plugging in two PIP's in one socket
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by knckdwntxt, Apr 26, 2012.
  1. knckdwntxt
    knckdwntxt Junior Member
    25
    Can anyone tell me if plugging in two PIPs into the same standard wallsocket is possible without blowing the circuit?
  2. plugable
    plugable Junior Member
    59
    Rancho Cordova, CA
    Each PIP draws 12 Amps, so it will blow the breaker even if you used a dedicated 20 Amp circuit.
  3. mitch672
    mitch672 Technology Geek
    1,077
    197
    Randolph, MA
    since the maximum current draw is 12A per vehicle, 2 of them together could possibly add up to 24A, that's most likely to blow even a 20A circuit breaker, depending on many factors (ambient temperature, age/condition of circuit breakers, voltage drop etc)
    if you had a 30A 120V circuit (not likely to be found), it would work.
    usually found at RV parks, "TT-30"'s, that are 30A 120V outlets, you could plug 2 PiPs into one of those, with a TT-30 to standard outlet adapter and a splitter... thats about the only case I can think of where it would work.
    this link has a picture of a TT-30 to standard outlet adapter
    eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
  4. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    Plugging them in is not a problem. Charging at the same time would be. But if you use the delayed charging feature you should be able to charge them both overnight..
  5. knckdwntxt
    25
    delayed charging is an excellent suggestion thanks!
  6. Rebound
    Rebound Senior Member
    3,970
    2,623
    Portland, OR
    It is a good idea! To be on the safe side, you can set one car's timer to an End time which is before the other car's Start time.
