Prius C TPMS
Discussion in 'Prius c Technical Discussion' started by Hans Unrat, Jan 20, 2024.
  1. Hans Unrat
    Hans Unrat Junior Member
    30
    Just FYI, the TPMS light in my wife’s 2012 Prius C came on during a short trip, she took it to a garage on the way and had all pressures checked (which were OK since I had checked the pressures in all tires a few days before). I couldn't reset the light with the car's reset button, but I have a Carista app and subscription which found a sensor fault and reset the light. It has not come back on after several days of driving.
  2. HiC
    HiC Junior Member
    23
    16
    Northern, MN
    2014 Prius c
    Will Carista app allow you to register new sensor IDs on a Prius C? I tried Techstream, but the Prius C is the only Toyota I can’t get it to work with.
  3. Hans Unrat
    30
    Hello and sorry for missing your reply, the light would eventually come back on, and would again after resetting the system after a couple of miles. The Carista app includes a screen which allows the user to manually enter the ID of a replacement sensor, I ordered a new sensor and will report on whether registering the sensor is possible after installing it!
  4. Hans Unrat
    30
    It's been a while, but Saturday I was finally able to replace the sensor. I programmed it with the Carista app just by changing the sensor code (listed on the sensor body). It appears the sensor activates once the car is in motion.
