Projector Fog Lights Kit
Discussion in 'Prius c Accessories and Modifications' started by grizdogg, Aug 26, 2013.
  1. grizdogg
    grizdogg Junior Member
    29
    I am interested in adding fog/driving lights onto my car. I really would like to do an HID set-up, so I was looking for projectors. I found these:
    Not knowing anything about them, aside from them being cheap foreign knock-offs, I figured I would ask if there had been any other guinea pigs out there?
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    If you are interested in doing an HID set-up, just do the HID set-up. These aren't needed.
  3. ROLOPR
    ROLOPR Member
    441
    95
    Puerto Rico
    Probably you will be the first guinea to tested.
  4. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    i like them but it looks like there is no lens on the fog?
  5. xliderider
    xliderider Senior Member
    8,016
    3,198
    Honolulu, HI
    Of course there's a lens, it's just not flat like on a reflector based light.
    SCH-I535
  6. kingnba6
    1,018
    242
    NY
    the actual projector lens is not what im talking about. like the headlights have a lens to cover the whole light. the projector has its own lens. i am talking about the outside lens of the whole fog housing.
  7. xliderider
    8,016
    3,198
    Honolulu, HI
    Small projectors get very hot, enclosing the front for aesthetics would make them even hotter because it would block any cooling air moving over the lens and housing. Sealing in an airspace would make for an insulating effect, not good.
    Headlights are OK because there is a much larger area to dissipate the heat through the front cover and a larger airspace to heat up initially.
    SCH-I535
  8. kingnba6
    1,018
    242
    NY
    so when you get rock chips on the projector lens, what are you going to do?
  9. xliderider
    8,016
    3,198
    Honolulu, HI
    Not going to stress over it? ;)
    SCH-I535
  10. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    looks pretty bad considering there's no lense protecting the projector.
  11. grizdogg
    29
    Glad I posted this. Hadn't even thought to much about the lack of a lens. I might not be the Guinea pig either. ..
    SPH-L720 ? 4
