Prius 2008 Tires
Discussion in 'Gen 2 Prius Technical Discussion' started by dvasicek, Feb 27, 2010.
  1. dvasicek
    dvasicek New Member
    Colorado
    I have about 24,000 miles on my 2008 Prius. A sort of "thumping" sound has appeared. It is slight, but I can hear it when I driving. A tire person told me the treads are uneven from having been worn down. He recommended that I buy four new tires. Does this sound accurate?
    Thanks.
    Don
  2. Patrick Wong
    18,200
    6,491
    That sounds plausible. Do you know what is the current tread depth of the four tires; and were the areas of uneven wear pointed out to you?
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    If you have 24,000 miles on your OEM tires, you are 20,000 miles past when they should have been replaced. The Goodyear Integrity tires should be replaced before the first snow, preferably before the first rain.
    Tom
  4. dvasicek
    dvasicek New Member
    Colorado
    The current tread depth is about 1/4". It is difficult for me to determine which way the areas of uneven wear pointed. They appear to be pointed out to me.
  5. Politburo
    Politburo Active Member
    971
    208
    I have to say my Integrities, with 18-22k, did pretty well with the storms this winter. I was surprised after having read so much about them here. I only got close to being stuck once, but it wasn't really the fault of the tires, and the other guy who was there was also having a bit of a problem.
