Pricing: FAIL, for one!
Discussion in 'Gen 3 Prius Main Forum' started by jginnane, Apr 21, 2009.
  1. jginnane
    jginnane New Member
    coastal NJ
    I've been reading this forum carefully for several weeks. The 2010 Prius wasn't my first choice, but the Insight II left too much lacking.
    I was pretty much set on a IV, despite the waste on a "satellite radio" and other nonessential items. I'd give up the V's 17" rims for a sunroof, with-or-without a solar array. (You know these will be 19.95 at Pep Boys in 6 months, and aftermarket rims/rubber always beat OEM choices.)
    BUT... one thing I absolutely demand, have to have, and all that, is good lighting. I was concerned to see HIDs go away and LED fronts brought in.
    Well... based on the MSRP packages we're seeing today, it looks like it'll be smarter to go back to the 5-year old solution we put on an '04 Acura TSX and add two pairs of Bosch Compact 100 lights: one set amber 55w fogs, and a pair of 10-degree spot driving lights, to supplement the stock 55w halogens. Toyota's LED fronts + "fog lamps" only come on the V trim level, and constitute a major premium over the IV. [Sure, they say these LEDs will last 15 years. But they're already so cheap that it doesn't matter.]
    Better lighting, leather seats, and a sunroof were major reasons we considered the 2010 Prius -- more important than MPG or power considerations (because, let's face it, we're only dealing with 4-bangers here.) But at this point it seems we're committed to major customizations, no matter whether we get the Prius or an Insight.
    So ... I'm calling this a FAIL for this particular buyer, because the option array just isn't working for me.
    [[[ PS -- Info on the lights at www-dot-boschlightsandmore -dot-com / products_fog_driving_lights-dot-htm -- I can post pix of them installed on our old TSX but it's kinda OT. When we had the TSX's HIDs, halogen high beams, Bosch fogs and spots all working at the same time, you could cook the toupee right off that Camry driver hogging the passing lane. :) ]]]
  2. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    I used to have an aftermarket Hella halogen on my motorcycle, and had to install an off switch so the battery had enough juice left to turn the starter. Despite careful alignment, people were always flashing their lights at me. "Oh...you wanna see the high beams, do you?" :eyebrows:
  3. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    We made this noise early on and it wasn't going to be changed this year. Despite, the difference in lighting isn't likely to be THAT significant that couldn't be handled w/ aftermarket bulbs and/or aftermarket fogs/driving lights.
    OR - you can find a way to add LED's from a salvage car and forego the auto leveling (unless you're really thorough and add the ECU/sensors/etc.)
  4. jginnane
    jginnane New Member
    coastal NJ
    LOL! I have a pair of French-made fogs with "soda glass", whatever that is (the glass is about an inch thick, and the pair weighs >15#) never installed on my Yukon (because I couldn't find a front rack I liked). I always read owner forums to see what people are trying to do to fix the lighting problem. (The halogens on a GMC Yukon were as weak as the brakes, which is to say, not adequate to the design purpose.)
    What most people don't realize is that car electric circuits can almost always handle another 55-watt circuit or 2 -- they have a significant safety margin to allow for leakage, aging batteries, generator age, etc. Here in coastal NJ, there are way too many deer running around after dark that you need that extra second or 2 of reaction time that better lights can give. But the key is to get _good_ lights: OEM fog lights, often a $300-600 option, are commonly useless in fog conditions. And the USA aftermarket seems to have ignored the value of narrow-cone "spot" driving lights, except in professional racing circuits.
    If we have the ear of the Toyota product team in this forum, I'd urge more attention be given to the issue of lights to see by. Toyotas seem to accrue to a slightly older demographic, and past the age of 50, you look for reasonable mechanical augmentations. :rockon:
  5. jginnane
    jginnane New Member
    coastal NJ
    Well, one of the tragedies we often see on the NJ Turnpike is kids w/ 8000-degree Kelvin lamps doing the zoom-zoom. Bright blue lights not only create instant headaches for other drivers, but actually work to lessen driving visibility in most road conditions. (Because blue light scatters more -- so in fog conditions, blueish headlights make an opaque wall in front of you, whereas amber fogs with low cutoff give a much better chance of actually seeing the road surface. Safety!)
    Beyond that, aftermarket bulbs don't help if they go in a lens housing that's wrong for the bulb. HID kits that re-use a manufacturer's halogen housing, for example, are universally WRONG. HIDs need a different lens/reflector combination. Whereas halogens don't have sharp "cutoffs", these are absolutely essential to safe and proper HID lamp display. I haven't studied the optics of LEDs for front lights yet, but doubt much has changed regarding the laws of physics.
    How important are headlights? If you are a cash customer willing to stand by your criteria, they can be a model-disqualifier, like absence of VSA (vehicle stability assist). Lease customers might look at it differently, since they don't own a car, and think they can get by for 3 years or so. But there's a world of difference in headlights between good and legally adequate.
  6. HTMLSpinnr
    5,341
    920
    251
    It's all a matter of perspective. Some folks (me excluded) are soured by the Prius HID experience and will happily take the std Halogen bulbs.
    The LED is a cool (7-8000 K) looking light as well. Perhaps not *quite* as cool as the HIDs when brand new, but they're not the "warm" light of incandescent/halogen bulbs.
  7. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    We've found the standard Halogens to be quite sufficient in our Prius.
    I, personally, hate HID lights. No way I'd inflict those on others.
  8. JSH
    JSH Senior Member
    2,605
    140
    PDX
    I have an off-topic question. I've been noticing lately more and more people are using the word, FAIL. Generally it is a short statement followed by FAIL! Where does this come from? I assume it is from some TV show or celebratory that I not familiar with.
    • Homer from the Simpsons popularized "DOOH!!"
    • Senfield brought us "Not that's there is anything wrong with that"
    • Martha Stewart started "And that's a good thing"
    I'm curious who started the whole "FAIL!!" thing?
  9. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    I mostly know it as an internet meme. Where it came from, I don't know. Wikipedia claims ([ame]http://en.wikipedia.org/wiki/Failure[/ame]) it comes from a video game, for whatever that's worth.
  10. sl7vk
    sl7vk Member
    518
    23
    Salt Lake City
    Just take the opposite approach....
    Start every sentence with Fact!...... Just like Dwight Schrute does.
  11. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    You can call your local Toyota dealer ... ask them the parts / labor cost to replace 1, singular HID headlamp in , oh ... a 2009 Prius
    How about $400 for 1 HID replacement.
    HID's have been a problem, do a search, they needed to go ... bye, bye.
  12. jginnane
    jginnane New Member
    coastal NJ
    I know that bulb replacement cost on Acuras is just under $100, which is not bad (though you should replace as pairs, so the color temperature stays the same).
    If "labor" means you have to pull a lot of things apart to get to where you can unplug the bad bulb, that's not a good thing. But our experiences with HIDs on several cars (Honda and Nissan) have been positive to the point that when I get in the Yukon at night, I often recheck to see if I'm only using DRLs.
    Back to the Prius, these pricing tiers mean you have to go "all in" on trim levels to get the latest and best lights. Meanwhile, dropping the other models (I - IV) back to 55w halogens might have helped keep the selling price down on the car... but that's like leaving seat belts out of the rear because most people don't carry passengers all the time. (It's not where I would have chosen to cut, IOW.)
  13. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Not only do you have to go "all in", but you have to opt out on the solar sunroof. You can't have both. :mad:
    Tom
  14. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    Packaging for the UK appears to have, as an option on the T Spirit, the solar panel but no moonroof. All models appear to get LED headlamps and front fog lamps.
    We don't know the exact contents yet; I'm going by the text descriptions and the pictures on toyota.co.uk. T Spirit: "A solar roof panel, powering a highly effective cabin ventilation system, is also available as an option." The pictures show the T3 with 15" wheels, T4 and T Spirit with 17" wheels, and all three with LEDs. One of the interior photos in the gallery shows the sliding roof headlining, but the exterior shot seems to just have the solar panel; if there's an opening section it's body-coloured (a 'sunroof' rather than a 'moonroof').
    We also don't know pricing yet, but currently the T3 costs £18,370, the T4 (T3 + JBL audio and changer, cruise control and fogs) an extra £785, and T Spirit (T4 + parking assist, nav and Bluetooth) an extra £2,055 over the T4, £21,210 total. I'm hoping for pricing to remain about the same.
    It's not that the car doesn't fundamentally support the configuration you want, but that TMS USA have decided not to offer it to you.
    For EU type approval, indications are that it will be sufficient to have two approvals, one for 15" tyres and one for 17". The former is rated at 89g/km CO2, the latter 92g/km; fuel consumption 3.9L/100km (15") and 4.0L/100km (17"). (Both are in Band A for UK Vehicle Excise Duty, below 100g/km CO2, which is therefore free.)
  15. HTMLSpinnr
    5,341
    920
    251
    Photo is rather suggestive of a body colored panel, however it could also be the glare from a different angle (polarizing filter anyone?).
  16. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    the Term FAIL has been noted to have began from 4chan.org several years back.
    and yes it's way overused.
  17. patsparks
    10,664
    567
    Adelaide South Australia
    Aren't fog lights compulsory in the UK? Isn't there fog 3 days out of 4 or something?:target:
  18. jginnane
    jginnane New Member
    coastal NJ
    What it means, in the context of this thread, is that at least one Prius probably won't be sold because of the initial option package/pricing array. It seems many people are having similar problems with current Prius marketing decisions. Six months from now, when the correct set of options are available, we may no longer be in the market.
    Incidentally, trying to hijack the thread to talk about process instead of what everyone else is talking about is a little young.:focus:
  19. Mike Dimmick
    963
    249
    Reading, UK
    Rear fog lamps are compulsory, yes.
    Since introduction of Euro emissions regulations and increasing switch to natural gas and electricity for home heating and cooking, smogs are incredibly rare.
    It was quite foggy at about 6am but is now really clear. I've used my rear fogs maybe three times since buying the Prius a year ago.
    I don't currently have front fog lamps. Of the three models, T3 has a very good set of options, T Spirit is overloaded (built-in nav = £££), and the T4 costs an extra £785 for only adding Cruise Control (£10 stick and a different brake light switch), front fog lamps (didn't find them that useful on my 2001 Focus) and JBL stereo.
    Still, the front fog lamps look better than those godawful grey plastic plugs in the bumper.
  20. qbee42
    18,058
    3,076
    Northern Michigan
    So what do you think about cats?
    Tom
