PRIUS C regen-braking-regeneration explanation- B mode
Discussion in 'Prius c Technical Discussion' started by ggtronic, Dec 5, 2012.
  1. ggtronic
    ggtronic SMART choice
    Montreal , Canada
    trying to find the max regeneration scenario
    for city driving... thanks for all above answers
    that help me write this intro guide...
    Summary :
    Excellent fact here :
    Questions about the Prius Braking System
    --Brake action seems to involve friction breaking immediatly ?
    qbee42 say no... it only prepare to...
    --regeneration stage to thermal braking is seemless !
    the best clue to regen efficiency is the regen bar graph menu
    (eco score menu)
    --braking force is harder than i thought to achieve best
    regen efficiency ! and speed dependant as mention by qbee42
    --you wont have stopping efficiency result unless you do
    a full stop (ok i admit my stop are never complete :( and
    that`s why i didnt get result )
    Transmission B mode ask engine compression on higher speed
    wich is not efficient
    i would still like to activate full regen on demand with a button...
    Here is the AMP values while driving (using scangauge Xgauge):
    Batt Pack Current Val : 07E22198 02EA85610698 3010 0001000AF334 : bIB : Amperes
    Max elec. drive current on this test : 98 AMP
    Max regen current on this test : 96 AMP
    any other clue on PRIUS C regen sequence ?
    thanks
  2. Ryephile
    Ryephile The Technophile
    418
    151
    24
    Metro Detroit
    Use either Eco Score or Eco Savings screen to instantly view how much regen you are achieving. Initial brake pedal application is 100% regeneration, and if you push harder it will also use the friction brakes. It is of course speed dependent, per the torque curve of the regeneration motor.
    Have you read your owners manual yet? Please do! It contains actual information and isn't some sort of compromise to your masculinity.
    "B" mode on the shifter is pretty much useless unless you specifically need more ICE braking, fuel economy be damned.
  3. rwn
    rwn Junior Member
    Bend
    Just a note on the B mode. If your battery is full (or even if it's not) when you go into B mode, and your going down say, a mountain pass, it's very functional. When you coast in B mode, the car uses engine braking as much as possible, so you can control your speed without using the friction brakes. Really cool feature IMO.
  4. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Pressing the brake pedal does not automatically cause friction braking. It does cause the brakes to prepare for braking, but doesn't apply pressure unless one of the following conditions is met:
    1) The amount of braking requested exceeds the capacity of regen. The total capacity of regenerative braking is limited by the size of MG2, the capacity of the battery and charging system, and the ability of MG1 to burn excess charge by spinning the ICE as an air pump. B mode is more aggressive about burning charge through MG1/ICE spinning.
    2) Panic stop. If you quickly mash the brakes, the braking ECU assumes a panic stop situation and employs "brake assist", where the system immediately goes to high level friction braking. Essentially it applies the brakes faster than the driver.
    3) Loss of traction. When traction is lost on either front wheel during braking, the braking ECU drops regeneration and switches to four wheel ABS friction braking. This is what causes the short loss-of-braking or surge sensation that Prius drivers sometimes experience when braking over bumps.
    4) Failure. Several failure modes cause the braking system to fall back on friction braking.
    So if you want maximum regeneration during braking, brake hard enough to fully utilize the regenerative system without forcing engine braking or friction braking. You will need additional instrumentation to do it with certainty, but that is really overkill for ordinary driving.
    Tom
    RocMills and JimboPalmer like this.
  6. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    I think qbee42 has probably explained this better, but any time you are within the blue regen portion of the HSI and not in one of the exceptional cases that qbee42 described, then you will be using regen brakes. There is one additional exception which is at very low speeds the regen braking is ineffective and only friction brakes are used.
    Outside of those cases, it is only when you push the pedal far enough to cause you to hit the bottom of the HSI that friction braking kicks in.
    Ha... I'm a nerd and this reminds me that we see the world differently. In nerd world, failure to read the manual is compromising your masculinity. I'd read the whole US manual online before I went in to pick up my car here. I was teaching the dealer stuff when he foolishly tried to give me a walk-through. :rolleyes:
    I have also been known to read at least part of the manuals of hire cars I have driven, but I acknowledge this as overkill.
    gsmckee, RocMills and ftl like this.
  7. ggtronic
    Montreal , Canada
    Thanks all !
    Ryephil: i'm guilty... i hate to read :giggle: ... i will try
    Jimbo : thanks for the link...
    Qbee42: best technical answer yet... thanks
    So it seems that breaking sequence is so smooth that regen/friction transition
    is hard to see ? or , as i think , they both start at the main time and change depending
    on pedal strengh (n)
    i'l try these Xgauge monitoring while braking and give result...
    HV battery charge control : 07E22198 02EA85610698 4808 00050001FD80 : bcc : kW
    HV battery charge control : 07E22198 02EA85610698 4808 1A3103E8FCA6 : bcc : HP
    edit : bIB work ! engine regen seems to provide 30amp on city idle & max braking
    regen reach 70amp in my neiberhood test... more test & video example to come
  8. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    Early 2010 Prius had a software fix as the braking transition was not seamless enough, but mostly you can't tell.
  9. ggtronic
    Montreal , Canada
    updated first post with this video about traction & regen amp.
  10. priusCpilot
    priusCpilot Active Member
    663
    210
    LA
    The slower the regen the more you capture as well? That's when I get my best stop scores anyway.
  11. Rob.au
    960
    441
    Sydney, Australia
    i-Tech
    I wouldn't say so. The trick to maximum score on your stop is to have two elements - 1. regen braking only until the friction brakes kick in as you come to a halt and 2. A nice consistent braking run - essentially getting just the right amount of pedal pressure that takes you from cruise speed to stopped in the right place, without needing to make any big adjustments on the way. This is difficult to achieve on shorter stopping runs.
  12. ggtronic
    Montreal , Canada
    priusCpilot: slower press at high speed... i agree , but at lower speed
    it seems we need more pressure to keep the max regen performance
    as mention by Rob.au
    really good info here :
  13. qbee42
    18,058
    3,076
    Northern Michigan
    It's all about power. At high speed it doesn't take much braking effort to exceed the capacity of the regenerative system. At lower speeds you need more braking force to develop the same amount of power.
    Short physics lesson: Power equals work per unit time. Work equals force times distance. Higher speed means more distance for the same time, so more power for the same force.
    Tom
  14. Rob.au
    960
    441
    Sydney, Australia
    i-Tech
    Worth noting that this information predates the HSI - the graph which in the C appears on the ECO Score display, as I discussed in an earlier post in this thread. The HSI means everyone has the information they need to keep to regen braking. It is true that as you slow down you will be able to press a little further down on the pedal without causing the HSI to bottom out, but this doesn't become significant until near the end of your stopping run (it seems to be an exponential relationship) and if you are focussing on the "stopping score" for some reason, the car seems to generally not like you making use of this and seems to prefer a steady stop (though IMO it makes no difference).
    On reflection, it might be possible that the programming logic of that score feels that if you are braking harder - even on regen brakes - there's an implication that you came off the accelerator later than you should have, which cerainly would be in keeping with the "Drive Without Brakes" school of thought - I just find that a hardline interpretation of DWB is impractical most of the time in the city.
