prius c wiring
Discussion in 'Prius c Accessories and Modifications' started by xerox6135, Jun 13, 2013.
  1. xerox6135
    xerox6135 Member
    170
    93
    michigan
    Are there any un used 12 volt wires under the hood of a Prius c that I could tap for the fog light relay just going to use the parking lights to trip the relay on
  2. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    you can actually just go to the fuse box (drivers side under the hood) and run a positive wire from the heavy gauge wire that is there. hard to explain but once you look at it, you should understand.
  3. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    I believe it's the big white one... but I may be getting it confused w/ the 2013... if there is not thick white one, look for a thick read one.
  4. xerox6135
    xerox6135 Member
    170
    93
    michigan
    Thanks guys. I ended up using a fuse tap in the fuse box and the trigger wire from parking lights. The fuse I tap is only hot when keys are on so I can still use my parking lights because I didn't install the switch inside the car
  5. Mo G
    Mo G Member
    317
    98
    Dallas,Tx
    So when ever you turn your lights on, fogs will always be on? Since the parking lights do not turn off when head lights are on.
  6. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    I would love for my Fogs to be on with both regular headlights and the brights. I used a jumper on my Saturn, but haven't researched it yet on the C. Has anyone done this one the regular Prius?
  7. kingnba6
    1,018
    242
    NY
    yup you are correct. so the fogs will be on with the side marker lights and also on with the low and high beams. but they will turn off when the switch is in the drl or off position. this way is beneficial because you dont need to run any wires into the car and can install the fogs and run wires all under the hood.
  8. Mo G
    Mo G Member
    317
    98
    Dallas,Tx
    Ah, ok. But at times, wont that be to much foreground light? That will harm distance vision. Might want to look into wiring a switch. But if you are okay with it.
