Prius Display Screen - Quality??
Discussion in 'Gen 2 Prius Main Forum' started by glory, Nov 11, 2005.
  1. glory
    glory New Member
    Los Angeles
    I have test driven the 2005 Prius and was not really excited about the quality of the display screen .
    I was wondering if anyone has seen the 2006 display screen. Is it any different, and have they improved the quality at all??
    Thanks
  2. Maytrix
    Maytrix Member
    742
    Marlborough, Mass
    :blink: What didn't you like?
    It's a display screen for giving the drive info, not a High Def TV. Heck, it's not even a regular TV. For what it displays, I think it's perfectly fine.
    I'll also add - it probably could be a better display, but since it is standard in all packages, I'm sure they wanted to keep costs down.
  3. Technogeek
    Technogeek New Member
    142
    Seattle, WA
    You should see the screen in the 2006 Lexus IS250/IS350. Visit your local Lexus dealer and check out the screen. It has 32K colors and higher resolution. From everything that has been reported about the 2006 Prius Navigation, the 2006 Prius will be getting this screen. Here's a picture of the Lexus screen:
    http://www.worldcarfans.com/news.cfm/newsi.../1/lexus/1.html
  4. djasonw
    djasonw Active Member
    958
    119
    Coconut Creek, FL
    Okay... Now I am REALLY envious. That is GORGEOUS!! Gotta hand it to Toyota. They really know how to make a car.
  5. acousticbiker
    acousticbiker New Member
    119
    Evergreen, CO
    Yeah, that screen is really impressive. It appears to be a 16 x 9 aspect ratio. From what I remember of the 2006 pics, the MFD still appears to be standard 4 x 3. I wonder if this is an indication that the Prius will NOT have the same nav system or screen as the Lexus shown above.
  6. john1701a
    john1701a Prius Guru
    12,793
    5,275
    57
    The aspect ratio (shape) is the same.
    The Lexus does have a higher resolution and a deeper color palette.
    That's to be expected. After all, Prius got some goodies before even any Lexus in the past.
    I do find it absolutely fascinating that quality of the Multi-Display has become a purchase factor. Some vehicles still have tiny low-resolution screens that aren't even touch-sensitive. And get this, some don't even have a Multi-Display!
  7. Tideland Prius
    16,402
    Some goodies? like what? Bluetooth?
  8. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    Well, there are not too many pictures floating around of the 2006, but if you look at the screen in this picture.... http://hybridcars.about.com/od/photogaller...iusphotos_7.htm
    It sure appears to be the 16 X 9 widescreen view... the picture is not too closeup, but maybe it is the updated one?
    Here is another http://img298.imageshack.us/my.php?image=06priusdash3di.jpg
    And maybe thebest one yet: http://www.forbesautos.com/gallery/2006/to...slide=12&play=t
    Make sure you play with the zoom function on this one and you can really pull in the screen nicely!
    Even toyotas site looks like 16 X 9? http://www.toyota.com/prius/interior.html
    Is it updated to reflect the 2006?
    Here is the 2005 http://cars.about.com/od/toyota/fr/05_toyo_prius.htm
    I dont see "any" that appear as the 4 X 3 aspect?
    Are you sure that is the difference that determines whether the screen is updated or not?
  9. prius2006rocks
    prius2006rocks New Member
    159
    CA - Central Valley
    Who knows really. But even if it were the same aspect (4 X 3), can the display still be updated for better quality? Or is that the 16 X 9? Im no expert.
  10. john1701a
    12,793
    5,275
    57
    Even if it could display both the increased colors and the resolution, it probably doesn't have the Processor or RAM to handle the animation... just like PCs in ages past.
    As for aspect, I think I'm an expert... having taken so many Multi-Display photos. The aspect is: 16 x 9.7
  11. MBranstein
    MBranstein New Member
    288
    Prospect, KY
    After several measurements of high-res 2006 photos in photoshop it looks like the MFD is 16 x 9.4
  12. habel
    habel New Member
    230
    Oslo, Norway
    Perhaps this info on the 2006 gives a hint to screen quality in the new car?
    "The optional voice-activated DVD GPS (Global Positioning System) Navigation system is the most sophisticated yet. It offers increased map quality, over 32,000 colors..."
    Henrik
  13. MBranstein
    288
    Prospect, KY
    In some other threads, we have decided that the MFD is now higher-quality and will look very similar to (if not the same as) the Lexus model.
  14. windstrings
    6,280
    378
    Central Texas
    Groovy baby!.. I hope your right.... its admittedly true they have improved the voice features.. the other may be in with the package also?
  15. skijapan
    skijapan Junior Member
    87
    Hokkaido, Japan
    I had an av input installed so that I can plug my iriver into my Prius. This input also allows for a portable dvd player to be viewed on the mfd. I also have a tv tuner in my car as part of the nav system. I must say that the picture quality is pretty 'gol 'dang 'darn good for the "control panel" of a car. Clear, crisp, and detailed.
    And fingerprints wipe off easily...!
  16. cowboy
    cowboy New Member
    85
    "Mountain Empire" region of southeastern
    That sounds pretty cool alright. Although I hope you don't actually watch tv while you're driving. If you do, then I'm glad you're over there instead of on the roads here! :lol:
  17. athanasios
    athanasios New Member
    24
    Switzerland
    Do you happen to have a link/name of the AV interface you had installed?
    Thanks,
    Alex
  18. glory
    glory New Member
    Los Angeles
  19. RonM
    RonM New Member
    72
    Agreed that a screen with greater resolution, and more colors, will require more CPU horsepower. We know from the Toyota press release that the 2006 Nav unit will offer "...increased map quality, over 32,000 colors, an ETA (Estimated Time of Arrival) display, a route tracer function, voice recognition street address search functions that allow you to enter a destination while driving, and can now be set to operate in English, French, or Spanish languages." All of that will require more CPU MIPs.
    From the looks of the following press release (http://www.denso.co.jp/en/newsreleases/050912-01.html), Denso has developed just that. It even has a 3D graphics capability in it. Why? Because the Japanese Nav market is now evolving to 3D maps with buildings, etc. to help the driver orient themselves even better in the city. That apparently might happen here eventually, albeit somewhat slower (yikes, I just read about this online 2 days ago, and I can't find the link -- to many related topics on Google).
    Given that the feature set improvement of the Lexus Nav unit that has been highlighted, and the corresponding new features in the 2006 Prius, they are likely the same. Of course, we won't know for some time until the 2006 cars get here, and some info shows up on them at the techinfo.toyota.com site. [Has anyone tried to access that in the past few days? It has been real flaky -- looks like they are doing an upgrade on it tonight...]
    I agree that it is interesting that the Nav unit technology (or even the generic MFD display resolution) might be a selling point. But, this car does attract people for the very reason that its a vehicle for Toyota to show off some of their higher tech features (among other reasons).
    Here's an interesting question... If we know from the 2006 press release that the '06 nav units have higher res maps with more color, I wonder if that same screen is being used for the MFD for non-nav Prii? Most likely, it will be if the cost is reasonable.
  20. aaf709
    3,862
    2022 Prius Prime
    Are you planning to turn the Prius into a movie theatre? I'm not impressed by pretty pictures if the content is bad. I mean, if the map steers you wrong is it important that it looked good when it did? That may not happen, but will the map show anything like a 3-D view?
    Sorry, but it just seems to me to be an example of Creeping Meatballism.
