Problem with Front Turn Signals
Discussion in 'Gen 3 Prius Accessories and Modifications' started by michaellam510, Nov 13, 2011.
  1. michaellam510
    michaellam510 Junior Member
    MA
    Does anyone know to fix or solve front turn signals that are not working? I just realized that both the front signals on my Prius doesnt light or flash when making a turn, the rear are working fine. Is this an easy fix or should I bring it to the dealer? Thanks
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Does you signals "hyper-flash"? Access to the bulb is in the rear of the signal. You will need to remove the under cover to access them.
    I find it hard to believe that both bulbs burned out at the same time.
  3. cproaudio
    cproaudio Speedlock Overrider
    2,401
    760
    CA
    burnt out bulbs maybe?
  4. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Not saying that bulb failure is the problem but it's not uncommomn for similar age bulbs to expire at the same time.
  5. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    You have a pretty new car so you might still be in warranty. I can't believe 2 bulbs have gone so quickly unless you do galactic mileage, so perhaps there is a deeper issue here? (I'm past 60k miles and mine are working fine).
    Trust you haven't wired them up into nonstandard daylight running lights or anything?
