PriusChat Forum Upgrade - post your bug reports/gripes/thanks here
Discussion in 'PriusChat Website Questions' started by Danny, Dec 2, 2007.
  1. Danny
    Danny Admin/Founder
    7,094
    2,116
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Well, it took a little bit longer than I had hoped, but it's (pretty much) all done! Please use this thread to post your bug reports, likes, dislikes, etc.
    I'll post the known issues and possible resolutions in the 2nd post.
    -Danny
  2. Danny
    Danny Admin/Founder
    7,094
    2,116
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Things I already know about:
    1. Password won't work with new software. You'll need to reset your password:
      1. http://priuschat.com/forums/login.php?do=lostpw
    2. PMs - for some people every PM they've ever sent/received will be showing up. And for some your Sent PMs will be in your Inbox, and vice-versa. To help you guys clean it up, I've added a PM Search. You can easily search for PMs by Username, subject, etc, and move them into folders or delete as needed:
      1. http://priuschat.com/forums/private.php?pmsearch=1
    3. Weird text showing up in Quoted posts. I'm working on a fix for that, so for right now just ignore it
    4. Signatures a little wonky - go into your UserCP/Edit Signature to correct it:
      1. http://priuschat.com/forums/profile.php?do=editsignature
    5. "Log In" names imported instead of their "Display Names". The way to fix it is:
      Log-in using your log-in name and password, then once you're in go to your UserCP. At the bottom you'll see a link called "Username Request" - click there, submit your name change request, and myself or a moderator will review your request.
      http://priuschat.com/forums/profile.php?do=requestusername
  3. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    It seems that the new software did not remember my password. It may just be mine, but you may want to chek this. I had to request a new one to log on.
  4. Danny
    Danny Admin/Founder
    7,094
    2,116
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    I've heard that from a couple of people already. I was able to get in with my test account's password, but Tony wasn't. Not sure if it was because of the contents of it, or what.
    For anyone having this issue - here is the link to have a new password sent to you:
  5. pkhoury
    pkhoury Proud TDI owner
    183
    Texas Hill Country
    Password troubles
    I had the same trouble with the password. Had to reset mine as well.
  6. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    Migrating a database a huge as PriusChat is no simple task. No doubt there will be glitches.
    Over the weekend, Danny, Evan, Tideland Prius, Galaxee and I tested a few things and identified a few tweaks. Unless Danny was able to fix them all, there might remain a few little things that will require individual attention.
    - Some signatures were messed up
    - Some threads were showing the format tags
    - Some PM mailboxes got bloated when all the "sent" PMs were placed in the "Inbox" pushing the mailbox over maximum capacity.
    In the end, we had to make a decision. Would it be easier to have individuals take care of their own signatures and mailboxes or should we keep PriusChat offline while Danny attempts to fix all of them?
    In order to get PriusChat back online, we decided to move ahead with a few remaining issues. If your signature and/or mailbox is a little off kilter, let us know and we can help you fix them.
  7. samiam
    samiam Antipodean Prius Poster
    2,442
    29
    Enn Zed
    While nearly all of the above glitches also occurred to my case (including having my birthday set to 30 November!?) I can say that it was a simple matter to recover nearly everything. So no worries & thanks Danny
  8. amped
    amped Senior Member
    3,892
    694
    Columbia River Gorge, Oregon
    Reply
    Nice improvements and big speed increase, thanks! No problems with login or browsing, though it wouldn't take my reply without a title.
  9. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    kudos, Danny!
  10. robincx
    robincx "Fear is the mind killer"
    1,294
    North Boston, NY
    Nice upgrade, bugs are always present when doing a system upgrade like this.
    Suggestion: from a usability perspective, keep all the buttons and info flush left, it's a bit hard on the user to adjust to the left/right scanning.
  11. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    An ever so major "Thanks!" to Danny for all the hard work and to the mods for helping him. The few glitches that Tony listed are more than manageable.
    An ever so minor issue: I've lost the capitalization in my user name -- the "J" and the "K." To most that probably wouldn't matter, but I'm anal. :p
    (Hey, and the new smilies work too!)
  12. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    Yay! Thanks for all the hard work, everyone!
  13. datavortex
    datavortex New Member
    114
    Atlanta, Georgia, USA
    Suggestion: I would like to use threaded mode.
  14. Neicy
    Neicy Member
    834
    Wakefield, MA.
    Great Job. Looks fantastic!
    Really IS fast!
  15. galaxee
    9,810
    468
    MD
    oh, i like the auto-search function when posting a new thread title.
  16. bestmapman
    1,289
    242
    The View New Posts feature does not appear to be working. I have made two posts and none show up using this feature. Great improvement overall.
  17. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Deleted as duplicate.
  18. seasalsa
    1,278
    Kent, WA
    This is another bug, The first two posts were "Post Quck Reply" and each came back as an error. The 3rd was just "Post Reply" and it worked only to find that the first two had worked also???
  19. seasalsa
    1,278
    Kent, WA
    I had no password problem. I do miss the "View New Prius Posts" and "Mark all posts as read", any chance of getting them back?
  20. Godiva
    Godiva AmeriKan Citizen
    10,339
    More dislikes:
    When I post an URL there is no second window allowing me to give the URL a name or title. I'm too lazy to look up how to write the HTML to make the URLs do this. So the URLs kinda suck.
    Don't like the editing. I go back and spell/grammar check. Now I have to give a reason for editing? I may spell like grade schooler but don't care to be treated as one.
    I guess I'll go in and look at my preferences and see if there's anything I can do to reset anything.
    Oh, and another thing. Who knew the User CP was our control panel? Kinda cryptic.
    All of the ignored users on my list are gone. I now have to set it up again. This is really annoying.
