Radiator Issue
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Prakash, Feb 13, 2007.
  1. Prakash
    Prakash New Member
    76
    I recently had an incident with my Prius 2004, and fortunately everything was covered by the Insurance Company. The repairs have been done, and there down to one last thing.
    My mechanic told me they had to replace a Canister in the front left; I believe it has something to do with the radiator. (I am not quite clear on what exactly the part is) In any case I assume the canister has something to do with the radiator. The mechanic told me he has to get air out of the canister to prevent the engine from overheating. He went on to say it has a sort of pressure cap on the top that he has to use to remove excess air in the engine which is causing the engine to overheat.
    Is anyone aware of what in the heck I am talking about? I will edit this post when I understand the issue more thoroughly. If any one understand this please h elp me out, thank you.
  2. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    Sounds like the "Thermos" to me.
    I don't have the diagram handy but the NA Prius has an insulated bottle that stores hot coolant when the car is stopped and uses it on startup to decrease warmup time and thus decrease emissions.
  3. Prakash
    Prakash New Member
    76
    <div class='quotetop'>QUOTE(Tempus @ Feb 13 2007, 08:30 PM) [snapback]389852[/snapback]</div>
    Can air get stuck in it?(Thermos) And at the same I suppose be successfully removed.
  4. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    it's a PITA to bleed air out of that coolant system... it's a bit tricky. so yes, what you're being told makes sense.
  5. Prakash
    Prakash New Member
    76
    <div class='quotetop'>QUOTE(galaxee @ Feb 13 2007, 09:03 PM) [snapback]389865[/snapback]</div>
    That is the exact terminology used by the company, "bleeding out the air." Furthermore, he said it was indeed tricky. In fact, he said on one day he spent half a day just bleeding the air out because he had to turn on the engine, and what not -and at the same time not put too much stress on the engine, as a result of the process.
    Will this effect performance, or should I assume that once all the air has been taken out I won't have to worry about the potential of overheating?
    Once again I appreciate the help.
      File size:
      22.2 KB
      410
  6. Prakash
    Prakash New Member
    76
    Do any one know the answer to this question? (this is pertaining ofcoarse to the thermos)
  7. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    It sounds like the thermos was replaced. Please do not drive the car until the system is properly bled by a Toyota hybrid-certified mechanic. You risk catastrophic, espensive damage to the inverter/converter and the gasoline motor.
  8. galaxee
    9,810
    468
    MD
    yep, once they get the air out of there you're back in business.
    but as jayman points out, the best people to do this would be the toyota techs at a dealership, especially since the guy already spent half the day messing with it and still hasn't gotten it.
    in fact, go ahead and *insist* that the toyota shop does it. it's the best way to be sure all the air is out. it's too complex and too important to not be completely sure.
  9. Prakash
    Prakash New Member
    76
    <div class='quotetop'>QUOTE(galaxee @ Feb 14 2007, 12:12 AM) [snapback]389985[/snapback]</div>
    I guess I should have referred to my mechanic as the local Hybrid Toyota Tech guy at Toyota, same guy that spent half a day bleeding it.
  10. galaxee
    9,810
    468
    MD
    <div class='quotetop'>QUOTE(Prakash @ Feb 13 2007, 11:43 PM) [snapback]390008[/snapback]</div>
    ...oh. :unsure: sorry to hear that.
    realistically we're talking 20 min if you're lucky (or know Wth you're doing) to 45 min on average. in case of FUBAR... 2 hours.
    does the guy know where the valve is? there's a nice layout in the repair manual describing how to do this...
  11. Frank Hudon
    Frank Hudon Senior Member
    4,147
    there is a procedure in the service manual that tells how to hook up the THHT and cycle the coolant pump to bleed the air from the system. There is a section in the manual that tells you not to remove the cover on the thermos.
  12. jayman
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(Prakash @ Feb 14 2007, 12:43 AM) [snapback]390008[/snapback]</div>
    Oh geez, find yourself another tech. Pronto!
