please help.. my new prius won't start..
Discussion in 'Gen 3 Prius Main Forum' started by maniack, Oct 1, 2010.
  1. maniack
    maniack New Member
    san jose , ca
    hi. i am new here,,,
    i bought my prius today,,,
    new 2010 prius II . today afternoon...
    but around 10pm , i try to start but it didn't start for 5 times i tried....
    finally it starts 6th time.. i press the brake and push the start button each time i try.
    now no problem,, but what if it happens again...
    one of my friend told me dealer only suspect the problem when it happens..
    please help... any one know why or what am i gonna do or check??
  2. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    i press the brake and push the start button.
    now no problem
    You should back to the dealer and have them go though the operation of the car
    YOU must press the brake to start the car!!!!!!!
  3. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    After the ready light stopped blinking, did you put it in "D" or "R"? Even then, the engine (gas engine) won't always start until you start moving, or have moved a few feet. It will run on battery and electric power for a bit. Chances are that's what happened and after the 5th try you wore the battery down enough for the computer to kick the engine on to provide a recharge...
  4. maniack
    maniack New Member
    san jose , ca
    i said i press the brake each time i tried...
  5. maniack
    maniack New Member
    san jose , ca
    i mean each time i tried to turn on it didn't do anything,
    no power came on.. till 6th time i tried...
  6. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    When you pressed the brake pedal did the brake lights come on? Sometimes the brake pedal sensor doesn't work properly (it can be adjusted or replaced) and the car thinks you haven't pressed the brakes.
  7. bwilson4web
    15,986
    Without pressing the brake, I push "Power" twice. This brings up the display and enables the Aux input for my iPod touch. I select the podcast I want to listen and adjust the volume. I make sure the GPS is up and fasten my seatbelt. Then I push the brake and push "Power" to start the car and drive off.
    If I do not press the brake pedal on the third "Power" press, it shuts the car down. This could isolate a "Power" button versus brake switch issue.
    Now I know my startup protocol is a little rough on the 12 V battery but the battery is kinda of cheezy small. I look forward to replacing it.
  8. Superdrol
    Superdrol Member
    399
    32
    Have them do a diagnostics test on your battery to make sure a cell is not dead.
  9. cit1991
    cit1991 New Member
    289
    95
    Tulsa, OK
    On my 2010, the brake pedel switch was set too far forward, so you had to press the pedal alot to activate it. This made it difficult to tap the pedal to disengage cruise.
    That switch is what tells the car you're on the brake pedal to enable ready mode. Make sure you're pressing the pedal hard enough to turn the little LED on the start switch green.
  10. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    :thumb:
