Proof of speeding violation
Discussion in 'Fred's House of Pancakes' started by ggops, Mar 22, 2007.
  1. ggops
    ggops New Member
    Short story
    Is it true the state troopers do not need to prove anything on a speeding violation? Literally its the officer's words against yours in the court of law?
    Long story
    He clocked me with a radar. The conversation started off at 87mph and finally after some argument about my cruise control speed (set at 72mph) the officer settled for 80mph on a 70 zone(supposedly he was being kind ).
    Finally when i visited the police car to sign the citation i saw The radar LED display on the cruiser read 75mph When i tried to explain i was warned against another citation.
    As per the State patrol office no video or photo evidence needs to be presented. This just does not sound right. There is plenty of room for error.
    Regards
    Ggops
  2. Godiva
    Godiva AmeriKan Citizen
    10,339
    <div class='quotetop'>QUOTE(ggops @ Mar 22 2007, 11:41 PM) [snapback]410676[/snapback]</div>
    You can go to courts and tell the judge your cruise control was set at 72, the officer claimed you were going 87, came down to 80 and you observed his radar said 75. You can also ask when the last time his radar was calibrated. Just know speeding is hard to beat as you are assumed guilty until proven innocent and it is his word against yours.
    That said, he's an a$$hole.
    I don't know about your state, but in mine you have to be going at least 12-15 mph OVER the speed limit. So you can take a chance, not pay and go to court. If you lose it's on your record and could raise y our insurance. Or you can pay the fine and go to traffic school and it's erased. That's what they're counting on your to do. It's revenue.
  3. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    That's garbage...
    You should have played the meow game with him. :lol:
  4. NuShrike
    NuShrike Active Member
    1,378
    In court, he has to bring certification that the radar was calibrated very recently before he got you. He also needs to show it calibrated after he tagged you. He can't clock his buddy as proof either.
    Which citation did you get written up for? Depending, you can ask for a road survey to prove that the prima facie speed limit was or wasn't valid. You also get to subpoena the back copy of his citation (Discovery). If you don't get it before the trial, he's in contempt of court and the judge, or the appeals court, has to throw the whole thing out.
    There's a lot of radar defenses out there.
  5. mikej83
    mikej83 New Member
    <div class='quotetop'>QUOTE(NuShrike @ Mar 23 2007, 01:09 AM) [snapback]410727[/snapback]</div>
    Usually the officer will testify that he performed the calibrations himself, and no evidence will need to be presented. And please, please, please be careful when giving out legal advice. You cannot simply mail out an informal discovery request and think your covered if they don't respond. You must file motions, set a hearing date, and a few other things to effectively use the discovery defense. Additionally, what applies in California may not necessarily apply in other states.
    Beating a speeding ticket is no easy task. Be prepared to spend a significant amount of time working on a defense, and consider whether or not it's really worth it to you. The system is against you from the start. The judge/commissioner/pro tem will most likely take the officer's testimony as gospel. Usually when the officer is supposed to present evidence, and fails to do so, the judge will allow it unless you object. If you raise an objection, you had better be prepared to cite the case or law that supports your objection, otherwise you will only succeed in pissing off the judge.
    I'd highly recommend that you read the part of the law you are charged with violating, and then do a lot of research. A good starting point would be at your local law library. They should have the annotated codes you can check out, and find some cases similar to yours. You'll also need to research procedural rules to find out how to do things like file a discovery request, or motion to compel, etc..
    That being said, maybe you'll luck out and the officer won't show up to court. The court should allow you to request traffic school after you are found guilty, but rules change in different jurisdictions.
  6. ggops
    ggops New Member
    Thanks for all your replies. MikeJ your reply is spot on with my own "discovery" of the legal procedures
    I guess a few too many episodes of "Law and Order" had me thinking the state has to actually prove the charges. Unfortunately that does not seem to be the case. The following is from IN - county court website
    "You should also know that since your case is a civil case, and not a criminal case, the State has the burden to prove by a preponderance of the evidence that you committed the alleged offense. This is a much easier burden of proof than "beyond a reasonable doubt," which is the State's burden of proof in a criminal case. In other words, the State must prove that it was more likely than not that you committed the offense. Also, since this is a civil case, you may be placed under oath and called to give testimony against yourself at your trial."
    I would probably pay the $36 fine plus court charges and move on. I feel miserable , helpless but heck at least i should feel fortunate I was not framed on bigger charges.
  7. dragonfly
    dragonfly New Member
    2,217
    Many, many years ago I got a ticket in Indiana for something-or-other. I don't remember why but I ended up in court. There was a guy before me that had a speeding ticket. He argued that he had the wrong sized tires on his car, so that his speedometer did not read correctly. He had been ticked for going X. He had his car tested to see how fast he was really going, when his speedometer read 55. The results came back Y, lower than X. The judge said, "so Y is still over the speed limit, right?" And he said "Right, but just a little..." So the judge let the ticket stand.
    What I'm saying is, you admit your cruise control was set for 2 MPH over the speed limit. The judge may not be sympathetic with you on that fact alone.
    What happened to you is a total crock but I agree it may be easier just to pay the fine.
  8. Schmika
    Schmika New Member
    1,617
    Xenia, OH
    <div class='quotetop'>QUOTE(Godiva @ Mar 23 2007, 12:53 AM) [snapback]410688[/snapback]</div>
    Calling someone an a$$hole based on a one sided story is being an a$$hole. Look, NO ONE WANTS A TICKET...they will color their story everytime to benefit them. I can think of MANY resons for what was described...all legitimate. LOOK IN A MIRROR, this isn't the first time your disgust for the police has shone.
    If your definition of "proof" is that he can show something in court, then the answer is no, if "proof" means his testimony, then yes. Stop watching TV!!!!
  9. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    I got a speeding ticket not too long ago... I was going about 62 in a 45... which sounds bad, but it's a stretch of 3-lane interstate highway where the speed limit drops to 45 for about a mile, and every mofo on that road speeds. I had no problem swallowing the ticket, except that the cop put me down at 67 just to bump my fine into the very pricey range of 20+ over the limit.
    There's not much we can do about it though because the cost to us to defend ourselves from abuse like that is greater in most cases than accepting the fine. It would mean time out of work, legal fees, and probably a losing battle anyway, since I was most definitely speeding :)
  10. daronspicher
    daronspicher Active Member
    1,208
    Far as I know I've driven about 115,000 miles in commuting over the last 3 years. The speed limit is 55... I'm working a hair of an offset schedule so commuter traffic is usually in the 65-75 range as I roll off my 130 miles a day... I figure it's only a matter of time before I get a ticket based on x number of cops patrolling so many miles of tollway with so many cars in the herd rolling along... I probably won't get chosen again for 2 or 3 more years.
    I got picked out about 4 months ago, paid the 75 bucks and probably got some point on my driver license for a while.
    Averaged out, I get 15 miles per penny of ticket-tax.
  11. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    A small benefit to having a ScanGauge: It displays the maximum speed for your current trip. It won't help if you've exceeded the alleged "clocked" speed earlier in the trip. But if your maximum speed for the trip is 75, it may help support your case. If the officer doesn't accept it, you could take a digital picture of the display with a date and time stamp and bring it to court with you.
  12. ggops
    ggops New Member
    <div class='quotetop'>QUOTE(Schmika @ Mar 23 2007, 09:33 AM) [snapback]410796[/snapback]</div>
    Schmika, My story is one side Unfortunately I was not video recording my journey across the state but i would like to point the fact that a police office is just as capable of "coloring" his story. he or she is no saint either (with your background its probably hard for you to believe)
    As per our friends at wikipedia "Testimony is a form of evidence that is obtained from a witness who makes a solemn statement or declaration of fact. Testimony may be oral or written, and it is usually made by oath or affirmation under penalty of perjury. Unless a witness is testifying as an expert witness, testimony in the form of opinions or inferences is generally limited to those opinions or inferences that are rationally based on the perceptions of the witness and are helpful to a clear understanding of the witness' testimony."
    What bothers me is the fact that the Officers Testimony is the one that counts and not mine. How/or why i am not sure. In what way is the officer guaranteed to tell the truth.
  13. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    Man, that sucks... I know several areas that have radar detectors that print out the speed on a little sticker for the officer, and in those areas the sticker has to be present by law. It's really something that should be enforced nation wide to keep cops honest. Everyone knows that they get their monthly or quarterly quotas, and they'll issue more tickets at the end of the month than the beginning, and they're more likely to add a few miles to your speed just to bump it up and reach their quota faster...
  14. daniel
    14,487
    1,519
    Spokane, WA
    <div class='quotetop'>QUOTE(ggops @ Mar 23 2007, 07:25 AM) [snapback]410820[/snapback]</div>
    In a strict scientific sense, there is no such thing as proof. "Proof" in a court of law has a very diffferent meaning, having more to do with the procedural rules of the court than with actual fact. Cases often turn on who is believed. Making a good impression and having competent representation are far more important than actual guilt or innocence. When it's your word against the cop's word, chances are the cop will be believed because of the (sometimes erronious) assumption that he's dedicated to protecting society.
    A man named Herrera was convicted in Texas of murder and sentenced to death. He later requested a re-trial based on new evidence, but the time limit had passed. Texas does not allow re-trials for new evidence after a certain time. In Herrera v. Collins (1993) the Supreme Court rejected his appeal. In a dissenting opinion, Justice Harry Blackmun said something to the effect that "executing a person who is actually innocent would be perilously close to murder."
    Here's why I bring this up:
    Justice Sandra Day O'Conner replied to Blackmun's objections by stating something like: "A person who has been convicted in a fair trial is actually guilty."
    There had been no procedural errors in Herrera's original trial. O'Conner's statement is precedent for the assertion that the "correctness" of the trial (i.e., whether or not correct court procedures were followed) rather than the events themselves become the legal determinant for actual guilt or innocence.
    Whether Herrera was innocent or guilty, O'Conner was saying that actual guilt or innocence depends on the court, and not on the facts of what occured.
    You are innocent until proven guilty. But "proof" has nothing to do with facts, and everything to do with court procedure in the jurisdiction of your trial. And "proof" may be nothing more than the cop's word against yours, if the cop appears more convincing to the judge than you do.
    You are much more likely to go free if you are guilty but have a good lawyer, than if you are innocent and have a bad lawyer.
    In the case of speeding tickets, you are generally better off just to mail in the fine. Of course, you are better off yet to drive under the speed limit. Think of it as "protection" money paid to the mafia that calls itself the government. In every country, the biggest mafia gets to call itself the "government." (Though traffic laws are one of the few areas where this mafia does something good.)
  15. viking31
    viking31 Member
    515
    22
    West Central Florida
    <div class='quotetop'>QUOTE(Dragonfly @ Mar 23 2007, 06:11 AM) [snapback]410764[/snapback]</div>
    That's right. Your admission you were traveling (and purposely) 2 MPH over the speed limit will probably sink you.
    Lawyers have an old saying "you cannot come to court with dirty hands"...
    With that being said, yes, no one expects a speeding ticket at just 2 MPH over the limit. But I agree with the other posters, it is not worth your time, money, and effort to mount a defense which most likely will fail.
    Rick
    #4 2006
  16. jimmyrose
    jimmyrose Member
    646
    Northern NJ
    I've fought a few speeding tickets in my time; some successfully, some not. If you in fact state/provide evidence of in any matter that you were over the speed limit (even by 1 mph) the judge may find you guilty of speeding, with just the speed itself being the debate. I have been in court when someone was being charged with 2 mph over the posted 35 mph, and because I believe there was some history between the judge and the officer, the judge ruled in favor of the defendant.
    In my area, if the speed you are being charged for is not the minimum (1-14 over posted), you can usually plead down to the prosecutor at your court appearance; this can reduce your fine/points for you, and might be done to ease the prosecutor's load - this all depends on your driving record.
  17. Dion
    Dion New Member
    128
    Jersey City, NJ
    The best you can hope for is to plead it down to a fine with no points. That's what I did. They only want your money.
  18. koa
    koa Active Member
    980
    45
    Hawaii
    It's good to carry a disposable camera or use your cell phone camera and take a picture of the radar/laser gun and the reading. The officers credibility is questionable if he cited you for 80 when the gun said 75. He lied.
  19. desynch
    desynch Die-Hard Conservative
    607
    Lakehouse
    Dude just man up and pay the ticket. You were speeding. If you weren't then take it to court and dispute, but believe me, the courts will probably side with the cop because people like you ALWAYS claim you are soooo innocent.
    Godiva.. grow up.. Calling a cop an a$$hole for doing his job is just plane immature. GROW UP LIBERALS.
  20. ggops
    ggops New Member
    <div class='quotetop'>QUOTE(desynch @ Mar 23 2007, 01:11 PM) [snapback]410997[/snapback]</div>
    Wow desynch, you must have some form of ESP to figure out about "people like me." Lets abolish all forms of defense for "people like me".
    Didn't realize the Gitmo style operation has spread to mainland as well.
