Quick question about A/C - Heat
Discussion in 'Gen 2 Prius Technical Discussion' started by DeekoPete, Jan 19, 2008.
  1. DeekoPete
    DeekoPete New Member
    38
    Wisconsin
    Hi all,
    I live in Wisconsin and today it's been really freaking cold. I went to hit the climate control and noticed that I was getting heat, but it showed that the A/C was on. Is this normal? I looked in the manual and the image shows it being on, so I'm sure it is, but I just want to be sure.
    Thanks!
    :) - Pete
    EDIT: Haha, I found the answer I needed using search. It is on if I hit the auto switch.
  2. Tideland Prius
    16,406
    yay for using the search function!!
    Yes, A/C doesn't mean cold air. You use A/C to dehumidify the air too (so your windows don't fog up).
  3. DeekoPete
    38
    Wisconsin
    And it works well for that, too! Seriously, this car is amazing! I swear I've just been reading the manuals for the past two days... :)
  4. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    That does not mean that the compressor is on, only that it is enabled in case it is needed to dehumidify the cabin air.
  5. patsparks
    10,664
    567
    Adelaide South Australia
    As the compressor speed is controlled by the computer it only runs as fast as it needs to to get the job done, so it wouldn't need to run at full speed to dehumidify the air if it was cold out.
    This is unlike a conventional car air conditioner where the compressor speed is determined by engine speed and a valve allows the system to work at different compressor speeds but with variable cooling again dependant on engine speed and the AC cycles on and off to control temperature. This uses more power than necessary and is not able to cool at its peak when idling causing temperature variations.
    The Prius air conditioning is like the inverter reverse cycle air conditioners manufacturers rave about and you pay more for, for your home. Except the Prius uses engine heat to heat the cabin.
  6. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Actually, the Prius air conditioner compressor would be locked out in cold temps anyway. The PAG oil isn't rated for cold temp operation. However, if you have heated parking, then the compressor could still run until either the pressure switch tripped it, or the temp sensor shut it down
    For my home, I have the A/C programmed to lock-out at temps colder than +55 F. If you don't have a heated compressor blanket, operation in temps colder than that will result in short compressor life
    My FJ Cruiser is programmed to run the compressor whenever the selector is in Defrost or Defrost/Floor. Since I have heated parking, that means the compressor is on, and I have no control over it. The interior will get bloody cold until the system senses the bitter cold outdoor temps and the compressor is locked out
    At least the Prius I can manaully disable the compressor. With the FJ, I just went into the master fuse box and pulled the compressor relay. Problem solved
  7. DeekoPete
    38
    Wisconsin
    Honestly, I'm impressed with how they implemented the whole system. Thanks for all the answers!
  8. Joey
    Joey New Member
    I've heard to think of the A/C light in the Prius as auto climate, instead of air conditioning.
  9. joerdie
    joerdie New Member
    61
    Cincinnati Ohio
    I thought something similar! I was thinking they meant air conditioning as in it "conditioned" the "air" to whatever temp the user wanted. "air conditioning" could technically mean either hot or cold... or maybe I'm just a huge dork with too much time on my hands.
  10. KTPhil
    KTPhil Active Member
    1,379
    The A/C light simply indicates that by pressing that button (or by proxy through the AUTO button) you have granted the car permission to run the compressor as it sees fit.
