Prius rear widow explodes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hycamguy07, Sep 24, 2007.
  1. hycamguy07
    hycamguy07 New Member
    2,707
    Central Florida
    I just finnished a report on a Prius rear window/ hatch window expolding into the car.
    The driver/complaintant said this was their 2nd prius and had never happend before. And had I ever heard of this happening?
    I told her only on pick up trucks & SUVs...
    She said she had parked the car in a publix parking lot and the window was fine, when she returned there was glass all over the inside of the car. I checked the car and there are no signs that it had been hit..
    Again I was surprized to this happen on a prius.... :huh:
  2. Proco
    Proco Senior Member
    2,570
    172
    28
    The Beautiful NJ Shore
    <div class='quotetop'>QUOTE(hycamguy07 @ Sep 24 2007, 11:47 AM) [snapback]516882[/snapback]</div>
    Yikes! This better not happen to my rental when I'm in Orlando at the beginning of October!!
  3. hycamguy07
    2,707
    Central Florida
    I know on the SUVs, Minivans & pick up trucks the large rear window has a tendency to expand & retract due to heat-up and cool down..
    Ive never heard of a prius having that problem though...
  4. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    <div class='quotetop'>QUOTE(hycamguy07 @ Sep 24 2007, 10:47 AM) [snapback]516882[/snapback]</div>
    This happened to my cousin's camaro a number of years ago. It was cold in the morning when they checked on something in the car (letting in cold dense air), then got hot during the day. A brief rainshower came along, contracted the metal and the window blew out. I suppose some of the glass then fell back in, but a good deal blew out onto the trunk. If that's what really happened, it's a sign of pretty tight seals.
    Maybe it's a good thing I tend to crack the windows on hot days. It's a pretty secure place here, I'm only worried about rain getting in.
  5. echase
    echase New Member
    227
    I would think the battery vents would allow air preassure to equalize. Besides, wouldn't a perfectly sealed car present a suffocation hazard?
  6. Sonny Jim
    Sonny Jim New Member
    260
    Newport Beach, CA
    <div class='quotetop'>QUOTE(hycamguy07 @ Sep 24 2007, 08:47 AM) [snapback]516882[/snapback]</div>
    Public parking lot + no apparent impact = spark plug chip
    http://en.wikipedia.org/wiki/Ninja_rocks
  7. nerfer
    2,507
    237
    28
    <div class='quotetop'>QUOTE(Greenkeeper @ Sep 24 2007, 12:12 PM) [snapback]516928[/snapback]</div>
    You're probably right. Just the metal contracting from sudden rainstorm. Could this happen if the sprinklers soak your car? Could be colder water, but not as much at once.
    The old VW beetles were known to have tight enough seals (when new) that it could be hard to close the door with the windows rolled up tight, and they could float. But I'm sure the vents still let a little air in and out.
  8. Tideland Prius
    16,402
    air can seep in through the vents and the door panels so it's not completely air tight lol.
    I believe this is the second time it was reported on PriusChat. Do a search to find the first incident.
  9. ceric
    ceric New Member
    1,114
    Fremont, CA
    I wonder how can one be sure that it was not vendalized by a passerby who hates Prius?!
    All it takes is a quick blow when no one is around. :angry:
  10. MegansPrius
    MegansPrius GoogleMeister, AKA bongokitty
    2,437
    27
    Chicago, IL
    <div class='quotetop'>QUOTE(Sonny Jim @ Sep 24 2007, 12:28 PM) [snapback]516938[/snapback]</div>
    There is at least one published press account of these being used:
    Suspected car burglars arrested in Newport
    Maliki is accused of breaking apart spark plugs and throwing the porcelain insulator at windows to smash them and burglarize at least 15 cars along Back Bay Drive and neighboring streets.
    http://www.ocregister.com/ocregister/homep...cle_1617608.php
  11. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    <div class='quotetop'>QUOTE(ceric @ Sep 24 2007, 02:44 PM) [snapback]516980[/snapback]</div>
    A spring-loaded center punch works well too. <thwack...crash...tinkle>
    Tom
  12. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    A spring loaded punch-down tool would also work nicely, especially if a #66 blade was inserted
  13. john1701a
    john1701a Prius Guru
    12,793
    5,275
    57
    Why? It happens to other cars.
    My father's Taurus had the very same thing happen many years ago. We never did figure out why. But I did get the prize for "most exciting theory" by saying it could have been struck by a micro-meteorite.
  14. Peter7307
    Peter7307 New Member
    Not as uncommon as might be expected.
    Stresses built up in the glass during manufacture can cause this to happen and with no warning either.
    The stresses are invisible and therefore pass through quality control where a chip or crack would be seen and the glass taken out of the line.
    Had something similar happen with a glass coffee table. It sat for years in the living room holding nothing heavier than a magazine. One day there was an extremely loud noise like a rifle shot. It was loud enough people heard it about thirty feet away in the back yard.
    We all went into the living room to find the coffee table glass top neatly broken in two pieces and no other glass shards or splinters. In fact we put the two pieces together and the matched perfectly.
    The general theory was stresses causing the demolition but I have to say the mini meteorite theory sounds a lot more impressive !
    Cheers , Pete.
  15. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    Happened on my Toyota Sienna on a side window. I think this must happen more often than people realize. I was driving along a freeway over the Rio Grande... not much chance of a BB shot making it. There was a loud BANG and I looked back at the big window on the right sliding door and it was totally crackled. Scared the heck out of us. And it kept crackling for a couple hours. Drove straight to a glass shop and State Farm paid for replacement.
  16. miscrms
    miscrms Plug Envious Member
    2,076
    523
    Phoenix, AZ
    Had same thing happen riding in a friend's Accord. Cruising down the highway, no other vehicles around. Loud pop and tinkle from the sunroof overhead. Fortunately the shade was pulled or we would have been wearing it.
    Rob
  17. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Had the rear windshield completely fracture on my 2001 Prius. Here are some details:
    1) Had to leave the car outside the home garage for one Floride winter night since home repair equipment was stored in the garage that night.
    2) Condensation on the window required turning on the rear window defrost for the first time ever when going to work.
    3) When returning to the car from work, the rear window was in 10000 pieces. This is in an enclosed parking garage, many floors up. Very, very unlikely to be middle of the day vandalism due to the empty car, undesirable parking spot, the security cameras in the surrounding accesses, and all the nearby cars with nice things to take.
    The first lesson is that (unlike the front windshield), the deductible must be used on your car insurance. The second lesson is that your rear speakers will not survive this. The third lesson is to use a vacuum cleaner with enough horsepower that it can pull the paint off the car (else your rear passengers will find little pieces of glass for years afterwards).
  18. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    One of the most common ways of breaking into a car is by flicking a porcelain chip, such as from a spark plug insulator, at a window. The glass will shatter and there will be no tale tell signs of the manner in which the breakage was accomplished.
  19. philmcneal
    philmcneal Taxi!
    332
    Simcoe Ontario
    <div class='quotetop'>QUOTE(FL_Prius_Driver @ Sep 25 2007, 04:30 PM) [snapback]517649[/snapback]</div>
    hm what does one advise to prevent this kind of things from happening to a guy like me?
  20. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    <div class='quotetop'>QUOTE(philmcneal @ Sep 26 2007, 05:53 PM) [snapback]518151[/snapback]</div>
    Option 1:
    Move to Florida, buy a house with a garage, and keep your Prius in it every night.
    Option 2:
    Decide to inspect you rear windshield very closely and carefully, especially around the edges. Look for any cracks or fractures. If you notice any, call a car glass shop. Cracks can be drilled and filled.
