Question about how long a prius can sit unused?
Discussion in 'Gen 2 Prius Main Forum' started by momfortheenvironment, Aug 6, 2006.
  1. momfortheenvironment
    146
    Southern New Hampshire
    I have another business trip in sept where I would normally park my car at the airport on sunday afternoon and fly back wed. Is that too long, will I come back to a dead battery? I'll probably call the service dept to see what they say but that seems like a flaw and it if costs me money I'm not going to be happy. What is the longest anyone let their car sit? :unsure:
  2. mcbrunnhilde
    mcbrunnhilde Opera singin' Prius nut!
    619
    26
    <div class='quotetop'>QUOTE(momfortheenvironment @ Aug 6 2006, 07:42 PM) [snapback]298831[/snapback]</div>
    You will have no problem with the car sitting unused for several days. If you were going to leave the car for several weeks, it would probably be a good idea to turn off the Smart Key button under the steering column (it turns off after 10 days by itself, but you might as well save the 12v battery). If you were going to be gone for more than a month, I think most people recommend that you disconnect the 12v battery, either at the attachments under the hood or on the battery itself.
  3. DaveG
    DaveG Member
    806
    Vancouver, BC
    You'll be fine for 2 or 3 weeks without any issues at all. If you're going to be gone more than 2 or 3 weeks, Toyota recommends shutting-off the SE/SS system (if you have a package with that option). That will slow the drain on the 12v accessory battery.
    The high-voltage battery in the back will also slowly discharge over time. Toyota recommends that if you're going to leave the car for a long period of time (more than a month or two), that you get someone to periodically start the car and run it for 10-15 minutes to maintain the high-voltage battery.
    Dave
  4. pirateprius
    pirateprius New Member
    149
    Eastern North Carolina, Home of the ECU Pirates
    I just left mine in the garage for 8 days when we took DH's HiHy to the beach for vacation. I turned off the headlights and disabled SKS. When I got back had plenty of battery charge. A few days at the airport should be no problem.
  5. Mokulele
    Mokulele New Member
    2006 Prius, less than 300 miles. I left it in the airport parking lot from July 13th thru Sept 4th (that's 54 days). When I got back, the car started like as if I drove it every day. Main battery showed 3 bars left upon startup. I didn't turn off the Smart Key either. FYI.
  6. fphinney
    fphinney Member
    234
    Walnut Creek CA
    <div class='quotetop'>QUOTE(Mokulele @ Sep 4 2006, 09:58 PM) [snapback]314329[/snapback]</div>
    WOW! From what I've seen on PriusChat, this flies in the face of some other's experiences!
    Anyhow, this is good news. However, I still wouldn't bet my life on my car starting after 54 days! Thanks again,
  7. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    Thats definately not the norm... Even on regular cars (without SKS), there's a small draw on the battery (i think i read it could get up to 0.25 amps, but i could be off by a factor of 10 or something) when turned off. while this doesn't seem like much, after a while it really adds up (54 days is excessive, i wouldn't count on any car turning over after that long). So no one should expect to be able to go this long. congrats on not having a dead battery, though!
    Oh, and for the record (since the above post could lead to some confusion), a dead battery in this sense refers to the 12V battery, not the HV battery... that one should still be at or very near where you left it, since it is disconnected from the system when turned off.
  8. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    <div class='quotetop'>QUOTE(pirateprius @ Aug 6 2006, 08:25 PM) [snapback]298846[/snapback]</div>
    very interesting thread here. one poster says the 2006's SKS shuts off automatically after 10 days of inactivity. you went waaay over the recommended time to leave SKS enabled and were ok. did your SKS work or did you have to use the remote unlock on your fob??
  9. NineToez
    NineToez New Member
    26
    I've heard from sales trainers directly from Toyota that if you plan to not operate your vehicle for more than three weeks to disconnect the battery (under the hood). I know that they mentioned a specific reason, however it was probably the same as what's been mentioned in this thread already.
  10. eagle33199
    5,122
    268
    2015 Prius v wagon
    <div class='quotetop'>QUOTE(NineToez @ Sep 5 2006, 12:13 PM) [snapback]314609[/snapback]</div>
    Under the hood? do they understand that the battery is in the trunk? (i'd much rather disconnect directly at the source, rather than furthur down the line at a circuit box or something...)
  11. wilco
    wilco New Member
    402
    I've left mine parked for three weeks, on two separate occasions, didn't disable the SKS, and had no problems. The doors unlocked and the car started with the fob in my pocket, so the SKS didn't auto turn off.
  12. NineToez
    NineToez New Member
    26
    <div class='quotetop'>QUOTE(eagle33199 @ Sep 5 2006, 10:28 AM) [snapback]314652[/snapback]</div>
    Forgive me, simple typo... I did mean in the trunk.
  13. FJRCRAZED
    FJRCRAZED New Member
    100
    S.E PA
    Just got back from 28 days in New Zealand and Tahiti. No problem with it at all. I didn't even bother to look in the manual to say what your suppose to do.
  14. Mokulele
    Mokulele New Member
    Once again. My Prius was left at the airport between Sept 12 - Oct 7th, that's 26 days. Didn't turn off the SKS. It fired right up and drove home fine. I do have contingency plans but so far so good.
  15. Bill Lumbergh
    Bill Lumbergh USAF Aircraft Maintainer
    537
    NorCal
    I left my Prius sitting from May 26th to September 4th and came back to full batteries. The hadn't been moved while I was gone. I *did* disconnect the negative battery cable from the 12V battery, and I don't have SKS. The HV battery didn't discharge at all, though.
