Ratcheting Click in the Steering wheel column
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 2010priusowner, Dec 6, 2010.
  1. 2010priusowner
    2010priusowner New Member
    37
    FL
    I have a 2010 Toyota Prius that has always since day 1 had a ratcheting clicking noise in the steering wheel column.
    The sound occurs each and every time I pull out in reverse from a parked position then as I am pulling forward as the wheel straightens out the noise occurs I will try and record it I wonder can I post a sound file here?
    Before anyone start asking about CV Joints or going off their own separate diagnostic tree let me be perfectly clear the noise I am describing is absolutely 100% in the steering column not under the car outside the car or somewhere other than where I have described.
    So the question goes out to all of you other 2010 Prius owners does your steering column do this make this noise that is?
    It makes me think something is attempting to calibrate itself.
    If this is not normal could there be a tsb for this?
    the car only has a little over 2000 two thousand miles on it I was planning on bringing it up to the dealer during the 5,000 mile service.
  2. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    My steering column does not make any clicking noise...
  3. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    no noises in mine
  4. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    I have the same noise on mine - it sounds like something is being reset or as you say, calibrated - it is not a "worrying" sound, rather something "happening" in the first few seconds of operation.
    There is no TSB and as far as I know you are the first one posting about it. I never thought of doing it as I considered the noise normal. And I think it is. (until it breaks :D).
  5. 2010priusowner
    37
    FL
    I fixed the problem, by turning on the radio. Now I do not hear it!:rockon:
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Did you bring it by the deal at all?
  7. 2010priusowner
    37
    FL
    No they are very bad all of them in my surrounding area in fact, it makes me wonder about, toyotas future when their dealerships are so bad!
    Very long boring story concerning the scummy dealerships, they call them stealerships for a reason but incompetent techs is taking it way too far.
  8. msmit002
    msmit002 Junior Member
    63
    O.K., so now my 2006 Prius is doing EXACTLY what you describe. I had it in at the dealer and they can find nothing wrong. The CV boots/joints were checked; they're fine. The clicking and rough/rumbly feel of the steering wheel is still present. I usually get it when steering a good 90 degree turn at rather slow speeds (think parking lot, etc.)
    Now, Jiffy Lube just remarked that the power steering fluid needed to be changed since it black as my boss's coffee, so my mechanic is doing that today, along with giving the steering a once-over to try and find the problem.
    So, did your problem ever go away? Or better yet, did you figure out what was wrong?
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    The power steering in the Prius is electric. I wasn't aware that there was any fluid to change.
    Tom
  10. adamace1
    1,403
    193
    Charlotte, NC
    Jiffy Lube 1
    You 0
  11. msmit002
    63
    Thank you, yes I now know that. Thank goodness my mechanic is honest and pointed that out to me. Nevertheless, your sarcasm is better spent elsewhere.
    So, the latest theory is that there is something wrong with the front transaxle on the driver's side. I'd really like to hear from others who can offer an opinion before my suspension conks out on me while driving my kids to school.
    The problem is that I cannot get the problem to present itself consistently. Some days the steering wheel feels like it will shear off right in my hand from the grinding and other days it seems fine..
  12. Bwrx
    Bwrx New Member
    Anyone have any ideas why the original poster's car is making the noise?
    I think my car is doing the same thing except the noise only occurs after the car has set a bit.
  13. V4Phan
    V4Phan Junior Member
    Ventura, Ca
    Check the steering linkage. Two U-Joints that could be damaged or the metal clip that holds the rubber boot in place inside the cab .... I trouble shooting mine now
  14. priusrat
    priusrat Junior Member
    CT
    My 2012 Prius II began having this EXACT same issue shortly after I bought it new. When I back it out of the garage in the morning into a K turn, the steering makes a faint ratcheting noise as I turn it. It continues as I turn the other direction going forward. I've had it at the dealer twice for it - left it overnight. In the morning, they claim they cannot hear it. I think it was worse in cold weather, even though I garage the car in a garage that is rarely under 40 degrees Fahrenheit.
    I just saw that there is a recall on the Prius steering column.
