Prius (2011) won't start / switch to "Ready" mode after 12 hours of not driving
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by howlz, Dec 16, 2016.
  1. howlz
    howlz New Member
    Austin, Tx
    First off, this forum has been extremely helpful in narrowing down what the issue is I'm having with my 2011 Prius. However, I've mentioned the problems I've assumed it is to my mechanic: 12v battery, brake sensor, and they still can't figure out the problem.
    Here's the issue: This just started as it's gotten cold in the last month. I live in Texas, so it doesn't get that cold (~32 on coldest nights for a few hours). If I leave the car in the driveway for more than 12 hours or so and come back to start it up, the car will not switch to "ready" mode. The lights all turn on and it beeps, but never turns over to "ready". This thread shows a video of the exact start-up problem I'm having with the same model car, and she figured out that it was a 12v battery problem.
    I took it to my mechanic yesterday and they've already racked up $300 in labor charges, seen error codes that the car sends, taken apart the wiring to test if it's loose, checked the 12v battery and say its fine... yet, they still are unable to fix the problem and can't replicate it now because the car will start if it hasn't been sitting for more than 12 hours. They offered to keep the car over the weekend so that they can figure out what the issue is on Monday after it's been sitting, but I am worried that I'll leave it there and just keep racking up a labor bill without a fix.
    I've had the car for about 4 years (bought used from 1 owner). I have not replaced the 12v battery in that time frame, but the mechanic is saying it is not the 12v battery. I typically only drive the car about 25 mins a day, mostly city driving, and sometimes not at all. It's been on a few long road trips, and this is the first time I've had any issues with it.
    I'm wondering if anyone else has any ideas of what could be the problem? Is there a way I would know that the 12v was the culprit causing this issue?
    Thanks in advance for any help.
  2. mrbigh
    3,686
    699
    Long Island, NY
    Replace the 12VDC Auxiliary battery and avoid any further extra expenses
    Mendel Leisk, Rebound and howlz like this.
  3. JC91006
    16,641
    8,496
    $300 pays for about 2 of those suspected batteries
  4. howlz
    howlz New Member
    Austin, Tx
    Thanks for your replies. I have an update: I just picked up the car from the mechanic and they were adamant about it not being the 12V battery... but I still have a hunch that that's what it is (bc it's a 6-7 year old battery, your recommendations). They found an error code (U0155) stored, but they aren't even 100% sure when this code was thrown.. it's just the last code in the system.
    Here's what they said on the bill: "This fault could not be duplicated at this time but a fault code is stored that is likely fail point. U0155 fault code is stored in the vehicles control module (IPC). This fault indicates a faulty dash display and/or a failure in the vehicles can-bus communication system. The technician will need at least 2 hours to further diagnose the problem."
    So I approved those two hours and this is what he found out: "The following morning no starting issues were present at this time. The technician performed a full pin out of the modules power and grounds and found no current issues. The technician then performed a test on the can-bus system to confirm proper operation of the vehicles can-bus communication system. Without the vehicle failing while it is here we will not abe able to confirm if the module has failed or is intermittently failing. The older prius (generation 1 and 2) have an issue with this and it is possible this vehicle may also. Due to the cost of the parts and time involved we suggest having the vehicle here while it is failing or leaving the vehicle here to re-test after sitting for 1 day or more."
    Since the car is working fine once it starts for the rest of the day, I didn't want to leave the car over the weekend and rack up more labor charges. They are telling me that it is most likely the instrument panel cluster that is faulty and will probably need to replaced (~$2000 parts + labor).
    After hearing their feedback, do you think it could still be a 12v battery issue? The guy I talked to said if it was the 12v battery that the car is "smart enough" that it will send an error code for that, and they only see the U0155 error.. Is that true?
    I am going to replace the 12v battery in the next few weeks after I absorb this unexpected cost, but I wanted to be sure that this error code hasn't happened to anyone else with similar issues. Mechanic says this happened in Gen 1 & 2 prius where the IPS would overheat and they supposedly fixed it, but now seems to think this Gen is having the same problem. Doesn't make sense...
  5. Rebound
    Rebound Senior Member
    3,970
    2,623
    Portland, OR
    Two possible solutions:
    1) Throw another $2,000 at it and replace the 12V battery, or
    2) Replace the 12V battery
    Of course it's possible that it's not the battery, but that's the most likely cause from your description: Voltage falls after 12 hours of exposure to cold. Sounds like a marginal battery.
    howlz likes this.
  6. howlz
    howlz New Member
    Austin, Tx
    Thanks, I'd definitely replace the battery before investing $2k on something the mechanic isn't even sure is the problem o_O It seems insane to me that the mechanic is telling me there's no way it could be the battery, even though it's the original 6 year old battery, and wants to blame it on something that would cost $2k to fix, even though he's not 100% sure about that either.
    Or maybe that's not insane and just a sign that I need to find a new mechanic! I think the latter.
    I did find this post that was similar, and again 12v battery seems to be the consensus on the cause.
    Thanks for your help everyone! (y)
    I'm going to go ahead and replace the 12v battery either way first and I'll update this thread if I am still having the problem. If anyone has had a similar issue or any other ideas in the meantime, feel free to share.
    Rebound likes this.
  7. Rebound
    3,970
    2,623
    Portland, OR
    When it wouldn't start, how did you eventually get it to start?
    Raytheeagle likes this.
  8. howlz
    howlz New Member
    Austin, Tx
    I usually had to keep going through the startup process... turning it off and then pressing break in and pressing power button. It takes 4-12 times to turn on if the cars been sitting. Usually powers on immediately if its run within 2-3 hours.
    I just went to do a 12v battery test, but seems like I may need the color dash display which my car doesn't have. Anyway I had recently driven the car within an hour but followed the instructions to try to test the 12v. Since I couldn't find the display on my model I gave up and went to start the vehicle. Wouldn't switch over to ready. Could it be because I started the car without the gas, further draining the 12v? I tried about 10 times and the car eventually switched to ready...
  9. howlz
    howlz New Member
    Austin, Tx
    Sorry double posted
  10. Mendel Leisk
    40,262
    You can check the 12 volts health yourself, with something like Solar BA5. Any competent battery retailer will have a similar pro level tester. Regardless of the outcome:
    Replacement of a 5~6 year old battery is "low hanging fruit", ie: it's well past it's prime, may be the issue, couldn't hurt.
  11. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Yes and NO, in that order.
    The battery VERY likely is failing and a simple voltmeter test of the voltage after sitting for 12 to 24 hours likely would prove that........but most recently trained "technicians" don't seem to even know what a voltmeter IS, much less how or when to use it.
    When the 12 V battery is getting weak, the low voltage to the computer modules can and does make all kinds of weird things happen, including various false failure codes.
    Get a name brand AGM battery and charge it fully before installing. You will be happy that you did.
    P.S. I would suggest that the "mechanics" at that shop are a bunch of morons but this kind of situation seems to be the norm these days instead of the exception. Search for old threads regarding 12 V batteries on here; there should be a TON of matches with eye opening information. It affects all models of hybrids; even other makes too.
    howlz likes this.
  12. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    IMHO all 2010 and 2011 OEM 12v should be changed at the first sign of any electrical issue.
    That ensures all electronics are at peak running voltages.
    It brings very good peace of mind when you change it.
    Now you can move on to the real issue, if it still exist.
    That many years is good use for that little battery.
    I ran into the Yellow Triangle once and I also had the traction control come on while driving for no reason.
    I can not say it was the weak battery but I can now eliminate that part, if it happens again.
    102k on my 2011.
    my2cents.
    #12 rrg, Dec 17, 2016
  13. Mendel Leisk
    40,262
    I think cops and ambulances get their batteries changed every 2 years? Just like an oil change.
  14. Rebound
    3,970
    2,623
    Portland, OR
    Dude, that is not cool. You can't update the thread only if it doesn't work. You have to update if it does work, so others can learn. Also, bisco hands out gold stars whenever we're right, and I have almost enough for a four-slice toaster.
    Mendel already has a toaster that toasts a whole loaf at a time. I do not know what's next for him.
    #14 Rebound, Dec 18, 2016
  15. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    Whaaaaat are you kidding?? A toaster!
    I been gone too long.
  16. fuzzy1
    10,332
    The internal voltage measurement is for Gen2, model years 2004-2009.
    Your Gen3 doesn't have it, so you must bring your own voltmeter. These are available as ordinary hand-held meters, or built in to various other devices (e.g. Scangauge and other engine monitors), or even as simple cigarette-lighter plug-ins.
  17. bisco
    50,830
    i don't even have a toaster. have to eat cold bagels.:(
    but seriously, o/p, is this 'mechanic' at a dealership?
