A question that, while not a big deal is most annoying to me. I have the V with navigation, but no solar or technical package. When I put four discs in the player, the first disc I load goes into the first slot and so forth until disc 4 is loaded into slot 4. Then when I push the button that opens the screen to close it, the player always starts with the disc in slot 4. Unless I remember to load disc one into slot 4, I have to open up the door again, and eject disc one, then reload it to get them to play in the proper order. What am I doing wrong? I know there must be some very simple step that I am missing, but damned if I am going to read that monster manual again, I must have missed it the first time. Thanks.
Mine works the same way. If I then want to listen to disc 1, I select select disc 1 to be played. Not a big deal to me.
x2. Not a big deal for me either...just select the disc that you want afterwards...it is not like the changer holds 10 discs....
OK, how do you get to that screen quickly? I guess I have been able to go there a couple of times, and I agree that is no big deal, but most of the time the screen I get is to eject one or all the discs so I then eject disc 1 and put it right back in. Thanks
Press the CD button on the left side of the NAV and bring up the CD menu. On this screen you can select the disk that you want.
