prius not working
Discussion in 'Gen 2 Prius Technical Discussion' started by SmR111, Aug 11, 2010.
  1. SmR111
    SmR111 New Member
    Bangladesh
    hello guys i am actually new in this website.
    im having a problem with my prius and i wud be glad if u people can help me out.
    the problem is, i was listening to music in my prius 05 setting the equalizer. After i got my work done, i pulled the key and closed the door. when i was pressing the lock button in my remote key, it wasnt working. Then i went inside my car and even the locks and other things werent working.. nothing was working eventually.. can anyone giv a solution to my problem? :(
  2. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    Sounds like a dead 12v battery. Assuming its the original one, its definitely time for a replacement.
  3. SmR111
    SmR111 New Member
    Bangladesh
    well ive changed the battery few months ago as it was giving some problems.. in few months its time for replacement? =/
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I am assuming you don't have Smart Key. Can you lock it with a mechanical key?
    When you press the Lock button on the remote FOB, does the red light come on? If not, you need to replace the Lithium thumb size battery in the FOB.
  5. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    If everything in the car is not working, check the voltage at the battery to see if you ran it down. If it has over 12v, look at the main fuse.
  6. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    It may not be time for a new battery, but I'll bet you ran yours down while listing to music. It's a small battery and doesn't take much to run it down. Try charging the battery and see if that solves the problem. In the future, leave the car in READY mode when listening to the audio.
  7. Patrick Wong
    18,200
    6,491
    Or at least, do not leave the car IG-ON (where the dashboard warning lights are on.) The power drain on the 12V battery is quite high when the car is in that mode.
    Assuming that the 12V battery is in good condition, then the car can be left ACC-ON (where the dashboard warning lights are not on and the stereo can be played) for a reasonable period of time. The car will automatically switch from ACC-ON to IG-OFF after around one hour has elapsed.
  8. SmR111
    SmR111 New Member
    Bangladesh
    guys it was actually a stupid matter. i opened prius's boot and opened the battery place. then i just tightened up the things and the car automatically started everything. it just got loose. but thanks a lot for your suggestions and i appreciate it :)
    OT: my prius's navigation system is in japanese language. is there any way i can transform that to english?
