1. Dirtnapper
    Dirtnapper Member
    104
    MA
    2014 Prius v wagon
    The power window on the passenger front side will go down using the switch on that door, but, I have to put it up using the switch on the driver's side. Any idea what is happening? Thanks.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    It sounds like the issue is with the passenger window switch since the window operates with the driver side switch.
    Check the continuity of the switch contacts with a multimeter. If you get high resistance try cleaning the contacts.
  3. Dirtnapper
    Dirtnapper Member
    104
    MA
    2014 Prius v wagon
    OK. Do I have to remove the whole panel or is there another way to get at the switch is my next question? Thanks.
  4. jdcollins5
    5,131
    1,342
    Wilmington, NC
    You should be able to remove the switch assembly from the arm rest.
  5. Dirtnapper
    Dirtnapper Member
    104
    MA
    2014 Prius v wagon
    It was very easy to pop the armrest piece off, and pop out the switch. Just swapped the back door one for now while the new one is on the way. Less than 20$ for a switch, shipped. Thanks.[​IMG]
    uart likes this.
  6. jdcollins5
    5,131
    1,342
    Wilmington, NC
    Good deal. It is always good to hear about an inexpensive fix.
    Good move in trying a known good switch in this location to verify the switch problem.
  7. northcoaster
    northcoaster Junior Member
    32
    northcoast
    I have exactly the same problem but am leery of popping out the switch or armrest and breaking some small plastic clip that holds it in and then have to buy a whole new one....do I slip a flat screwdriver or butterknife or putty knife under it and get it out?
    I forgot, where did you get the new switch for $20? Thank you so much!! hope you get this and can reply
  8. Dirtnapper
    Dirtnapper Member
    104
    MA
    2014 Prius v wagon
    I don't recall where I got it exactly,just do a Google. I got rid of that vehicle last April and dumped all records, got the prius v. It was nothing to pop the old one out.
