prius fuel gauge issues
Discussion in 'Gen 2 Prius Technical Discussion' started by statultra, Mar 24, 2008.
  1. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    my 05 prius fuel gauge has some issues, i went to fill up at BJ's the other day , ( 2 bars on the gauge ) put the gas nozzle into the filler hole and bang it wont fill up, so i took it out and tried again, same result.
    so i waited and tried again and now its starting to fill up, and then it clicked, at 15 dollars! i thought thats just craziness since gas here is 3.26 a gallon, it usually takes 25 dollars to fill up with two bars, so i kept trying to fill it up
    pulling out the nozzle and kept trying, and yet it wouldnt take more than the 4.whatever gallons i put in, surprised, i drove it today, and it went down two bars already.
    why is this happening?
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Maybe a problem with the pump nozzle. Did you try another station?
  3. statultra
    798
    31
    Edison,NJ
    2001 Prius
    it went down 4 bars today, and i only did 76 miles on the tank
  4. firepa63
    1,761
    208
    There was a TSB for the gas gauge and filler neck on the 2004s that had to do with erroneous readings with the fuel gauge. Perhaps your 05 falls into that category. Check with your dealer. Unfortunately I don't have a copy of the TSB. Mine was done in January 05 and it involved replacing the whole instrument panel, gas gauge, speedometer/odometer, etc.
  5. Patrick Wong
    18,200
    6,491
    This TSB applies to certain 2004 models only.
  6. bear15
    bear15 Member
    168
    35
    Suburban Chicago
    We had a similar problem. Time to take it to the dealer and have it checked.
  7. Evilshin
    Evilshin Member
    119
    My 05 had that problem... It also gives the low fuel warning when there is about 10 litres of gas in the tank...
    I have resorted to using the fuel usage gauge to calculate how much fuel is required.
    Most gas stations will has issues with the fill up triggering early. Twice I ended up over filling and spilling some gas. So of this issue might have to do with the Prius expandable fuel tank that was designed to minimize evaporation of fuel. But may prematurely trigger the pressure sensor in the pump.
    I would fill up once with a slow fill rate until the can see fuel overflowing... (Do it slowly... don't waste gas). Then I would calculate fuel needed to fill...
    My problem has since been minimized... do not know why though....
