Question about MG1-2 efficiency
Discussion in 'Gen 2 Prius Technical Discussion' started by Doza, Jul 6, 2009.
  1. Doza
    Doza New Member
    MA
    Exactly how efficient are these generators? Could they be used in other applications, oh say a wind generator?
  2. wfolta
    wfolta Active Member
    366
    146
    Washington DC
    2018 Prius
    Sort of like how people use Subaru "boxer" engines for homemade airplanes? This kind of thing brings new meaning to recycling of cars. (Sorry I don't know the answer for you.)
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    They are pretty efficient, but you can do better if your horsepower needs are a bit more modest. The MGs on the Prius are hybrid permanent magnet motors, meaning that they work as permanent magnet motors up to a point, and then start acting as induction motors.
    Tom
  4. ken1784
    ken1784 SuperMID designer
    2,943
    1,380
    67
    Yokohama, JAPAN
  5. Doza
    Doza New Member
    MA
    Sorry can't seem to open that document at work. How was the RPM rating vs. VDC of these generators?
  6. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    The motor/generators are three phase AC units and require the electronics to create DC. They produce about 500 V. Efficiency ranges from about 80% to about 94%, depending on load and RPM (max efficiency was around 2400 RPM -of the HSD-). The study did not separate the MGs and run them up.
    The efficiency is about what you would expect for units of this power output (which was not specified in watts in the study but rather in N-metres). Usually the higher the power capability of a generator, the higher the efficiency. Note that the Prius units are not thermally designed for continuous high output, as they are "supplemental torque producers" used for acceleration etc. During the study they "exceeded the rated temperature".
    If you want to use them for power generation you would have to do a lot of engineering.
