Prius barely turns on, all problem lights light up, sounds like its accelerating then it turns off
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by chitgroza, Sep 29, 2023.
  1. chitgroza
    chitgroza New Member
    colorado
    So the story goes I was out at night and left the cars AC running while I was in there, suddenly it turns off and does't turn back on. I assumed I needed a jumpstart so in the morning we kept attempting to do it and it just wasn't cutting it. found out the fusible link seemed to have melted down the middle so we got that replaced and done. it helped a little, we managed to turn it on for longer than a second, it would run but the engine sounds like it's accelerating and once it reaches some threshold the car would shake, the screen would just say problem and then turn itself off. We replaced the 12V battery with a brand new one. didn't do the trick neither. cleaned out the hybrid battery and replaced the bad ones. Nothing. checked every fuse, they're all fine. The car seems to only be able to turn itself on when the key is in the ignition and with a scan from my obd scanner it said the only problem was the actuator? We cleaned it, then replaced it with a good one, yet it still pops up saying it's the problem. Our final thoughts were it must be the cars computer because physically everything else seems fine. We replaced the ECU today. and the same problems persist. PLEASE help I don't have good luck with cars and I don't want to have to lose another.
  2. JC91006
    16,632
    8,492
    Have you tried getting professional help? The amount of time and money you've spent guessing at this, it's a really expensive way to fix a car.
    I would make sure you have a nice clean throttle body and then make sure there is fuel getting to it (put a few gallons into your gas tank)
    50,803
    try scanning with tech stream
  4. chitgroza
    colorado
    Oh yeah I got a really cheap actuator, and a free battery from warranty. But you're totally right, my next step was to get it towed for free and checked out by the dealership just to diagnose it. And that is what we cleaned, then we replaced it with our other prius' throttle body (which works fine) and it continued to pop up as a problem on our bluedriver scanner. Thanks for helping so fast btw I thought I'd have to wait days for a response
  5. chitgroza
    colorado
    Is this a different app? or scanner? and would I have to buy it?
  6. JC91006
    16,632
    8,492
    Did you also clean the MAF sensor while you removed the throttle body?
  7. SFO
    SFO Senior Member
    5,302
    4,244
    Northern California
    Welcome to PriusChat!!
    I don't believe that app/adapter is toyota hybrid compatible, but maybe it is?
    Yes, techstream is the dealer technician diagnostic software that runs on a windows device (or you can emulate).
    If the tech curve is too much (search is your friend), find a compatible device in this thread : Gen2 OBD2 app review | PriusChat
    FYI : you're moderated until you've posted 5 times.
  8. chitgroza
    colorado
    No I have not, will get back on that.
  9. chitgroza
    colorado
    thank you
  10. SFO
    SFO Senior Member
    5,302
    4,244
    Northern California
    Did your scanner offer any OBD2 codes that you could post in this thread, without knowing the codes its mostly a guessing game.
    Free tows are great, and does the dealership offers free diagnostics (some have), if not then it might help to have an adapter that allows you the ability to run techstream. If you don't have access to a laptop or tablet with a usb port, then just read this post for other options : Gen2 OBD2 app review | Page 2 | PriusChat
    If you do have a laptop/pad with usb, buy a miniVCI clone or openport clone for $25. You can also spend more on higher quality adapters.
    This link can explain the difference : https://blog.obdii365.com/2022/07/13/mini-vci-vs-openport-for-toyota-techstream/
    If you end up going with the miniVCI cable, then read : https://blog.obdii365.com/2022/10/16/toyota-techstream-mini-vci-v1-4-1-vs-v2-0-4/
    If you end up going with the openport clone, then read : https://blog.obdii365.com/2022/03/23/how-to-choose-the-right-clone-tactrix-openport-2-0-j2534/
  11. chitgroza
    colorado
    The toyota dealership said it would be 200$ for a diagnosis. Are your options gonna read the same thing theirs will? and I do have a computer are you recommending the miniVCI over all of those?
