Prius Oil Filter Cartridge
Discussion in 'Gen 3 Prius Technical Discussion' started by 72fordgts, Sep 6, 2011.
  1. 72fordgts
    72fordgts Member
    132
    35
    ON, Canada
    Does anyone know if the oil filter cartridge on a 2010 prius can be removed with a standard style strap filter wrench? Or does it need to be one of those cup style wrenchs used with a socket wrench?
    Thanks
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    There is a good chance that your cap is on there so tight that it would not come off with the strap. If it was properly tighten, probably yes. For whatever reason the dealerships seem to be really cranking down on those puppies. Probably a misprint in the service manuals.
    However, you would have to find a pretty small strap wrench for that size (64mm).
  3. rebenson
    rebenson Member
    364
    43
    Suburb of Chicago
    I never had much luck with the straps... I was not happy when I got the 2009 corolla and discovered it had the cartridge filter. I'm going to get a wrench that will do both corolla and Prius (supposed to be same size). Auto store had some really inexpensive oil filter wrenches for under $7 - $10.
  4. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    A strap wrench won't work. The filter cover is too smooth, and you'll be highly challenged to generate 17 ft-lbs of torque needed. The correct end cap wrench is either available from a dealer or on-line. Go to the Maintenance section of this forum & search for oil change threads.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    +1 Agree !
    I tried a strap wrench the first time and could never get enough grip. What little grip I could get I could not get enough leverage to get any torque on it.
    Get the correct 64mm cap wrench. I had a 65mm and it would slip off when I tried to apply torque. With the correct cap wrench and socket wrench it still took some leverage to finally break it loose.
    I do not understand why the dealer service departments have to torque these down so tight :mad:
  6. 72fordgts
    72fordgts Member
    132
    35
    ON, Canada
    Hmmm...that's not good. I just called every parts place in town and they only have 65mm wrenches. Toyota says they won't sell their wrench to me for whatever reason. I may have to order one online, but I wanted to change the oil tonight. Who knew a simple oil change would become so complicated.
  7. Dark_matter_doesn't
    691
    151
    Seattle, WA
    I sympathize, there's always a quirky aspect to a new car's maintenance. The oil filter cover wrench is one of the very few special tool issues for general maintenance on a Prius. I had a heck of a time finding a 23 mm socket for the wheel lugs recently. At least the real oil filter tool is metal and will last a very long time.
  8. 72fordgts
    72fordgts Member
    132
    35
    ON, Canada
    Where's the best place to get one of these wrenchs? I have seen several online? Does it have to ne the Assenmacher Toy640 or will a std stamped steel 64mm work fine?
    Thanks for the heads up on the 23 mm wheel lugs too!
  9. cmrj
    cmrj Junior Member
    34
    Boise, Idaho
    I bought mine at the Toyota dealer. It was in the accessory area. They are also available on Amazon. Most of the stamped steel wrenches don't seem to work very well. An additional benefit for me is that the Toy640 also fits the filter housing on my 09 RAV4.
  10. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    You should have saw me when I did my first (Saturday) change. I drained the pan figuring my Camry cap wrench would work. It didn't. So I ran to the local parts places twice... no go. So I called the dealer... yup they had one but $40! Reluctantly I bought it and it turned out to be a Assenmacher for 3x the price. *!
  11. El Dobro
    El Dobro A Member
    7,071
    3,258
    Looks like I'm going to start a maintenance tool list now, before I need to do anything. :D
  12. cmrj
    cmrj Junior Member
    34
    Boise, Idaho
    Ouch. I was only charged about $20.
  13. 72fordgts
    72fordgts Member
    132
    35
    ON, Canada
    Well, I went into the Toyota dealer and dealt with a different person. They agreed to sell me the Toyota oil filter wrench, which I believe is a Toyota part (has Toyota/Lexus and a part #). It is a metal cup style wrench, nice quality, but VERY pricey of course. They agreed to sell it to me for $10 over cost, so for $45 CDN plus tax. Not cheap, but to get one off ebay with shipping would be pretty close to the same, and needed to change the oil today.
    I did also buy a parts store 65mm wrench to try it out. Good thing I got the Toyota wrench because the filter was on very tight. The 65mm wrench slipped. The Toyota wrench worked well, but even it jammed on due to the high torque required to remove the oil filter. Oil change was a breeze otherwise, and the car has a fresh fill of Mobil 0W20.
  14. Pecker
    Pecker Junior Member
    33
    Ohio
    There's one for sale on amazon. I think it's around $17.
    iPad ?
  15. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Bullocks on Toyota wanting not selling you the tool.:cool:
    Glad you were able to get the SST and change your oil. It was allot cheaper up there in Canada then it was in the islands.:)
  16. 72fordgts
    72fordgts Member
    132
    35
    ON, Canada
    Yeah, that's the one I got, same part number. I guess $45 is too bad then.
  17. Mendel Leisk
    40,236
    The Repair Manual says 18 ft/lb, it's fairly clear, in a couple of places.
    I've been using a (Honda) 14 face socket with 64.5mm inside face-to-face, so I guess a quoted size of 64mm is what you need. Here's a few pics:
    With the socket on:
    Without:
  18. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    It makes a person wonder though... it seems like everyone that has done a change themselves (after a change by the dealer) has reported difficulty getting the cap off. Whereas when I do a change after I have torqued it prior, I have no problem getting it off. Perhaps they are trying to align with the tabs as opposed to torque tightening? Who knows. Perhaps I will ask the service tech next time I am in there... next year, ha. :)
  19. Mendel Leisk
    40,236
    Yeah, this car, I decided not to darken the service department's doorstep for oil changes.
    I initially purchased the oil filter socket in the pic for an '89 Honda Hurricane. It's got quite a heavy gauge sidewall, over 2mm, basically indestructable. I also picked up a larger diameter one for Accord. Then Honda's automotive division switched over to the smaller filter diameter. And Toyota's a perfect match. Maybe becoming a standard size?
    The oil filter socket, and a torque wrench, are good investments. And the oil pans, funnels, safety stands, jacks, ramps, socket wrenches, trim pry bars, and, and...
