Prius owners... watch out for the 3009 error code. It will cost you dearly.
Discussion in 'Generation 1 Prius Discussion' started by lndbrusr, Jul 20, 2009.
  1. lndbrusr
    lndbrusr New Member
    Howdy fellow prius owners. In March of 2009, I had a failure in the electric motor in my gen1 prius with less than 90k miles on it.
    My purpose in this thread is to make prius owners aware of this failure condition (although I see many references to 3009 error on the boards recently) and that it might cost YOU a considerable sum of money to fix it. This is applicable to both the gen1 and gen2 prius and it does not matter if the car has "by the book" maintenance and service or not (mine is "by the book").
    Below, in between the lines, is a copy of the body of a letter I sent to Toyota USA customer care in mid-April. I waited till now to post this to the boards as I wanted to see if Toyota had a response for me. As of today, I have yet to receive a response from Toyota customer care. I have taken the case numbers, etc. out of the body of the letter. ***The dealership, Toyota Sunnyvale, in my opinion, did a great job. They even tried to talk to Toyota customer care after I sent the letter as I had cc'd people at Toyota Sunnyvale on the letter.
    ______________________________________________________
    I own a 2001 Toyota Prius with just shy of 90,000 miles on it. It has been a great car and until now, the epitome of a Toyota; a quality, reliable product. I am writing this letter to share my recent service experience with this car and more importantly – to voice my current dissatisfaction with the Toyota service philosophy around the Prius product.
    Around March 15th, 2009, my Prius started making a weird humming noise. Some research at home uncovered references that at times, a weird humming noise and a “check engine light†indicated a failure of one of the two electric motors inside the transaxle. I did not have a “check engine light†at the time so I though that perhaps a wheel bearing had gone bad.
    On March 24th, I drove the Prius to Toyota Sunnyvale for them to diagnose the noise and also to perform the 90,000 mile major service. En route, the “check engine light†came on. The dealership called me later that day to tell inform me that the noise, and the code p3009 which was set, meant that indeed one of the electric motors inside the transaxle had failed. A case number XXXXXX was opened with Toyota and they verified the original diagnosis. Toyota Sunnyvale then tried to see if Toyota would help cover the cost of the repair. I was very pleased and appreciative of the steps the dealership took to try to get Toyota to help me out. It turns out that the dealership had no luck and gave me the final diagnosis and cost estimate to fix it. I was told that the repair procedure was to replace the entire transaxle (instead of just the bad electric motor) and that the parts price was roughly $3,725 and the labor roughly $1,430.
    I was flabbergasted at the price and a bit upset that I was told that I had to replace an entire transaxle due a failure in just one of its components. I called an independent repair shop here locally to ask them their opinion. This shop had also been one of the references I saw earlier describing this phenomenon and they confirmed that the procedure in these cases was to replace the entire transaxle.
    At this point, I called Toyota customer care myself and opened up ticket number (XXXXXX). This is when I learned that the electric motor was covered with the same warranty coverage as the transaxle, even though it is a part unique to the hybrid system! It amazed me that something which is obviously an integral part to electric /"hybrid" nature of the car, is not covered under the hybrid warranty. This design and this motor is clearly something unique to the “hybrid†technology for the car. I am further disappointed that Toyota does not have an alternative repair or replace procedure (and parts) for the electric motor failure. The only solution offered is to replace the entire transaxle. In other words, Toyota expects that a customer replace a perfectly good transaxle, except for the electric motor inside, when the electric motor dies. Your customer care representatives were helpful and courteous and tried to do what they could but in the end, told me that there was nothing Toyota could do.
    Toyota markets itself as a maker of quality, dependable cars. Much of your customer satisfaction and return business is based on this reputation for dependability. Common perception is that Toyota automobiles can thrive on basic maintenance and care. Thus, I find it hard to swallow, and out of the ordinary, that for a Toyota product, that I am forced to spend roughly one quarter of the car's original purchase price for a repair on a Toyota with just 90k miles on it.
    Ultimately, I had no other good option than to have the dealership repair the car. Additionally, I am now considering selling the car as I am leery of how much the next repair on the Prius could be. I have also discovered that the second generation (in America) Prius has the same design (electric motors are inside the transaxle) and the replace/repair procedure is the same and just as costly. I do not however, know if the hybrid warranty covers the electric motors in the second generation Prius. Many people will be unhappy if/when they have to go through what I have gone through!
    The Prius is not my first Toyota vehicle. I also have a 1982 FJ40 with just over 152,000 miles on it. I have not had any major issues with it (all stock and original). I have had nothing but a "usual" Toyota reliability experience with the FJ40. I really wish I could have said the same about the Prius....
    This has been an immensely disappointing and costly experience and I hope that this letter might get Toyota to change their stance on how to cover a failure of a hybrid specific part in a hybrid vehicle. If you have any questions or want to talk further about my experience, please feel free to contact me.
    ****Again, I just want to get the word out there that:
    -The prius can have this problem.
    -The hybrid unique part (the electric motor) is not covered by the hybrid warranty (it is covered by the drivetrain warranty) on a gen1 prius.
    -The repair procedure is to replace an entire "module" instead of just the bad part.
    -Replacing the "module" is extremely expensive in both parts and labor.
    -I did not have any luck getting Toyota to help or cover completely my repair.
    Happy Motoring!
    lndbrusr
  2. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    bad luck does happen from time to time, I had to spend roughly $3000 to replace the transmission on the wifes Beetle and that was after negotiating it down from $3800. I am curious though on if you had ever changed your transaxle fluid.
    You also should consider locating one at a junkyard.
  3. lndbrusr
    lndbrusr New Member
    the transmission fluid was changed at 60k per the service interval... I find that a 60k interval probably is not often enough and was going to ask the dealership to change it during my 90k until this happened. Also, I am not convinced that replacing fluid would have prevented the electric motor winding failure which is what really occured.
    Unfortunately, I did not have the time to scour the junkyards and with junkyards, often you get what you pay for...
    lndbrusr
  4. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Nine years of rock solid operation and volumes of saved gas. You need to own at least one lemon from a shady dealer to understand that your criticism is a little too strong. Toyota honored their commitments fully. It's certainly not what you desire, but Toyota has to draw the line somewhere. Keep in mind that every warranty extension adds to the price of the car. If the price of the car was $5000 more to provide the coverage you are talking about, could you have afforded the car? If it is that important to you now, why not buy expensive extended warranty coverage earlier? Or was that even an option?
    I also have a 2001 with 100,400 miles on it. Sooner or later the car is going to die. That is a fact. When it does, 1 mile from now or 200,000 miles from now, I will considered it one of the best cars I have every had. I bought it fully aware that the first production run of any car carries some extra risk and considered the tradeoffs. If what happened to you, happens to me, then I would be unhappy, but not at Toyota.
  5. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
    wellsaid......
  6. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi ind....
    This is a widely discussed issue in the 1st Generation Prius posts on Prius Chat already. Check out Bob Wilson's posts regarding transmission oil life - he recomends something like 34 K miles for changes, and wiping out all the stuff reachable with the pan removed on the first change.
    Not to far from you there is a place called Luscious Garage - check them out they may provide a cheaper route , if Toyota does not come through with some extra cash for the repair...
  7. lndbrusr
    lndbrusr New Member
    FL_Prius_Driver & Sandy--yes, Toyota is honoring the letter of their warranty contracts. I can not fault them for that. I do consider this one of those "grey areas" where a manufacturer can step up and make a customer for life or not...
    More importantly, the intent on this post is to let people know to start saving money for this potential problem. From my post:
    donee--The "independent repair shop" in the body of my letter is Art's Automotive in Berkeley--another highly regarded independent Bay Area repair shop.
    lndbrusr
  8. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    There is complete agreement that saving money for unexpected events is smart planning and your case is a good example. The more debatable aspect is that there is any "grey area".
    Specifically, let's reverse the situation. You sell a used car to a buyer. You are completely honest and state that you know of no problems, but the terms of the sale are "as is" for $4000 with agreement on both sides. Two weeks later, the buyer comes back with a major $3000 repair bill. Would you pay?
  9. lndbrusr
    lndbrusr New Member
    FL_Prius_Driver,
    Again, the purpose of this thread is to let prius owners know that they have a potentially costly repair possibly in front of them.
    You are certainly entitled to your opinion about my expectations/hopes being to high or not.
    -I personally believe that hybrid specific parts SHOULD be part of a hybrid warranty.
    -I personally believe that, for whatever reason Toyota chose, the repair procedure and supply chain for a busted electrical motor is to replace an entire, costly, transaxle might not be the least expensive option for the customer (although it might be the easiest for the manufacturer/dealership)!
    -I have owned many cars over my lifetime. This is the first time I have ever had to pay one quarter of the car's original sales value for a single repair. I have owned BMWs and if you had told me that one of my cars would have a repair cost of this caliber, I would have guessed it to be the BMW and not the Toyota!
    -I have had other manufacturers cover "grey area" work under warranty as a way to keep me a loyal, happy customer. I will admit though that those occurrences happened before the current economic downturn!
    lndbrusr
  10. dannyman
    dannyman New Member
    Northern California
    It should have been covered. And you should have fought harder. But, at this point you have expressed to them your dissatisfaction. However the car has been repaired, and now you are considering selling as a result. Toyota sells millions of cars and trucks. You solved your own problem and also getting rid of the problem (maybe), so why would Toyota want to help you.
    Thank you for getting the word out, I'm sure most of us dread the thought of having a similar situation. I read customer complaints at work and lines like these make the shred pile.
  11. Patrick Wong
    18,200
    6,490
    Yes, it is true that if your Prius has an unwarranted failure and you must rely upon dealer service, then you are looking at very big $$$$ repair costs. A potential alternative is to install salvage parts, although this approach is risky with respect to the transaxle since that is a well-known Classic weak point. Further, the transaxle is the most expensive part that is likely to fail.
    Now that you've spent $5K on repairing the car, it seems that you would do better to continue to drive it and get some value out of the money expended. If/when you have another significant failure, just have the car towed to the salvage yard and be done with it.
    Good luck.
  12. SageBrush
    SageBrush Senior Member
    11,627
    2,532
    Southwest Colorado
    Exactly
  13. lndbrusr
    lndbrusr New Member
    I am actually keeping the car for the time being. I don't know how much driving I will have to do to feel as though I got value out of that big repair bill though ;-)
    thanks,
    cj
  14. SageBrush
    11,627
    2,532
    Southwest Colorado
    Good for you, cj. Best to let reason win over after ranting :)
    I'm not an engineer, so take this with a grain of salt: when I look at the changes from Prius gen to gen, the motor winding seem to be one of the largest changes I see outside of simply new technologies. I imagine some of it has to do with cost savings, but I strongly suspect that Toyota has identified a weak link, and is working hard to improve it. The inverter is also a problem child -- relatively speaking.
    I liked your point about the transaxle design not being modular (and, requiring hours and hours of labor to replace.) I hope Toyota is listening.
  15. pdxrose
    pdxrose New Member
    175
    25
    Thanks for sharing. Confirms my previous auto operating style; purchase extended full warranty (0 deductable) at dealer cost (not retail = double). Keep the car until two month before warranty ends (this one is 7 years or 100,000 miles). Sell it private (warranty makes it easier and pays for itself by not having to trade)and run for the hills. I would rather spend $1,100 and be done for the next 7 years.
