PO3190, non-specialist mechanic can't figure it out
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Blaq, May 15, 2015.
  1. Blaq
    Blaq New Member
    Boston
    Hello!
    2008 w/ 128k miles
    I was driving, red triangle of death came up & the gas pedal felt unresponsive so I pulled over. Oil was low, so I added a quart which brought it to full, and while the check engine light was still on, the triangle was off so I went on my way. Car still felt off though and when I came to a stop, the car was kind of shuddering forward.
    Took it to my mechanic, he found that the inner shaft seal in the transmission had broken. I was completely out of transmission fluid. Repaired it for $500 (apparently it's a bitch to get to), gave me an oil change (I had put in a slightly thicker oil, all they had at the closest gas station when I stopped originally), and sent me on my way.
    An hour of driving later, triangle comes on, as well as the "Hybrid System Malfunction" light. Car smells funny/hot, gas pedal unresponsive (like the ICE stopped but the electric stayed on), was difficult to accelerate, and then after 30 seconds the display/engine cut out and I cost to a stop.
    Car still starts, but figure I didn't want it dying on the highway and I was safe where I was. Got a tow. Drove it the 2 minutes to my mechanic the next day.
    Says it's throwing a P3910 but says that has a host of possibilities and he can't recreate the engine failure to try and diagnosis it.
    Any advice? I suppose I should take it to a specialist.
    Recent repairs:
    - 12v aux battery
    - Front axle (Apparently the seal had broken, the fluid had gone, dirt got in and eroded it. Car was shaking violently when I drove over 50pmh. $1k fix.)
    Unaddressed problems:
    Very occasionally the display doesn't want to come on when I start (can't see how fast I'm going/fuel level). Not enough of an issue for me to really be bothered with.
    #1 Blaq, May 15, 2015
    50,828
    huh. probably should take it to a toyota dealer for specific codes and troubleshooting.
    how many miles on her? maybe the hybrid battery needs to be replaced.
    also, inverter, inverter pump, inverter recall, serpentine belt, so many possibilities.
    Blaq likes this.
  3. Blaq
    Blaq New Member
    Boston
    128k+
    That was our first thought, he looked into it and concluded it was fine.
  4. Mendel Leisk
    40,254
    I wonder: how long was it completely out of transmission fluid? And did he use Toyota ATF-WS or something else?
  5. Blaq
    Blaq New Member
    Boston
    I drove for an about an hour home after that first light.
    I noticed when I took it to him the next day that there was drippage under my car (I thought it was an oil problem originally given it seemed odd I had run low so soon after a change <1k miles). He said it was a mess under there, apparently it was quite the leak.
    Couldn't tell you what he used.
  6. bisco
    50,828
    you're under the 10/150 warranty, yes?
    Blaq likes this.
  7. Blaq
    Blaq New Member
    Boston
    I don't see why not. Parents bought the car in CA, I'm living in MA now. Both have the stricter emission laws.
    (I assume we're talking about the battery warranty?)
    If you're talking about some sort of extended warranty from the dealership my father should have bought, I don't believe so.
  8. bisco
    50,828
    no, the basic toyota warranty should have you covered, depending on what is wrong.
    the only way for us to help is to get the codes. that's either toyota, or a mech with toyota capability.
    if you're tech savvy, you can retrieve them yourself.
    Blaq likes this.
  9. Blaq
    Blaq New Member
    Boston
    Oh wow, thanks for the advice. Few quick questions since I don't know how these things work:
    Does that cover just parts or labor as well?
    Do I have to go to a dealership to take advantage of that or can my independent mechanic take care of me?
    Should that have applied to my transmission inner shaft seal ($650) or axle replacement ($1k) as well?
    PS. I noticed your location is Boston as well. Do you know any good/honest mechanics in the area? I've been using E&S and been happy. But I don't really know enough to tell the difference, and I'm not sure how well he knows Priuses.
  10. bisco
    50,828
    parts and labor, dealership only. unfortunately, the tranny isn't considered part of the hybrid system. hopefully, whatever else is wrong, will be. i don't keep my cars long enough to have a mechanic. the only thing i can advise is checking triple a, you need someone with toyota tech stream analysis software.
    Blaq likes this.
  11. Blaq
    Blaq New Member
    Boston
    No problem, appreciate the advice!
    For the dealership: should I anticipate any problems with the fact the car was purchased from a dealership in CA (not Boston)?
  12. bisco
    50,828
    you can try calling good news garage in cambridge, they're the guys who used to have the car repair show on npr.
    Blaq likes this.
  13. bisco
    50,828
    the only thing i'm not sure of is whether the car has to be purchased and registered in mass the whole time, to be covered by the 10/150. they can tell you that before you authorize any work.
    Blaq likes this.
