Prius "transmission"
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by John Steenhoven, Jan 29, 2018.
  1. John Steenhoven
    John Steenhoven Junior Member
    Portage MI
    My Prius today was slipping out of drive and into neutral on its own and also would not shift to park as well. Driving in Michigan in ice and snow and car was warmed up. This happened twice after powering off and turning back on. After a couple more power offs ran fine remainder of day. Any ideas? A sensor covered with snow? Vehicle has been in this weather for 10 years no problem. Thanks!
  2. valde3
    valde3 Senior Member
    2,002
    746
    Finland
    Do you mean that while driving it goes to neutral and you then have to shift it back to drive. Maybe just a bad shifter? If you hold it in drive does it then stay in drive? If that’s the problem it should be easy and pretty cheap fix.
    What happened when you tried to shift into park?
    #2 valde3, Jan 29, 2018
  3. John Steenhoven
    Portage MI
    Yes, slips in to neutral while in drive. It does stay in drive if I hold lever in place. At one point it would not shift from neutral to park as well....I had to shut off vehicle to go in to "Park".
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    "Slip" is a poor choice of words for this, as a "slipping transmission" means an entirely different thing.
    In this case your "transmission" (the HSD) is doing exactly as told by the shift lever. Just the shift lever is going insane and telling it to do weird things. If you are in D or B and above 7mph if you (or the shifter gods) select R or P, it will go to N. We have seen this before on cars with heavily used shifters. A junkyard part is an easy swap, there is just a connector on the back. Pop some trim, unplug the old, plug in the new, bam new shifter.
    Are you one of the people that shifts into N at every light, or between D and B thousands of times on a drive home? My coworker did that. His shifter also died. It has a finite life cycle like all switches, and usually it is used 3-4 times per drive. But if you're using it 300 times per drive, it will die a lot more frequently.
    Also you can take this opportunity to "upgrade" your shift knob to something different. Since it does nothing but send codes, you can make it whatever you want. There is a flourishing aftermarket shifter knob market including just buttons for each gear versus the knob itself. If any of that appeals to you, now would be the time.
  5. John Steenhoven
    Portage MI
    You're right, slip is a bad choice of words....could not think of another! Interestingly, it only changed from D to N at 1 or 2 mph...definitely not above 7 mph. And no, I am not one of those that shift to N while at a light. Always in D, R, P, or in N through a car wash. Occasionally in B going down a steep hill. Thanks for your note!
  6. bisco
    50,831
    could be a bad shifter, how many miles on her?
  7. padroo
    padroo Senior Member
    2,763
    2,251
    You could check your electrical connections here also.
    I am thinking this because it is exposed to the weather in the rust belt. I would check the electrical connector in the video for green wire oxidation ( bad connection).
    #7 padroo, Jan 29, 2018
  8. John Steenhoven
    Portage MI
  9. bisco
    50,831
    any trouble codes?
  10. John Steenhoven
    Portage MI
    Nope. And it worked fine the rest of the day, about an hour of driving. Business utility vehicle.
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,829
    Clearwater, Florida
    Shifter is bad many posts about replacement. Frigid temps probaby got it.
    Combo meter is next I’m afraid.
  12. ChapmanF
    16,991
    I don't know that any switches are in there ... just magnets and a couple Hall effect sensors that never touch them or move. I can't easily guess what would wear out in one, though from your post it seems like there's something that can.
    Maybe some piece of metal finds its way in and sticks to one of the magnets, making it seem nearer the Neutral position than it is?
    From the rest position to N is only one axis of movement, so just fooling the lateral sensor could look like a shift to N. To get spurious R or D, both sensors would have to be fooled.
    I'd bet those button units use actual buttons (switches!) and might be even more at risk of wearing out, though I have no data.
    -Chap
