Playing the radio/audio set
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bramesh, Jan 25, 2010.
  1. bramesh
    bramesh New Member
    25
    Singapore
    Is it possible to play the radio/aduio set when the car is switched off?
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    Yes. If you press the Power button without pressing the brake you go to IGN-ON where you can listen to the radio. Press the Power button again without pressing the brakes and you go to ACC mode which is the same as older cars when turning the key to the ACC position. In ACC mode the dash comes on along with the radio, windows, doors, etc.
    You need to be aware of the fact that with either of these modes, the HV battery is not connected to recharge the auxilary 12V battery and you can discharge this battery if you are not careful. If you plan to listen to the radio for extended periods of time it is best to operate in the Ready mode so that the HV battery can recharge the 12V auxilary battery and then the engine can come on to recharge the HV battery when needed.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    The steps are correct, but are you sure the terminology isn't reversed? I thought ACC was the first step and IGN-ON was the second.
    Tom
  4. jdcollins5
    5,131
    1,342
    Wilmington, NC
    Tom,
    You are correct. ACC is the first step where you can use the radio and IGN-ON is the second step where you can use the other electrical items.
    Thanks for the correction,
    Dwight
  5. PazPrius
    PazPrius New Member
    72
    San Diego
    Also I have found that mine has a 1 hour timeout in the acc mode.
  6. ScottG10
    ScottG10 Member
    132
    Bothell Wa.
    In the Ign-on mode (second mode) the HV battery will charge the 12v battery even though the ICE does not cycle. I have verified this function myself with a DMM.
  7. bramesh
    bramesh New Member
    25
    Singapore
    Thank you all. I have learnt one more function today.
