Prius 10 Car battery question
Discussion in 'Gen 3 Prius Main Forum' started by justaguy, Aug 4, 2010.
  1. justaguy
    justaguy New Member
    136
    california
    My prius battery just died overnight a few weeks ago because i left the door open. I got it jumpstarted by aaa.
    The battery level has been fluctuating when im driving. It would go up and down and not stay up while driving. Generally regenerates when i brake alot. I just got it serviced at toyota and they OK'd the battery condition.
    Battery fluctuating during driving. Normal or not normal? am i just paranoid?
  2. chuckc192000
    chuckc192000 Junior Member
    44
    The battery you see on the display is NOT the battery you had to have jumped. There is a separate 12 v battery that is used to run the accessories and the computers when the car is not turned on. It's normal for the battery that drives the electric motors to fluctuate up and down depending on driving conditions and the way you drive the car. It would be highly unusual for it to remain at full charge all the time.
  3. justaguy
    justaguy New Member
    136
    california
    ^that's news to me
  4. Colonel Ronson
    Colonel Ronson New Member
    443
    33
    Tucson, AZ
    This is your hybrid battery. It goes up and down for everyone. And even if this wasn't a hybrid, your battery level doesn't stay the same in whatever car you're driving...
  5. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
  6. Penny's Dad
    Penny's Dad New Member
    421
    46
    Orlando Fla
    I left the house my traction battery indicated 2 bars left...I got to work and it was within 1 bar of the top (that's quite a range). Since I was close to top I switched to EV mode entering my parking garage...drove around parking garage in EV with lights and AC on...parked with 4 bars left...Hope that answers your concern.
  7. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
  8. andreiliev
    andreiliev Junior Member
    23
    Chicago
    Hi there,
    After two days of cold, my car is out of power. Lights are very weak and it is very difficult to unlock it.
    Do you think it may be the 12v battery ?
    Where can I find a new one ?
  9. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Sounds likely, run the test at http://priuschat.com/forums/newbie-forum/73400-weird-stuff-happening-mpgs-dropping-test-battery.html after you've left the car overnight. Tell us the values you get after each step.
    You also have a 2nd gen, so you shouldn't have bumped this thread.
    Many would recommend http://priuschat.com/forums/prius-h...-12v-yellow-top-d51-battery-pencil-posts.html instead of buying a replacement from Toyota. It won't save you any money, but many feel it's a superior battery. I have one of these but w/different sized terminals as the pencil post version didn't exist yet.
  10. richard schumacher
    7,664
    1,042
    United States
    A new Toyota battery and the Optima yellowtop D51 pencil post are the only drop-in replacements. Anything else requires modifications to the car.
    A Toyota dealer should not charge more than about $200 for a new one installed. More than that and they're trying to gouge you; go to another dealer.
  11. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
