I'm looking for my first Prius, a second generation. I work on my cars for the most part, and have had good luck with Bentley manuals. What do-it-yourself repair manual is best for Gen 2 Prius? I understand that tires wear out quickly. What strategies should I use when buying new tires, e.g. get 70k warranty vs. 50k warranty? I read about pulse and glide, but don't understand how to do it. Please help. Also, would that lessen my transmission's lifespan? How about the battery? Can I use synthetic transmission fluid in the tranny? Thanks!
Pulse and Glide plus Warp Stealth in the Prius II for maximum FE … - CleanMPG Forums As for transmission fluid, AFAIK, the only fluid approved is Toyota ATF WS which some here have stated is a synthetic. I personally wouldn't mess around w/anything else. I don't see a point. Google searches for siteriuschat.com atf ws might prove insightful.
Thanks. I test drove a Gen ii Prius. I tried the pulse and glide, and watched the display. As soon as I took my foot off the accelerator, the green arrows appeared and persisted with mpg at 99.9. Sometimes at the beginning of the glide, I did not press the accelerator, and the green arrows persisted. Why do they recommend tapping the accelerator pedal at the beginning of the glide? It seems unnecessary to me. I watched several Youtube videos, and they made the same recommendation. As to transmission/tranny fluid, I read elsewhere that it gets dark and the magnet fills with metal by 53k, so I intend to change it every 20-30k, as I do in all my other vehicles (and have never had a tranny die on me). Someone else in this forum made the insightful comment that Prius' planetary gears have nothing special to protect them from the gunk accumulating during extended tranny fluid changes. I'd rather do frequent changes than risk damaging the transmission. My mechanic to-be says that Prius taxi trannies go out at about 200k. I also saw a craigslist ad for a Gen 1 Prius whose tranny died at 218k. Does anyone know what's in the WS, i.e. is it 75W-90? If so, I would be tempted to use Mobil Delvac Synthetic Gear Oil 75W-90, which is commercial-grade, extended drain that someone else on this forum used in his 2007 Toyota Landcruiser (albeit he didn't say he used it in his Prius)
I have the higher res LCD so the colors are different. IIRC, for me, arrows going into the battery are blue. Regardless, you want to dead band (no arrows at all) to minimize losses by putting as little as possible into the battery via regen (when you coast w/no foot on either pedal) or by drawing as little as possible out of the battery to maintain speed, incurring a double conversion. If you have a ScanGaugeII - Trip Computers + Digital Gauges + Scan Tool and watch the bta XGauge value, if you coast at a moderate speed, you'll see ~19 amps going into the HV battery. If stopped w/AC and headlights off, IIRC, draw is ~1.3 to 1.8 amps. When dead banding, it's above 1.8, but still better than when you have arrows coming out of the battery. From one PDF at http://priuschat.com/forums/gen-ii-...ngauge-best-threads-mileage-improvement.html: I'm confused by what you mean by "tapping the accelerator pedal at the beginning of the glide"? You should pulse up to a certain target speed, then glide by dead banding. http://www.vfaq.net/FAQ-fuel.html mentions the late Dave Hermance (too bad I never got to meet him ) and pulse driving. BTW, regarding your tire question. I didn't at all care about tire warranty when I bought mine. I think that's true for most people here. I looked for a combination of fuel economy (or less of a hit), handling (partly based on comments here) and whether they could deal w/light snow. At the time I replaced 2 tires, I was in CA where it didn't snow but feared I might have to move back to WA (where it sometimes snows) for work. So, I ruled out summer tires.
What Bentley doesn't cover, you can find most answers here on PC. Bentley is way better than any Haynes or Chiltons manual. Bentley also has common procedures not in the factory service manual. Buy new tires and rotate them every 5,000 miles. See http://priuschat.com/forums/gen-ii-...resistant-replacement-tires-current-list.html for ideas. Battery longevity seems most affected by extreme temperatures -- very hot or very cold. Transaxle longevity seems most affected by lack of fluid change. Use only synthetic fluid in the transaxle, specifically Toyota ATF WS or Redline D6. Change it as soon as you get the car, unless the prior owner has a receipt for making the change within the past 60,000 miles.
Replacement Battery Warranty Thanks to both of you for your replies. I was curious about what happens when the Gen 2 battery dies. I called the Toyota dealer, and they offer a new battery but only a 1 year warranty on it. They couldn't explain why the original battery has a 10 year warranty, yet a replacement only has 1 year.
Re: Replacement Battery Warranty Toyota ATF WS is extremely thin and has very low viscosity. If you spill some on a concrete driveway you can easily wash it away. This is nothing like gear oil. Perhaps I can explain. Prius is rated as AT-PZEV compliant. This is a State of California Air Resources Board rating. To qualify for this rating, the vehicle's hybrid system components must be covered under an extended warranty. Once that warranty has expired, the manufacturer has no further obligation to extend that. However, Toyota offers a one-year warranty applicable to all spare parts. Hence that warranty also applies to the traction battery. Suppose you were to buy a non-hybrid Toyota with a 5 year, 60K mile power train warranty. Some time after the warranty has expired, imagine your car needs a new transmission and you ask your Toyota dealer to install a new unit. The new transmission would only be covered under the one year parts warranty, not a five year warranty. Regarding a repair manual, if you plan to do any serious work then you will want to have access to the Toyota repair manual, electrical wiring diagram, etc. You can buy these volumes as a paper copy for ~$400 - $500 or you can access the subscription website, techinfo.toyota.com
Re: Replacement Battery Warranty Buying a new battery from a dealer is truly the last resort. The vast majority of battery failures are one module out of 28. Repair is anything from do it yourself module replacement for maybe $50, to installing a junkyard salvage battery for about $500, to buying a reconditioned battery from one of several sources for $1500 or less.
