Problem: red triangle & red power light when powering on car
Discussion in 'Gen 2 Prius Main Forum' started by jmann, Mar 20, 2010.
  1. jmann
    jmann Member
    201
    30
    Cleveland, OH
    Problem[solved]: red triangle & red power light when powering on car
    Every few days, and I think this has only happened when I first start my car in the morning here is the problem:
    Red triangle/exclamation mark appears on dashboard; LED on power button is orange; dashboard comes up with all regular icons (headlights, D-N-R-B-P, etc.) but it will not go into gear and the engine does not start; pushing the power button does not turn off the car; There are no errors displayed on the MFD.
    I then hold the power button a few seconds to force it off and try again. It then starts right up.
    This happens ever day or two or three, and so far, I think, only first thing in the morning.
    Other notes:
    This is a 2006, package is everything but leather seats (I think that is a package 6); I leave the HID headlights on all the time because there are not daytime running lights;
    While I think this is highly unlikely because the SKS and everything else works, The first thing to check is the 12V battery.
    Throw me some other ideas.
    Solved: it is the 12v battery.
  2. abra
    abra Member
    197
    Austin, Tx
    Three Touring
    12V battery Low voltage or battery about to go out.
    Happened to me alot when i forgot to close hatch all the way.
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    If your 12v battery is the original, it's probably the cause of your problems and should be replaced. The other possibility is the brake pedal switch or you're not pushing hard enough on the brake when powering up. I think the 12v battery is really the culprit though.
  4. jmann
    jmann Member
    201
    30
    Cleveland, OH
    Yep, it is the 12V battery. I'm calling my buddy to get me one at the auto store supplyer price. (out of curiosity, what did you guys pay for the AMT battery for the prius?)
  5. Patrick Wong
    18,209
    6,510
    I paid ~$139 plus sales tax when buying the 12V battery from my local Toyota dealer in Tucson this past fall.
  6. firepa63
    1,761
    208
    Make sure you are getting a battery that will fit the Prius and has proper venting. Toyota is really the only battery made specifically for the Prius.
  7. Music City
    Music City New Member
    Nashville, TN
    My 2005 Prius has been doing exactly the same thing for a couple of months now...very random occurence. We also keep the lights on while driving and have for almost 5 years now. The dealer has not been able to replicate the problem. He must not have experienced a Prius with a worn battery yet. So it's for sure battery replacement time???
  8. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    After 5 years the battery doesn't owe you anything anyway. Waiting for it to finally really crap out is going to increase the total cost (tow, having to go with what the first dealership says when they know they've got you over a barrel), so why not go ahead now anyway? You can shop around, or order a yellowtop on line etc. And you can do it at your convenience rather than have the car die at the worst possible time. At least by a battery boost pack if you aren't going to replace the battery.
  9. Patrick Wong
    18,209
    6,510
    Absolutely. I've seen a few posts where the hapless owner paid $400 for a replacement 12V battery:
    $100 for towing
    $100 for "diagnostic" time
    $200 for the battery and installation labor
    Especially if the battery failure happens to your spouse, SO, or child, who needs this negative drama?
    You are not married to the 12V battery. Better to replace it at a time and place of your choice, esp if you can DIY and save all the labor costs involved.
  10. Music City
    Nashville, TN
    All good advice. I did check the status of the battery last night. Without load it is at 9.7 volts. We're shopping for a new one today.
  11. richard schumacher
    7,664
    1,046
    United States
    Shopping at a dealer? There is no aftermarket direct drop-in replacement. The clamps and perhaps the cables would need modification or replacement. For that matter make certain that the dealer sells you the right one and not some random thing he has sitting around. And make sure he charges it properly before giving it to you.
    The fact that the dealer could not replicate the problem is more evidence that some dealers don't know to check batteries or don't know how to do it correctly.
  12. Music City
    Nashville, TN
    Yeah, I found out after 5 or 6 calls that a non-OE battery is not available. I did see the links about modifying the Optima but the part that scares me is rigging up a temporary 12v power source to maintain the memory settings. So far the dealers want $90 - $150 in labor plus the $139 for the battery. If I installed an OE battery myself and lost memory settings what would I need to do to reset stuff?
  13. firepa63
    1,761
    208
    Basically all you have to do is set the pre-sets on your radio and reset the auto-up setting on your driver's side window (easy and it's in the owner's manual). You may also have to set your temperature setting for your auto AC. It's really no big deal.
  14. Bob.H
    Bob.H Junior Member
    38
    Findlay, Ohio
    Just curious. Has your gas mileage been suffering for a while now?
    It seems a common thing with a bad 12 Volt battery.
  15. BAllanJ
    667
    78
    Kingston Ontario
    If you've turned off your reverse beep beep, you'll have to do that again, and if you've set the sks to open all doors, you'll have to do that again too. And your phone contact list. Basically the car's memory reverts to how it was when you got it, except for the odometer of course.
  16. firepa63
    1,761
    208
    Why would a bad 12v battery cause bad mileage. The 12v battery is basically out of the picture when in Ready mode. Therefore it shouldn't impact MPGs.
  17. BAllanJ
    667
    78
    Kingston Ontario
    The theory goes that if the battery requires constant charging to get up to the 13+V that the constant voltage charging system provides, then it's drawing energy constantly and can drop your mpgs a little. I suppose this theory could be tested by seeing if the battery is hot after the car as been in ready mode for a while.... all that energy will have to have turned to heat.
  18. richard schumacher
    7,664
    1,046
    United States
  19. firepa63
    1,761
    208
    You can run the Prius with the 12v battery totally disconnected once in the ready mode. The amount of charging for the 12v battery is negligable. That's why it takes several hours to charge it if it's almost depleted.
  20. BAllanJ
    667
    78
    Kingston Ontario
    I was responding to the question of why a bad battery would affect mileage. If a battery can only hold 7 volts, say, a 13v charger will apply a substantial current.
    I agree that no current would go to a disconnected battery, and a healthy but depleted battery would climb quickly over 12 volts, so would draw less current and would charge slowly.
