PSD oil change help?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Floyd, Sep 13, 2006.
  1. Floyd
    Floyd New Member
    Gulf Coast, Grand Bay, Alabama
    I'm planning to change my PSD fluid at 30k miles and was wondering where the drain and fill plugs are. The only reference that I could find is at http://hiwaay.net/~bzwilson/prius/pri_T_cold.html . The photo shows an earlier model and mine is a 2005 which seems to be a little different. I didn't want to accidentally remove the coolant plugs. Does anyone have a link to this proceedure or a good photo that I can reference to? Thanks
  2. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    [attachmentid=5005]
  3. TucsonPrius
    TucsonPrius Member
    167
    16
    Tucson, AZ
    2020 Prius
    If the photo isn't enough, the PSD drain plug takes a 10mm hex, whereas the inverter drain plug is a 24mm socket.
    The fill plug is also a 24mm socket, but it's on the side of the PSD, not the bottom.
    Thanks,
    Shawn
  4. bwilson4web
    15,933
    <div class='quotetop'>QUOTE(Floyd @ Sep 13 2006, 05:00 PM) [snapback]319153[/snapback]</div>
    Sorry 'bout that.
    I've put a link to the photo in the web page and will add more text shortly.
