PLZ HELP!! No Heat!! No Hot Air!!!
Discussion in 'Gen 2 Prius Main Forum' started by svldvc, Dec 17, 2010.
  1. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    Hi guys.
    I have an 06 Prius.
    I was driving my Prius today and I've noticed that my car has NO HOT AIR... :(
    And this is Winter!! :rolleyes:
    I was driving for about 20 mins and still...No Hot air...vents are blowing cold (cool) air. :confused:
    I recently changed my condensor/radiator but I did NOT fill my condensor with the A/C gas yet. (could that be the problem?)
    But isn't the gas inside condensor is for A/C and not for the Hot air??
    Any other stuff that I need to check to solve this problem?? (harness, fuse etc.?)
    Please help me ASAP...it's cold outside and my car has NO HEAT! :( :(
    Thanks a million!!
    ~Serge~
  2. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    Did you say you just changed your radiator? Do you hear gurgling in the car? If so, it is possible you did not get all the air out of the cooling system. Make sure the coolant in the expansion tank is at proper level. Then put the heat on economy and max hot, drive down the highway for about 20 minutes to see if that changes the level in the tank.
    If that doesn't work, we will need more info to help you.
    Try to stay warm,
    Joe
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Most likely you have an air bubble in the system from refilling the coolant.
    Tom
  4. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    Current temp at State College, PA : 21ºF.
    Dude! Hopefully you can get that taken care of quickly. At least we're coming up on a weekend so maybe you can work on it over the weekend.
  5. mike lipke
    mike lipke New Member
    89
    MN
    To remove the air:
    Remove the black plastic radiator cover that is just behind the hood latch. Under that cover, directly over the radiator on the right (driver's side) of the radiator, you will see about a 1/2" hole in the metal brace. Take a flashlight, and if you have the right hole, you will see (6mm?) hex socket. that is the radiator vent. When car is cold, open that vent about 2-3 turn. Do not remove it, just loosen it. Now remove radiator cap and fill with 50/50 until fluid runs out of that vent(use your flashlight).
    Button it up and drive it again. You may have to repeat after a driving cycle.
  6. SageBrush
    SageBrush Senior Member
    11,627
    2,532
    Southwest Colorado
    An air bubble makes sense, impeding flow of hot fluid to the heat exchanger. Look up Pat Wong's thread on exchanging engine coolant, it has the best instructions related to purging air. I also suggest you jack up the front of the car (not the back) while you are at it. Last tip courtesy of Ed in Florida.
    The 'A/C' is NOT just cooling, it is used for water removal from the air also. It does not sound like a good idea at all to leave that component dry. Choosing 'A/C' or 'Auto' will turn it on; you definitely do not want to run the compressor dry.
  7. Cpl Bloggins
    Cpl Bloggins New Member
    New Brunswick, Canada
    1- check to see if you hear blower fan operating under glove-box with the A/C Auto switch off, the air flow switch set to vent through main instrument panels, and the fan speed switch to Hi.
    Check blower fan on both air intake settings
    2- If the blower fan works then set temperature to Hi and press rear and front defrost switches and fan speed to high.
    3-You should have heat even if you have coolant problems in the main radiator in the front of the car because the prius has 3 PTC heaters, with two of these heaters attached to the heater core radiator which is not same radiator as the main ICE radiator.
    4- If no air is blowing through the front windshield, then check to see if servo motors are operating for the inlet and outlet duct dampers.
    2 Inlet dampers on passenger glove-box side
    2 Outlet dampers on drivers side above gas pedal
  8. Politburo
    Politburo Active Member
    971
    208
    I don't think the compressor will allow itself to run dry, but can't say I've tried it..
  9. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    guys...all I can say is WOW!!! You guys are spot-ON!!! :D
    I can never stress enough how much I LOVE this forum!!! :D :D
    The air buble is the problem that I have...because I filled my radiator only once...and when I was driving it...a "PROBLEM" msg came up with a Triangle saying that my car is overheating (needs more coolant)...so now that makes sense.
    Today I will try to get the air out of the radiator system and re-fill my compressor with A/C gas.
    Does anyone have a link to Patric Wong's write up on "how to remove air" ??
    Also does anyone know how many cans or oz does the Prius need of the A/C gas, or how many cans?? Or what should be my pressure level for the A/C?
    Thanks a MILLION guys!! I love you all!
  10. qbee42
    18,058
    3,076
    Northern Michigan
    Make absolutely certain you use the correct refrigerant. The Prius uses a hermetically sealed electrically powered direct drive A/C compressor. This means that the electrical windings come into contact with the refrigerant and lubrication. If you use the wrong one it will short out the A/C compressor motor, necessitating a complete replacement of the compressor/motor.
    Tom
  11. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    wow...thank you sooo much for your post Tom..I didn't know that.
    I will make sure I buy the right one then. (can I buy from AutoZone or Dealer ONLY?)
    ~Serge~
  12. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    Justed talked to the Toyota Service...and they said that Prius takes the regular A/C freon as other cars do...BUT it needs a "special" oil though (Toyota ONLY) but it's not too bad..only $12.95.
    And Prius takes 1.06 lb of Freon :D :D
  13. koolingit
    koolingit Member
    158
    51
    Mocksville NC, USA
    I'd leave charging the AC to the dealer.
    All the air in the system has to be pumped out before refrigerant is put in. If you don't do everything right, it won't be 100% efficient, will work harder and break down sooner.
    The car talk guys say AC repairs usually cost around $100 or over $1000...there's no in between. Evacuating and charging your system should be around $100.
  14. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    Hi. guys..
    yes, my Coolant level was Low (in containter by hood latch).
    I filled it up and drove the car..and still No Heat! :(
    ***a TRIANGLE with "!" came on saying that car is over heating..
    What does that mean?? Is coolant not getting to the engine??
    When I got back in the garage, the Coolant level was still at FULL.
    Ran the car till ALL the bubbles got out of the tank and I could not see any more air bubbles. Still...NO Heat!
    Also I've checked the container (kind of small yellowish, flat-looking, w/ black cap) that is located NEXT to the Silver, Square box that says "Hybris Synergy Drive" on the Silver metal cap....and that Bottle that's next to it also has written LOW & FULL levels on it and it was on EMPTY. :confused: What is supposed to be there?? Coolant??
  15. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    also...(maybe off topic question)...
    On the Driver Side of the car (LH), there is a HUGE Silver canister (that has pumps leading to it and bunch of hoses)....What is that thing?
    I tried draining the fluid from it (by opening the little Yellow valve) and it's bright PINK color fluid...but I filled my Radiator with GREEN-yellowish Coolant... (so it didn't mix??)
    But that Pink stuff smells like Coolant...? (Is it coolant?)
    How do I pour it back??
  16. Patrick Wong
    18,200
    6,490
    1. I recommend that you use Toyota Super Long Life Coolant when replenishing coolant. This has a pink color and is premixed with distilled water. Other coolants may not be compatible.
    2. The empty container mounted to the side of the inverter holds inverter/transaxle coolant. This also should be filled with Toyota SLLC and the bleed valve at the front of the inverter needs to be opened to rid the system of air. There are several posts regarding how to do this.
    3. The canister in the LF fender well holds engine coolant, that is why the fluid is pink. This is replenished via the radiator cap.
    4. I recommend that you remove the actual radiator cap to see what the coolant level is, and refill as needed. Do not assume that fluid added to the reservoir will quickly make its way into the radiator; this may take a long time depending upon the level within the radiator.
  17. northwichita
    481
    102
    29
    Wichita KS
  18. SageBrush
    11,627
    2,532
    Southwest Colorado
    That is a no-no. Pls follow Pat Wong's advice
  19. edthefox5
    edthefox5 Senior Member
    10,096
    4,829
    Clearwater, Florida
    Exactly. The Prius electric compressor is tricky. The system uses special ND11 oil. If even a small amount of any other type oil is introduced into the system it will break down the electrical insulation in the comp and it will throw a DTC. The scope of the amount of oil to be installed is out of home diy'er capability.
    And since you have installed the wrong gas it is imperative to get to the dealer and have the system purged asap.
    On any car on the planet with a new condenser having been replaced a complete sytem evac and flush must be done before a re-charge. A new drier is a good idea also.
    Plus when replacing any component in the ac system a leak check is imperative and is part of any competent ac repair.
    Charging the system without a complete test for even a tiny leak is waste of time:
    http://www.denlorstools.com/home/dt1/multilist_167/automotive_air_conditioning_leak.html
    Be careful with the engine coolant also as you could overheat the motor. Just because you have no cabin heat does not mean the engine is not overheating. Even a slight overheat is not good on the engine as it has an aluminum head. You have a monster air lock.
    Get the car to the dealer.
  20. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    Okay...the A/C i haven't touched...the dealer has to do it.
    I haven't used ANY "freon"...I've only used a wrong Coolant (green one from Auto store),...but it's all drained now :D
    But my car DOES overheat even with the coolant in the system...why?? <<---That's my question..
