Quick Question: Is there a way to visually tell if an igniton coil is bad?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by acemason, Jun 27, 2018.
  1. acemason
    acemason Junior Member
    SF
    Question in title. I'm in the middle of changing my spark plugs. Was just wondering if there's a way to visually check if the coil is bad. I don't have a multimeter or anything.
  2. acemason
    SF
    Here's a pic of them if it helps. There's some brownish copper looking residue towards the top of one of them and the bottom of two of them.
  3. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    not really
  4. Patrick Wong
    18,200
    6,490
    Rust stains? Dirt? Clean off the residue using isopropyl alcohol.
  5. Mendel Leisk
    40,238
    You can pull the coils, insert a spark plug, ground the plug to the engine, disconnect fuel injector electrical connections and run the engine in inspection mode, see if there's a spark. More info in the attachment.
