Piston Soak Results
Discussion in 'Gen 2 Prius Main Forum' started by ozarkretiree, Nov 18, 2020.
  1. ozarkretiree
    ozarkretiree Member
    72
    26
    Missouri
    Four Touring
    I had an independent service shop do a 24 hour piston soak on my 245,000 mile Prius with great results. The tech said I had a couple of leaky fuel injectors and the other 2 were weak. I took the car to Toyota stealer and had the injectors changed out because the leakers were washing down the oil protection on the cylinder walls.
    My oil consumption has dropped to almost nil. My dipstick is showing down about 1/4 quart after 2200 miles since the above fixes were made. This is a huge improvement over the previous experience of needing a quart every 500 miles or so. I am posting this as a possible fix for those of you who are having consumption problems with engine oil. The soak cost about $110, mainly because it tied up a bay for a full day.
    Johhhn, Mendel Leisk and SFO like this.
  2. SFO
    SFO Senior Member
    5,302
    4,244
    Northern California
    Any ideas on what 'magic fluid' was being used by the mechanic ?
    nssdiver and Mendel Leisk like this.
  3. ozarkretiree
    ozarkretiree Member
    72
    26
    Missouri
    Four Touring
    I think he used SeaFoam.
  4. alftoy
    alftoy Senior Member
    1,132
    514
    Saskatchewan, Canada
  5. Stimp
    Stimp Member
    53
    North Carolina
    Seafoam is just isopropanol with a splash of petroleum distillates. Buying 99+% isopropanol/2-propanol online is probably a better deal than $eafoam.
  6. Mendel Leisk
    40,232
    oldtechaa likes this.
  7. Stimp
    Stimp Member
    53
    North Carolina
  8. Mendel Leisk
    40,232
    It is less than 25% isopropanol, according to the safety sheet. As HAL would say, this conversation can no longer serve any useful purpose.
    nssdiver, alftoy and oldtechaa like this.
