Prius v 2012 Mechanical key
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by BubbleDogs, Feb 19, 2015.
  1. BubbleDogs
    BubbleDogs Junior Member
    71
    NY
    It seems that the battery to the smart key ran out. I knew there was what it was called "mechanical key" in the smart key, so I took it out. Great. But..... how can I start the car with mechanical key?
    And if you are outside, and the door is looked, how could you open the car with the mechanical key. I could find how to use the mechanical key anywhere. And my search for "Mechanical key" in the prius v chat only generated Honda ad.....
    Your help is greatly appreciated!
  2. BubbleDogs
    71
    NY
    Will it work for v??
  3. Mike500
    Mike500 Senior Member
    2,593
    766
    Yes,
    and the battery is the widely available CR2016. It's the same coin battery used in current Timex watches.
    BubbleDogs likes this.
  4. bill03060
    bill03060 Junior Member
    Nashua, NH USA
    2022 Prius
    XLE AWD-e
    The mechanical fits in to the slot in the driver's door handle, just like any key. To start the car, hold the key fob, with the silver Toyota logo, against the Power Key and with the brake pedal depressed, push the Power key and the car will start.
