Ran Out of Gas With 5 Pips Showing
Discussion in 'Gen 2 Prius Main Forum' started by brucesax, Apr 13, 2010.
  1. brucesax
    brucesax Junior Member
    NC
    My car died on me today. I pulled into a parking lot within .25 miles on battery only. Totally shut down with a dash full of warning lights. Had to have AAA carry car to dealer on rollback. Code showed out of gas but had 5 pips showing. Turned out to be a leaf blocking the sensor which told car that it was out of fuel. Fixed and recharged 2-hours and $105 later.
    Strange situation but good techs and Dealer.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    A leaf blocking the sensor...no way. I don't buy that explaination one bit. The fuel level sensor is much more complex than that and I can't imagine any way a single leaf, even if it did, somehow, get into your tank, could cause that problem.
    I'd be looking for a better explanation. What was/were the actual code(s) pulled?
    Do you think you should have been out of gas? How far had you gone on the last fill at what MPG?
  3. ljbad4life
    ljbad4life New Member
    365
    24
    Maybe the leaf clogged the line (and not the sensor). which would starve the engine of gas and essentially shut the engine down. The sensor would still show the correct amount of gas, but the gas could not get past the clogged fuel line.The most pertinent question is how would such a large item get into your gas tank? sounds a little sabotage-esque to me
  4. derkraut
    derkraut Member
    299
    28
    SAN
    Yup; something doesn't compute here. Did the dealer tell you about the "leaf" issue? Something's rotten in Denmark, I think. For $107.00, I would go back to that dealer and ask for a more detailed explanation, and get the specific code readouts.
  5. Mylar
    Mylar Member
    163
    36
    Cincinnati, OH
    2019 Prius
    The leaf could have entered the fuel system from a contaminated fuel tank at the filling station. Seems very logical to me :)
  6. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    The only way to find out if there is a leaf in the tank is to take the gas tank completely apart. No way they will charge only $105.
  7. hschuck
    hschuck Member
    385
    bay city, ca
    The blockage could have been downstream from the tank and much more assessable.
  8. hill
    8,560
    Welcome to PC bruceax ... sorry for your experience. Any chance that the tech mentioned how a leaf got in there? I mean this IS spring time. Maybe if this were Autumn? / Fall? ... and refilling your tank at a station with trees near by? on a windy day so they'd be blowing your way? I duno. What do YOU think.
  9. Tom Banjo
    Tom Banjo New Member
    62
    South Florida
    Gas from the gas station tanks goes through a filter in the pump prior to getting in your car. Most gas nozzles are fairly tight fitting, as many states require the fumes to be prevented from esacaping during filling. That is not to say a leaf can't get in a tank, but it is unlikely.
    I do not know where or how many filters there are for the Prius gas system, some cars have two, one at the tank, and another near the engine. More likely sediment or the unidentifiable remains of a leaf blocked something. I doubt they pulled a whole leaf out of anywhere in the fuel system.
    In any case, most likely would not be a warranty issue, so $107 might be cheap. It is possible they have no idea and that is a story to explain why it happened. If it happens again, obviously, you have lots of leaves in your gas tank.
  10. brucesax
    NC
    I reviewed the repair ticket this morning after all of the comments. It states "Cleared leaf from airflow meter and cleared codes."
  11. priushippie
    priushippie New Member
    330
    Pennsyltucky
    It must have been a Nissan Leaf! I new they would be trouble for the Prius!
  12. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Well that's a whole different issue and is not related to running out of gas.
    Tom
  13. Politburo
    Politburo Active Member
    971
    208
    Leaf still shouldn't have gotten by the air filter though..
  14. richard schumacher
    7,664
    1,042
    United States
    Sounds like carelessness when installing the last engine air filter: not completely securing the cover (which can be caused by putting in the filter upside-down), or maybe making a hole in the filter.
  15. brucesax
    NC
    Careless filter installation sounds plausible to me. I just purchased the car 5-months ago and the previous owner had just had a oil / filter service prior to purchase.
    I was told that the code read out of fuel. But, in further inspection, they found the leaf as the true culprit.
    The techs and dealer performed the service late in the day , which they did not have to do.
    Positive techs but a very sensitive car.
  16. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    You beat me to that one!
  17. CharlesJ
    CharlesJ Member
    467
    29
    38
    Monterey
  18. KTPhil
    KTPhil Active Member
    1,379
    "Airflow meter" in the fuel system?
    Or was it a leaf in the mass air flow sensor? And how did it get past the air cleaner?
