Prius-Segway Challenge
Discussion in 'Gen 2 Prius Main Forum' started by xbdude, Jan 25, 2008.
  1. xbdude
    xbdude opticat
    168
    North Central Florida
    I just got a Segway (Segway.com) and I’m cruising around the neighborhood to the bank, the drugstore, Burger King, etc. on it. At first it was somewhat strange to ride because you always feel like you are going to fall backwards or forwards. On a narrow sidewalk, you can get going so fast (exactly 12.5 mph before the speed limiter lets you know you’re on thin ice here, thank you) that it feels a little scary. Also, I’m vertically challenged at 5’ 7â€, but the additional height I gain while standing on the Segway brings me to a pleasant 6’-4â€, somewhat lofty compared to most of my pedestrian counterparts. Don’t worry—I am very courteous when approaching a pedestrian from behind. The Segway is as quiet as the Prius in stealth mode, so I have this not-so-pleasant little bell that I activate to avoid unnecessary pedestrian collisions. Cruising (no, “gliding†is more appropriate) can be an interesting experience, since everyone passing by in cars stares in amazement, huge grins on their faces, children with their hands pressed up against the glass as they happen by. Anywhere I go, everybody asks what it is, where I got it, and how much it costs, and how fast it goes. Some people even have the courage to ask to ride it (I haven’t let them yet, but probably will soon). Sometimes I don't just ride up and park outside a store. I glide right in. The Segway is equipped with a cool little handlebar bag that holds much more than it appears making it great for those small but pesky errands. It always brings stares when I go through a drive-through lane (“ Are you sure that burger’s plain, young man?â€) It fits perfectly in the back of my Prius when the seats are folded down. Just hook a heavyb bungee to the nifty Prius tie downs to keep the Seg from swinging about. The low deck height of the Prius makes it easy to load and unload. Since the Segway has been touted as the next revolution in transportation, let the PRIUS - SEGWAY CHALLENGE begin!
    Segway ---- Prius
    Range: 24 miles ---- 500+ miles
    Top Speed: exactly 12.5 mph ---- 100+ mph
    Payload: 260 lb ---- 810 lb
    Price: $5250 ---- $23,460
    Weight: 105 lb ---- 2932 lb
    Power: about 4 hp ---- 110 hp net peak combined
    Passengers: 1 ---- a tight 5 or easy 4
    Turning Circle: 0 (turn-in-place) ---- 34 ft
    Ground clearance: 3.4 in ---- 5.6 in
    Batteries: Lithium Ion (2) ---- Nickel-Metal hydride (28)
    Fuel cost/mile: $.0096 at $0.25/charge* ---- $0.054 $3.00/gal (55 mpg)
    Cost in dollars/lb payload: $20.19 ---- $28.40
    Dollars per total range: $0.25 ---- $27.27
    Safety: Lots of WARNINGS! ---- Ironclad
    Reliability: Bulletproof ---- Bulletproof
    Emissions: None ---- AT-PZEV (almost none)
    Fun-Factor: Exciting in no traffic ---- Somewhat tepid
    Group attracted to it: Everyone ---- Practical, environmental, intelligent
    So what does it all mean?
    The Prius is 9 times faster, and 4.5 times more expensive, carries five times the passengers and has 23 times the range. The Prius has 27 times more power and 28 times the weight. The Segway DOES accelerate smartly to 12.5 mph, but the combined HP of the electric and gas in the Prius does allow adequate acceleration.
    The Segway has lower fuel cost per mile though (*just plug it in and you pay for it with a slightly higher power bill—cost based on dollar/kw/hr for your area). But the Segway is a bit pricey in the speed and range category, for how fast and far it can move stuff per dollar of acquisition cost.
    Interestingly, even though the Prius is 27.9 times heavier, it only costs $.044 the number of dollars in fuel more than the Segway for each mile traveled. In other words the Prius is actually cheaper per pound in moving itself!
    Bottom line: The most range, speed, payload, and safety all go to the Prius, but if you like to be the center of attention, then you need a Segway!
    With special thanks to AM for your ideas.
  2. AZPrius
    AZPrius Desert Rat
    42
    Phoenix
    That's funny, I just got my first chance to ride a Segway today. Quite the interesting experience.
    Prius also "bests" the Segway if it's too hot, too cold, raining, snowing, sleeting, too dark.... but would be fun to have anyway. I wish they were chaeper, I'd probably be willing to pay ~$1500 or $1800 tops.
  3. GreenLady
    GreenLady Member
    163
    Denver, CO
    Nice! :)
    The only times I've seen Segways were when I worked at an airport, and the police officers used them.
  4. daniel
    14,487
    1,519
    Spokane, WA
    I'm a bit surprised that it costs nearly a penny a mile. My 4-passenger 4-door Zap Xebra costs about two cents per mile but weighs a lot more. (New figures may be forthcoming when I get it back with the new LiFePO battery pack.)
    I once rode on a Zappy3, which I call the poor man's Segway. It has 3 wheels and no balancing mechanism and only costs around $600. But I found it scary as I was constantly in fear of falling, and there's not enough weight on the drive wheel, which therefore has a tendency to spin. I'd like to ride on a Segway, but I have no use for one.
    My Xebra gets the kind of attention you describe for the Segway.
  5. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    ok lets add a Zenn to the mix
    Range: 25-40 miles depending on OAT
    Top Speed: 36 mph
    Payload: 550 lbs
    Price: $14,00010
    Weight: 1290 lbs
    Power: about 18 hp ( i think)
    Passengers: 2
    Turning Circle: not much
    Ground clearance: enough
    Batteries: lead acid deep cycle...6 of em
    Fuel cost/mile: your cost is subjective and an estimate im guessing... my cost is well, lets do performance instead since you dont tell us what you pay for electricity. Zenn does 3.46 miles per kw.
    the rest i not sure i understand, so i skipped it.
  6. patsparks
    10,664
    567
    Adelaide South Australia
    Segway uses power just to stand still.
    Another point to score the segway against the Prius is width of doorway it can pass through.
    Another, how many countries are they legal in. In Australia Prius 1 Segway 0.
    As ther Segway does not comply with vehicle standards it isn't legal to use on public roads or footpaths.
  7. tochatihu
    tochatihu Senior Member
    9,456
    3,654
    Kunming Yunnan China
    2001 Prius
    Add an outboard inverter ot your Prius and you can charge the Segway while you are hauling it...to that next narrow doorway.
    Apparently when GWB got on his dad's Segway, and famously fell over, he did not know the part about turning the gyros on.
  8. Howard M
    Howard M My other Harley is a Prius
    Tucson, AZ
    Put the Segway in power assist mode and it can climb steps ;)
    At least on the Gen 1 model, I think the Gen 2 is different.
    I've had a Segway since April '03 and while it's a great machine for the intended purpose of using it when it's too far to walk and not far enough to use a car.
    Ironic thing is when I lived in NYC and used the Segway all the time it was illegal and I could have been ticketed or had it confiscated.
    Now I live in Tucson, AZ and it is completely legal to use but I don't use it anymore cause everythig is too far. No more corner deli, bakery, etc...
  9. daniel
    14,487
    1,519
    Spokane, WA
    When it's too far to walk but not far enough to drive the Prius, I prefer my Xebra over a Segway. (Not far enough to drive the Prius means anything less than around 30-odd miles.) And I stay dry in the rain in the Xebra. But of course the Segway is cheaper. But the Xebra goes at or even over the in-city speed limit: it goes 40 mph, and the speed limit is 25 on most Spokane residential streets, and 35 on most Spokane arterial surface streets.
    To me the Segway looks like a toy. A fun-looking toy, I admit, but a toy nonetheless. (Though to be fair to the Segway, the Xebra is a bit of a toy as well, and the Segway is probably better built.)
  10. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    I saw a guy on Segway riding around a parking lot once. This was the first time I saw one in person. They move so fluidly, its freaky. The guy was mapping out the parking lot for seal-coating. He had a GPS on the handlebars, and a palm computer. So, he would just hit enter when he reached a the corners of the parking lot which was kind of U shaped, and calculate its area. He had it done in 5 minutes, even though the parking lot was about 100 yards by 75 yards. Pretty neat.
    Yea, even here in suburban Chicagoland, the various places I go are too far a range for a Segway. I would need about 25 miles range to do my typical weekend errand loop with sufficient margin (3 or so miles). And this is all in one town only. The Segway has about 15 miles range last I heard.
    Its bizarre that the places that need these things the most, outlaw them. Think about the cars off the streets each Segway represents. New York probably saw them as a threat to bus revenues. Although they are not outlawed in Chicago proper. There is a Segway Tours company in downtown Chicago. They take you on a tour of the city, each customer on a Segway -another neat application. Segway started up production based on orders from catalog/online merchandising wearhouse operations. Eddie Bauer et al can get allot more picks done when the wearhouse people are zipping around on segways rather than foot.
  11. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    And you have no trouble lifting that into the Prius?
    For me, a Zenn or Zap or other Neighborhood Electric Vehicle would make sense. Most of my trips are within three miles here in town as I either shop locally or visit clients.
    One of the big obstacles to such a purchase, however, is the vehicle cost. Even if operation was completely free, with no maintenance, it would take years to break even vs. the operating cost of the Prius.
    I suppose the only real solution would be to eliminate one conventional car, my wife's 1995 Volvo, which has cost a bunch for maintenance. Give her the Prius and buy myself a NEV. We usually travel together out of town anyway; it's very rare that we both need to leave town at the same time.
    Wonder how I could make that fly...
  12. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    i would love a segway, but only as a toy... i am almost always either at work, or with my son. so a one passenger option would fit very little of my transportation needs.
    also, living in Pacific Northwest, it would be parked for most of 6 months every year since i will not do rain.
    besides, for the speed and real range of the thing, i have a bicycle that does the job and keeps me breathing as well.
    but like i say, if i won the lottery, i might pick up a few just for those nice summer nights to take a ride thru the park or something. (keeping in mind that the many trails we have here, none allow motorized transports of any kind)
  13. Qlara
    Qlara New Member
    488
    Also Prius has tons of safety features like Air bags, ABS, VSC and 5-star crash ratings to name a few. Segway has none.....(or its only safety are to make sure you don't go above 12.5mph and not falling down easily?) I'll still put my bet on the Prius instead.
  14. Devil's Advocate
    922
    Las Vegas, Nevada
    When it comes right down to it $5,000 for a 1/2 a scooter is retarded!
    I can get a used honda civic for that for christ's sake!
    Maybe $1,500.00 MAX better at around $1,000.00. Especially since they are illegal in half the cities you would want to use one!
  15. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    I agree, $1500 and I'd give a Segway serious consideration...but $5000 is just far far too much, IMO.
  16. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    I've driven the off road version of the Segway; the one with the big, knobby tires. What a hoot. I would buy one, but it might eliminate the little bit of exercise I get. Where I live, everything is either in easy walking distance or too far for even an electric car. There isn't much of a happy medium.
    Tom
  17. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    Please do not ride these on side walks.
    My sister was struck from behind by a bicycle and ended up with a broken leg. Sidewalks should only be for people, not segways or bicycles. That is what bike pathes are for.
  18. ny biker
    ny biker Member
    463
    Northern Virginia
    2022 Prius
    Actually I imagine New York sees them as a threat to pedestrians. You'd be killed if you tried to use one on the street, and on a crowded sidewalk you could do serious damage.
  19. donee
    donee New Member
    2,956
    197
    Chicagoland
    So why are bycicles not outlawed then ? They go faster, and are far less actively safe than a Segway. I can't count on my ten fingers how many times I have been brushed by a bicycle going down a sidewalk or through a red light in excess of 12 mph.
  20. donee
    donee New Member
    2,956
    197
    Chicagoland
    A segway on a sidewalk can be operated perfectly safely. Unlike a bicycle which requires a certain amount of speed to be steerable, and in balance. A person can run nearly as fast as the max speed of a segway. When is the last time you saw a person ticketed for running on a sidewalk ? Are we going to outlaw jogging now too ? Lets see, the 6 minute mile - common standard of fitness - is 10 mph, duh.
    If somebody came up with a bycycle with very large rotational inertia wheels, then bicycles might be able to go slow enough to stay in balance at walking speeds. But there are other problems with this idea, of course.
    Segway restrictions on sidewalks is pure and simple Ludite-ism.
