Priapus squeaks; What's up with that?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TonyPSchaefer, Aug 18, 2011.
  1. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    Truth be told, I'm not a car guy. So even some of the more mundane automotive issues have me stymied. With this in mind, can someone please explain to me why it sounds like Priapus' undercarriage is squeaking when I roll over uneven pavement and make slow turns and the like? These are not internal sounds as I know all those.
    It's a metal-on-metal squeaking kind of like rolling around on an old mattress.
  2. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    First the HID sensor, now the squeaks. I think you are just paving the way to get a new car... :rolleyes:
  3. northwichita
    481
    102
    29
    Wichita KS
    It needs greasing, unfortunately there are no grease zerks ( that I know ) on this car. Do you have any broken rubber boots on the tie rods, ball joints, or sway bar links? That would be a good clue. I replaced my sway bar links recently, boots were partially gone, to cure my noisy car.
    http://www.carpartsdiscount.com/aut...abilizers/front_sway_bar_link.html?3593=84767
    above link is for photo only, I bought mine on ebay.
    50,818
    turn the radio up. :)
  5. TonyPSchaefer
    14,816
    2,499
    66
    I really am eyeing a 2012 PHV.
    Its hard to miss the noises with a car this silent.
    NorthW: I can take a look but, referring to the OP, I might not know it if I see it.
  6. bisco
    50,818
    when you get to my age, you won't hear the squeaks. or the radio!
  7. Tideland Prius
    16,405
    Could it be the springs?
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Do you also hear it when you are not in the car? It could be your knees.
    Tom
  9. ursle
    ursle Gas miser
    1,049
    192
    NH
    Check the shrouding around the muffler, it comes loose and as the muffler sways around makes contact, at least mine did and as the muffler is a hollow tube the sound seemed to originate from the front end.
  10. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Priapus likes to post here every once in a while. Why dont you ask him to post about it?
    Can you get a recording of the sound?
  11. Priapus
    Priapus Alter Ego
    Pervert shoved a microphone in my rear and started rocking me up and down! :eek:
  12. TonyPSchaefer
    14,816
    2,499
    66
    See what happens when I try to diagnose a problem? He's belligerent and difficult.
  13. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    You recently jacked up the car to check out the HID thingamajig right? Maybe you stressed bushings or your spring perches such that they move around more. I would also check the rear of the car for the same issues. Jacking up the car, especially from just one corner, can cause some parts to loosen up or even crack if they are rusted.
  14. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    Squeaks? Priapus? You need some lube, obviously. :p
  15. TonyPSchaefer
    14,816
    2,499
    66
    There was no jacking. I backed up onto blocks. I've done that several times in the past.
  16. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Well, it's less likely to be the problem but I would check anyway. Those are the most likely to cause a metallic squeak. A broken muffler hanger can cause a similar sound.
  17. TonyPSchaefer
    14,816
    2,499
    66
    I just wanted to be clear that I was not jacking Priapus.
  18. Tideland Prius
    16,405
  19. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Well you did say it started squeaking. Whatever you do to your own car is your business.
  20. edthefox5
    edthefox5 Senior Member
    10,096
    4,829
    Clearwater, Florida
    Of course it sqeeks. Its a metal machine. Its dry as a bone and rusted.
    It needs to be lubricated with spray grease. Lots of moving parts there in the front end. Especially the trailing arms.
    My cars don't sqeek.
    Plus it doesn't help if its spent its life on severely overinflated tires.
    That beats the sh*t out of the suspension.
    Its probably why so many people complain about rattles.
    I've tried inflating my tires to 50 lbs. Whoa the car hits really really hard on the slightest bump. Not good.
