Prius "force field"?
Discussion in 'Gen 2 Prius Technical Discussion' started by Philmo, May 12, 2008.
  1. Philmo
    Philmo Junior Member
    47
    This may be a longshot, but I'm wondering if the Prius puts out any kind of electrical field when running -- or otherwise. I ask because I had several Hi8 videotapes stored in a box that just happened to be about 2 feet from the front, left side of the Pruis where I park in our garage. When I went to review some of the tapes they were blank, whereas a separate tape that had been stored in another location was fine.
    Foolishness? Wishful thinking? Other?
    Thanks...
  2. apriusfan
    apriusfan New Member
    6,050
    205
    S.F. Bay Area
    I really doubt that the EMR that the Prius generates is sufficient to erase a video tape. If you want to confirm it was or was not the Prius, try repeating the erasure with another tape. If it is erased, there may be a failure of some electrical part in the Prius. If not, then something else caused the erasure. Again, I really doubt the Prius is the source of the erasure.
  3. bwilson4web
    15,939
    My experience has been that degaussing takes a pretty intense magnetic field. However, moisture, temperature and age are pretty destructive of magnetic tapes. Sorry for your loss but magnetic tape were never really considered an archive medium.
  4. Evilshin
    Evilshin Member
    119
    The magnetic field generated by the two synchronous motors of the Prius is unlikely to do much to your tapes... but if you are worried, you can bring compass and see if it goes nuts... If that detects nothing, you can try a magnetic field detector... okay, maybe not... ;)
  5. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    You don't say where you are, so there is little I can tell you other than the tiny field the Prius emits is not going to erase anything!
    Think about it people! If the Prius emitted a large EM field that would be wasted energy! The motor generators are pretty much fully shielded to capture any field energy generated. The only "emitted fields" are from the cables, mostly from the battery to the front of the car. The field emitted by that cable is much lower than the earths magnetic field, based on what other "concerned people" have measured.
    If your garage is very dry, that will evaporate the glue that holds the magnetic powder to the tape. The powder then falls off the tape. Heat will accelerate this process.
    If you want to use tape for archival purposes you have to store the tapes in a humidity and temperature controlled room. NOT a garage!
  6. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    If it emits a field, it's not nearly strong enough to interfere with the really loud bass of the guy in the car next to me.
  7. bwilson4web
    15,939
    UUhhhhh!!!! Another urban legend!
    We can start the rumor that a Prius will erase the magnetic strips on ATM and credit cards! That is why they so often fail during a retail purchase. Only by putting them in a thin plastic bags is the evil Prius field neutralized.
  8. Qlara
    Qlara New Member
    488
    NO way the Prius will carry that much EMF, even with the Perm Magnets in both MG motors. Maybe the residue heat from your Prius ICE can affect the tapes over time too.
    But yes, do what Evilshin has suggested by confirming it with a compass....this myth has to be busted.
  9. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i have a meter and my friend has a meter. we tested the car all over. normal devices in your house such as the radio and microwave put off higher fields... cell phone too.
  10. dandeman
    dandeman Junior Member
    61
    Chapel Hill, NC
    Not a chance... My personal experience with Hi8 metallic video tapes is that it takes an extremely high magnetic field to erase.. I have a bulk eraser I use routinely on VHS tapes (wipes them totally clean) and that same bulk eraser won't begin to erase a Hi8 video tape.. It will put a little noise on it..
    regarding magnetic fields from the prius, high efficiency motors (the prius motors are extremely highly efficient per Oak Ridge National Labs published papers) don't get there and still leak large magnetic fields.. Large magnetic loss would occur only in a very, very poor motor design.
    Managing magnetic loss is a fundamental element in the design of any transformer, electric motor or any magnetic device that is attempting any reasonable degree of efficiency.
  11. richard schumacher
    7,664
    1,042
    United States
    Do you see keyrings and tools flying through the air and sticking to the Prius? No. Heat killed your tapes. Not all tapes were created equal.
  12. bwilson4web
    15,939
    What!!!
    I might not have to buy another Acme Inc. magnet (see Avatar?)
  13. richard schumacher
    7,664
    1,042
    United States
    So *that's* how them hypermilers do it!
  14. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Doc Willie's will deflect a MK IV photon torpedo.
