Prius Prime – A/C Not Working, B1476 Code, Constant Sound Under Hatch
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Giedrius Cyras, Apr 17, 2025.
  1. Giedrius Cyras
    Giedrius Cyras Junior Member
    Lithuania
    2014 Prius+ MPV
    Active
    Hi everyone,
    I have a 2019–2020 Toyota Prius Prime (ZR-FXE) and I’m currently experiencing an issue with the air conditioning system.
    Symptoms:
    • Air conditioner doesn’t start at all. No cooling.
    • Freon is fully charged – verified by technician.
    • There is a constant electrical or humming sound coming from under the rear hatch area – even when the A/C is off.
    • The A/C compressor does not engage.
    Diagnostic Results:
    Ran a scan with a professional tool and got the following codes:
    • B1476 A/C Inverter Load System – Current
    • B1476 A/C Inverter Load System – History
    Other systems like hybrid control, HV battery, radar, etc., all show “Normal.”
    My Questions:
    1. Has anyone dealt with this B1476 code before?
    2. Could this be caused by a blown fuse or relay, and if so – where is the A/C inverter or compressor fuse located in the Prius Prime?
    3. Does anyone have a wiring diagram or fuse layout for the A/C system or compressor?
    4. What could be causing that constant sound under the hatch – is it related to the HV system or cooling inverter?
    Any advice or guidance would be hugely appreciated! I want to avoid replacing the A/C compressor or inverter without being sure.
    Thanks in advance!
  2. MAX2
    MAX2 Senior Member
    1,333
    415
    101
    Third planet from the Sun
    AIR CONDITIONING SYSTEM, Diagnostic DTC:B1476/76
    The operation of the compressor with motor assembly is stopped and this DTC is stored if the rotation load is too large or too small while the compressor with motor assembly is operating.
    Possible causes are refrigerant leaks, overcharged refrigerant, insufficient cooling due to a condenser fan circuit malfunction, or compressor lock.
