Prius Problem
Discussion in 'Gen 2 Prius Technical Discussion' started by viking16, Feb 16, 2007.
  1. viking16
    viking16 New Member
    Hey everyone we got our prius last year (2006 it's an 05). I have come to site and reading alot. But I got a problem with our prius and the dealer isn't helping.
    Here is the problem we run a security company and go about 100 miles a night (we got the prius with 13,000 miles and now it has 33,000 miles) well we have had the check engine light come on 3 times (in the first year). First was due to the thermostat on the radiator. They fixed that. Then a week later the light is back on. Now the dealer says it found an air bubble in the coolant. Sounds like someone didn't flush the coolant when they changed the thermostat. They fixed that. Well now the light came back on and we brought it in well after about a week with them having it and giving us the run around saying we don't know whats wrong with it and they claimed that the service tech from Toyota didn't know what was wrong either. Our service tech (guy who signed our toyota in to the shop), then told us that Toyota tech support didn't know either. Well we get it back about a week later and they tell us change the way you drive and there is no fix so just ignore the check engine light all Toyota vehicles do this. I asked him what if it is major. He told me well I don't know. So we got in writing to ignore the check engine light. He also told us all toyota's do this if they sit more then 30mins. We sit for maybe 30 - 40 mins to write our faxes for the customers.
    Have you guys and girls ever heard of a dealer saying ignore the check engine light and we are not going to fix the problem.
    Now don't get me wrong the Pruis is a great car we love it just Toyota doesn't fix it.
    Please help.
    Thanks
    Dennis
  2. nicoss
    nicoss New Member
    304
    Are you talking about the "Maintenance Required" orange light?
    If yes, it automatically comes on every 5000 miles and indicates that scheduled maintenance is needed.
    In any case, have you tried a different dealer?
  3. viking16
    viking16 New Member
    <div class='quotetop'>QUOTE(nicos @ Feb 16 2007, 04:01 AM) [snapback]391339[/snapback]</div>
    Nope this is the check engine light not the Maintance Required light. And No I haven't tried another dealer.
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    You should have the dealer tell you the error codes or retrieve them yourself w/a an OBD II scanner. "All Toyota vehicles do this" is total BS and untrue.
    In any case, sounds like you need another dealer.
  5. viking16
    viking16 New Member
    I think he cleared them because the check engine light is gone.
    Would do no good with another dealer since the Toyota Field rep came out and looked at it. If I take it somewhere else the same rep will come out. They are 2 close together the next toy dealer is about 30mins away.
  6. Woof
    Woof New Member
    <div class='quotetop'>QUOTE(viking16 @ Feb 16 2007, 03:33 AM) [snapback]391336[/snapback]</div>
    To me this sounds like the classic, "Go away with your trifling problem today so I can blame you tomorrow when it becomes a major nightmare."
    Not to make more work that doesn't fix your problem, but consider informing Toyota about this dealer, especially if the mechanics are "Toyota Certified." Disreputable shops that advocate ignoring the check engine light should not be backed by Toyota Corp. In the process, perhaps Toyota Corp. can support you in finding a dealer that will fix what's wrong.
  7. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    Although they should have been able to detect this if it was indeed the problem, but... The Check Engine light on many cars will come on if the gas cap is not properly secured or leaks air. Make sure you always turn the gas cap at least 3 clicks past the point where it stops. Also consider replacing the gas cap.
    This may have absolutely nothing to do with your problem, but it is a common cause of "Check Engine" lights on many cars.
  8. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Man if you got it in writing to ignore the check engine light they really opened themselves up to a major lawsuit. What happens if you lost oil pressure,you'd never know it because the light is alreadyon and they said to ignore it. so if you burned up an engine a lawyer would have a field day with this. I'd call the general manager of the dealership and ask them if he knows his service dept. is setting them up for big time lawsuits, and tell him he better FIX his service dept. starting out by FIXING your car! I bet the rep. from Toyota never even looked at your car.
  9. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    Forget lawsuits. You don't have to do a thing. Just inform CARB with a copy of the letter, and I suspect under lemon laws, you will get a new car, as you indicate Toyota said they don't know how to fix it. I'm pretty sure in Calif. and probably anywhere in the US and Canada, a CEL on is not allowed. If it comes on again anyway.
    It's probably just a connection issue somewhere, but if they can't fix it - they must replace the car! It's not legal to drive with the CEL on all the time.
  10. MegansPrius
    MegansPrius GoogleMeister, AKA bongokitty
    2,437
    27
    Chicago, IL
    <div class='quotetop'>QUOTE(viking16 @ Feb 16 2007, 04:33 AM) [snapback]391336[/snapback]</div>
    Yeah, you should really forward of copy of that letter to Toyota Corporate. The advice of "change how you drive," "ignore check engine" and "all Toyotas do this" sounds, frankly, crazy. I also can't believe all Toyotas do this if they idle more than 30 mins. One poster here, Paul Cullen, used his Prius to power his house for TWO DAYS during a power shortage. http://priuschat.com/index.php?s=&show...st&p=363152
    Customer Experience Center
    Phone: 800-331-4331
    Mon - Fri, 5:00 am - 6:00 pm PT
    Sat, 7:00 am - 4:00 pm PT
    Fax: 310-468-7814
    Or send correspondence to:
    Toyota Motor Sales, U.S.A., Inc.
    19001 South Western Ave.
    Dept. WC11
    Torrance, CA 90501
  11. KTPhil
    KTPhil Active Member
    1,379
    I agree with the "fix it or give me a new car" offer to Toyota. California has a 50K mile emissions warrantee, and that includes NO check engine light. Third time's a charm, if they don't fix it, demand a new car. Send a copy of the demand as high up in Toyota as you can find. I'm sure they will take issue with the "all Toyotas do that" claim PRONTO!
  12. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Another jerk ripoff dealer making the "they all do that" claim. If you really do have their claim in WRITING, make many copies. Even better have an attorney notarize a copy. Send that to CARB, and CC it to Toyota headquarters.
    Amazing. "They all do that."
    Of course, if the car should happen to calf when conveniently off warranty, they'll claim "TFB you're SOL."
  13. malorn
    malorn Senior Member
    4,281
    59
    &quot;Somewhere in Flyover Country&quot;
    <div class='quotetop'>QUOTE(viking16 @ Feb 16 2007, 02:33 AM) [snapback]391336[/snapback]</div>
    Just try another dealer. Let another dealer know your plight and i think you may be surprised at what happens. Every manufacturer has bad dealers.
  14. viking16
    viking16 New Member
    Thanks everyone I will google CARB and tell them. I think they (dealer) just wanted to get to get the car back and make up the story. What I will do is wait till the next check engine light comes on again and call Petaluma Toyota (they are about 30mins from My town) and ask them.
    I forgot to add Toyota (the one in town where we took it to) said the code is a ghost code and engine is thinking it is over heating when it is not and all toyota's do this when they idle. He also told Toyota knows about this problem and has NO fix for it at this time.
    Boy this is a great forum thanks for all your help. I will see if I can find that letter and scan it and post it.
  15. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    I agree with the poster who said he didn't believe the Toyata rep looked at it.
  16. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    <div class='quotetop'>QUOTE(viking16 @ Feb 16 2007, 01:13 PM) [snapback]391713[/snapback]</div>
    Total BS. The Prius engine does not idle for more than a minute or so when it's warm. If you sit for 30 minutes, the engine will only start if it's necessary to charge the traction battery.
    Demand the code number. They should have a record of the work done last time.
  17. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Please divulge who the POS dealer is. Inquiring minds want to know!
  18. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    <div class='quotetop'>QUOTE(Marlin @ Feb 16 2007, 05:29 AM) [snapback]391367[/snapback]</div>
    Yep, a loose gas cap can definitely trigger check engine lights. However, it's just a common cause and w/o retrieving the codes, one really has NO IDEA what is being reported. The light being on doesn't you which of the hundreds of codes listed at http://www.obd-codes.com/trouble_codes/ (for example) is being thrown. In some cases, there are multiple codes stored.
    Places like http://www.obdii.com/ and http://www.obd-2.com/ have info and links to scanners you can buy. I saw http://www.carmd.com/ at CES. The neat part is that you can plug it into your computer via USB and you'll receive reports like those at http://www.carmd.com/AboutTheProduct/WhatDoIGet.aspx which tell you the common causes of the codes you're getting along w/estimated repair costs.
  19. viking16
    viking16 New Member
    Hey cwerdna I really like car MD. I am really thinking I might buy one.
    JimN the dealer is in Santa Rosa CA. They are called Freeman Toyota and Lexus (http://www.freeman-toyota.com/)
    I will call them monday (2-20-07) and ask for it.
  20. hill
    8,569
    "Hey Mr. Dufus Dealer ... I'll bet the local consumer advocate TV show would like to come down and interview you .. maybe you'd like to tell your fellow Toyota customers you send away ON TV, that you're unable to fix their car ... and maybe corporate would like to hear about you over the boob tube as well?"
    That ought to light a fire under him/her. Doing trial work years ago ... when dufus attornies would obviously not know their head from shinola, I would love making objections, by only refering to code numbers (104b, etc) ... so when the judge asked for rebuttal, the opposing counsel would have to say I don't know what that number means. I'd then reply (boy would opposing counsel feel stupid in front of their client), "perhaps the defense needs time to consult with an attorney?". Embarrasment over unpreparedness is a great motivator. I know, because I REALLY learned the evidence code after a wisenheimer attorney did the above to me :p
