PRIUS calculation of MPG
Discussion in 'Gen 2 Prius Technical Discussion' started by tjs4689, Aug 12, 2006.
  1. tjs4689
    tjs4689 Junior Member
    Pafici Northwest
    How does the PRIUS calculate MPG and to what level of precision?
    For Example does PRIUS calculation 4 to the left and 4 to the right (1234.4321) an only Display Two to the left and one to the right (99.9)? Or is it using something else?
    If true then the user will be forced to the more accurate calculation outside of the PRIUS system as they would never see any better than 99.9 MPG.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    <div class='quotetop'>QUOTE(Timothy J. Suhr @ Aug 12 2006, 09:40 AM) [snapback]302085[/snapback]</div>
    The computer uses more digits in its internal calculation.
    Tom
  3. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    The computer does use more calculations, but most users have found that those are usually off by a few MPG, when compared to hand calculations (taking the number of miles divided by the amount of gas you put in at the end of those miles). While some of this undoubtedly has to do with the bladder system making refills so unreliable, people have found that, over several years their calculations are, on average still a few MPG different than the car's, which pretty much indicates that the car's calculations are ever so slightly off. (meaning that, comparing the car's calculations with total miles to arrive at gallons, you'd be either over or under by more than 10 gallons)
  4. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    My MPG is 1.6MPG optimistic over a 63K lifetime.
