PLZ HELP! My Prius Starts and then Stalls!??? HELP!!
Discussion in 'Gen 2 Prius Main Forum' started by svldvc, Jun 7, 2011.
  1. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    Hi guys. (I've searched the forum and didn't find the answer)
    I have a 2008 Prius Basic (no back-up camera :( )
    I just got this car and it started and drove and ran fine w/out any problems.
    After having it sit in my garage while waiting for title and paperwork.
    Now when I start the car it starts...works for about 3 secs and then slowly starts stalling as if it's choking and then just stalls....
    ...all lights come on...including the triangle...red car w/ exlclamation on MFD comes on...and MFD says Car has Problem.
    I have a scanner and TWO codes come up in OBDII:
    P0010 - Intake (A) Camshaft Position Actuator Circuit/Open
    P2111 - Throttle Actuator Control System - Stuck Open
    Please help me and instruct on how to fix it....(I'll try everything in my power to fix it myself before taking it to stealership)
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    I'm on this thing lately where I see odd problems and start suspecting things like the ignition coils. Does it sound like it's knocking? I had major problems at one point and tried a lot of different things. It wasn't until I started the "pull plugs till something happens" test. That I found ignition coil 1 had failed... Or was failing. No codes pointed to it. Symptoms steers off with brake errors... Power steering errors (both on and off)... A few others too... But eventually the engine simply stalled. (there was a Point when 45mph was my max speed)
    A lot of odd things for 1 item that will never throw a code.
  3. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    Sorry for stupid question...but where are Ingition Coils located?
    And how do I change them? (sorry I'm a n00b) :(
  4. Patrick Wong
    18,200
    6,490
    Your engine apparently has two problems if your OBD-II code reader is reading correctly. One is that the variable intake valve timing is not functioning. The other is that the throttle motor is binding.
    I doubt that a spark igniter has anything to do with the two problems above.
    Based upon your question, I will assume that you do not have a clue about the two problems that I described above. In that case you really would be better off visiting your Toyota dealer.
    However if you are a fast learner, then I suggest you visit techinfo.toyota.com and download the repair manual pages that are relevant to the two DTC. Then you can decide whether you are capable of fixing the problems or not. Good luck.
  5. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    any one has a digital copy of a Prius Service Manual that can lend me?
  6. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,515
    38
    Santa Fe, NM
    You should buy the Bentley book at Amazon. It will help bridge the gap between the automotive knowledge that you have and the sometimes indecipherable service manual.
    How long did this car sit? How many bars are on the battery on the display? Have you checked your 12V and verified that you see more than 12.3V with the car just sitting -- sometimes it only takes a few days of non-use and then you have http://priuschat.com/forums/newbie-forum/73400-weird-stuff-happening-mpgs-dropping-test-battery.html Is there anything else about this car that we should know, such salvage title, auction purchase, etc.
    P2111 - So, the Prius has throttle-by-wire, and this code says that your throttle motor is stuck open. The first place to start is at the intake: are all wiring harnesses connected, no mouse chewage, etc. Given that you have P0010 which could also be a problem with the main engine wiring harness, that deserves close inspection. Then take the black plastic air box off (i.e. the part that holds the air filter and contains the mass airflow sensor) and inspect the throttle plate, seeing if it moves freely, cleaning it if necessary. If that all looks good, then the service manual says to replace the throttle motor. But, your description is inconsistent with the fail safe for P2111, which is that the throttle plate is supposed to move to a 16 degree angle to allow for a fast idle limp-in mode. It is quite possible that you have many other trouble codes that the code reader can't show you.
  7. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    Thank you so much for being helpful.
    The car has been sitting for one month or so.
    I just bought a NEW 12v battery and my HV battery has a Pleanty of Load (2 bars less from full).
    Like I said...the car drove fine before and started w/out problem.
    I will follow your advice and will start with the airbox to inspect the throttle.
  8. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    As Seilerts expounded, the air throat area is very important, it can be cleaned with a clean cloth, and some Mass Air flow cleaner. Physically wipe both sides of the throttle plate. When disassembling the air filter box, you may encounter a very dirty air filter. This will give you a clue as to how the car was cared for. Pulling the plugs is always a educational endeavor, get the right tools and keep them for life. A simple procedure of just brushing the plugs lightly with a brass bristle brush can do wonders. The spark plugs are normally good for 100,000 miles on the Prius, but if the car was abused you may want to change them sooner. Good show on changing the 12V Bat, that is always a good procedure on a unknown car.
  9. striker308
    striker308 Three time Prius owner
    302
    43
    Evans, NY (USA) / South Williamsport, PA (USA)
    Documentazione Tecnica Prius 2006
    down load the sections to a file on your computer. they download in English.
    the only one I couldn't get is the wirring (bad link)
  10. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    Thank you for your help guys...will try to tackle this issue next week when I get some free time.
    will post update..
  11. crazy1977
    crazy1977 New Member
    CA
    hello Guys, i have a 2008 Prius (40K miles) with the same problem: DTC P2111 My engine starts and after 2 seconds it stalls.
    I've checked in another posts that the problem could be the throttle valve and sometimes cleaning could be the solution.
    But i have some questions for all people that have this experience:
    - How do you know if the ECM is ok? and it is sending the right current to the throttle valve?
    - How to test the throttle valve? applying 12VDC and 2A current? somebody did it?
    - Cleaning of the throttle valve allows you to soft move? how much soft?
    Before buying a new throttle valve I will clean the actual, and the i will post my results.
    Any Suggestions are welcome.
  12. seilerts
    3,326
    1,515
    38
    Santa Fe, NM
    It's not the ECM. You could monitor the current if you have a scan tool or inductive current probe. It is either a sticky throttle plate, the throttle motor, or a wiring problem. The resistance across the throttle motor terminals should be between 0.5 and 100 ohms. This could/should be a power train warranty item in your case (5 years, 60k miles).
  13. andyprius
    2,212
    188
    If the throttle plate is physically stuck, spray a LITTLE WD 40 to unfreeze it then spay spring to the left of air throat with some lubricant or light oil. Unplug elec connector that impedes you from removing the whole air filter box, inspect it, spray both sides of plug with Electronic spray cleaner, Shake off any excess and reinsert connector. Unplug and plug in several times to insure a good contact. You can do this with any any electrical/electronic connector. Make sure the excess is removed first. That throttle plate is normally in the closed position. Be careful when handling the mass air flow sensor.:cheer2:
  14. crazy1977
    CA
    Thanks for your response
    Today I've cleaned the throttle valve with any results. Still the same DTC p2111
    I've already measure the resistance in the terminals, is 3ohms.
    Does anybody knows how to test just the throttle valve? A simple test? Just open and close ellectronically? I saw the plate when I was trying to start the motor and it doesn't open, still close when the car starts, just i reach to hear some sound trying to open it but with no action on the valve (plate).
    I can't bring the car to a dealer for the moment, I'm so far away from one of them.
    Any adittional suggestion is welcome.
  15. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    I still can't fix it...did any of you guys had any progress? (crazy1977)???
  16. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    ::UPDATE::
    1.) I've replaced the Throttle Motor Assembly.
    2.)I found out that the code DTC P0010 "Camshaft Position 'A' Actuator Circuit (Bank 1)" was throwing because the oil control valve circuit (OCV) sensor was snapped off (broken). So I replace it.
    Now. When I scan my Prii again with OTC Nemisys 2010. Those two codes do NOT show up anymore (P0010 & P2111).
    BUT...I get 3 whole NEW codes...
    P0122 - Throttle/Pedal Position Sensor A Circuit Low Input
    P0222 - Throttle/Pedal Position Sensor/Switch B Circuit Low Input
    P2135 - Throttle/Pedal Position Sensor/Switch A/B Voltage Correlation
    Any info on these 3 new codes???
    What is wrong w/ the throttle pedal?? I didn't touch the pedal :(
  17. Patrick Wong
    18,200
    6,490
    Those three codes relate to the throttle position sensor which is located at the throttle body. Apparently you did something to upset that sensor or its wiring harness connector when you replaced the throttle motor.
  18. crazy1977
    CA
    If you want i can send tomorrow some pages from the service manual that shows that DTCs, now i dont have it. Check your inbox.
    The throttle valve that you changed was opening or not, before the replacement have you checked it?
    I saw that mine was not opening so i will order the throttle valve the next week.
    Someone knows how much open this valve? I can see just a try to open but i cannot see a gap for the air just like totally closed.
  19. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    ::UPDATE :: UPDATE:: SOLVED:: UPDATE:: SOLVED:: UPDATE:: SOLVED:
    **((all this following information is for future reference to those who will have the same problem as me & same DTC trouble codes & will stumble upon this thread)))**
    **NOTE:**
    my Prius had some minor damage to the front nose.
    Car ran & started fine.
    After sitting in the garage for 2 months, when I went to start the car...it would start..then stall after 6-10 secs of running.
    **CODES:**
    1.) P2111 - Throttle Actuator Control System - Stuck Open
    ((Solution)) Replaced the Throttle Body Motor Assembly (pic 1)
    *note* this code will ALSO be showing up IF the Throttle Position Sensor (TPS)(pic 2) has been tempered with, and if you put it in a teeny-bit "off from normal" position (I'm talking millimeters) from what Toyota intended it be...the computer will throw the P2111 code!!
    2.) P0010 - "Camshaft Position 'A' Actuator Circuit (Bank 1)
    ((Solution)) This code was throwing because the Camshaft Timing Oil Control Valve (OCV) Sensor (pic 3) was snapped off (broken). So I replace it. Code was cleared.
    3.) P0122 - Throttle/Pedal Position Sensor A Circuit Low Input
    ((Solution)) All of these 3 codes were showing only because of 1 sensor...the Throttle Position Sensor (TPS) (pic 2). For some reason my partner accidentally installed a "damaged" TPS sensor instead of the good one and that's why those codes were throwing.
    *Replaced it with a good TPS Sensor & all codes were cleared*!
    :cheer2: :cheer2:I want to THANK EVERYONE who was active and helping me SOLVE these issues and by giving me hints and pointing me in the right direction. (special thanks goes out to Patrick Wong for his educational help) ;)
    THANK YOU EVERYONE!!! :cheer2: :cheer2:
    Prius_Angie likes this.
  20. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    My 1st Throttle Motor wasn't opening either.
    When I installed my NEW one, I had already installed the airbox on top, so didn't look, but my guess is that IS OPENING UP since the car runs & not stalls anymore.
    But when the car is shut off...they are supposed to be SHUT completely.
    At least mine were.
    ~Serge~
