Prius V wheel Question
Discussion in 'Gen 3 Prius Accessories and Modifications' started by sshowell99, Feb 4, 2011.
  1. sshowell99
    sshowell99 New Member
    Alabama
    I own a Prius IV and was wanting to upgrade my 15" wheels to 17" Prius V wheels. I came across an auction for a Prius V OEM wheel that stated the following in the description "This wheel is for the Prius V only, the ABS Unit and EPS is not set up to accept a 17" wheel if you don't have the V". Now I've seen a lot of III AND IV models with Prius OEM 17" wheels. I was wondering if anyone has encountered this situation and if there was any truth about the ABS/EPS not functioning properly. The other question I have is can I expect to get the same MPG if I do upgrade to the 17" wheels. Thanks
  2. Tideland Prius
    16,403
    Yes there will be a decrease in mpg and it will depend on the weight of the alloy, the weight of the tyre, the design of the alloy (drag) and the width of the tyre (friction).
    As for ABS/VSC, he's probably just covering his bases. There may be some cars that have issues with upsizing the wheels but there are a number of members here that have successfully upsized without issue.
  3. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    You should expect a ~1.8 mpg hit based on published numbers.
    The 17"-wheel Prius EPS has a brushless motor system that allows the tighter ratio, but the 17" wheels will fit II-IV just fine.
  4. bagwell
    bagwell Active Member
    592
    49
    the woodlands, tx
    I have the V wheels on my II and have had zero issues....VERY slight MPG hit but nothing else.
