Please help! Many dtc code
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by brwnjr82, Oct 7, 2008.
  1. brwnjr82
    brwnjr82 New Member
    london
    I took my Prius to Toyota Maindealer today for diagonistic check with regards to the warning lights showing on the dash board.The followings are the codes that came up..P3107,C1310,C1378,C1641.Please anyone with idea on what part of the vehicle might be responsile for these error.The car runs fine except it will not run on EV only or allows the use of PARK ASSIST.Many thanks to the ROOM.This error started after taking the car for a tyre replacement and aircon check at a local tyre shop.The car was then driven by the fitter with handbrakes on.He told me he was unable to locate the handbrake and then said the light was showing before he drove the car.>
  2. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
  3. Patrick Wong
    18,200
    6,491
    DTC P3107 "Lost Communication with Airbag System Control Module". This error code is logged by the hybrid vehicle ECU when it cannot communicate with the airbag ECU.
    DTC C1310 "Malfunction in HV System". A problem with the hybrid control system.
    DTC C1378 "Capacitor Communication Circuit Malfunction". A problem with the brake control power supply, the skid control ECU, or the wiring harness.
    DTC C1641 - Could not find this, is it possible that you have a typo with this one?
    I suggest you have your main dealer tech diagnose the problem, since your car is covered under warranty and these codes do not point to an obvious issue.
  4. EJFB1029
    EJFB1029 New Member
    4,726
    206
    Corpus Christi, Republic of Texas
    No logical reason for an A/C check by a tire shop, my guess is that they accidentally, or on purpose, disconnected some wiring in doing the A/C check. A 2008 should not need an A/C check by a tire/tyre shop, only dealer for that, since its under warranty.
  5. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Tire shops are the last people you want jacking with various components of this car. They can barely manage tires and alignment and you must keep constant watch on them.
  6. Patrick Wong
    18,200
    6,491
    Not to mention that the Prius electric A/C system design is relatively unusual, it uses unusual compressor oil, and an untrained A/C mechanic (not to mention a tire mechanic) is more likely to cause harm than benefit.
