Rattling/buzzing noise low speeds
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Cole 2005 prius, Jan 16, 2023.
  1. Cole 2005 prius
    Cole 2005 prius New Member
    Valley center
    I just took a trip to the snow with my 2005 prius. I had to drive it pretty hard and go through some deeper snow and some ice. I now hear a rattling sound from the bottom front of the car. It comes on intermittently and turning left seems to be when it mostly happens. It only makes the noise at 5-15mph and it's rare. I have a video of the noise uploaded to my YouTube channel. Any help would be greatly appreciated.
  2. Tombukt2
    Tombukt2 Senior Member
    12,900
    2,316
    Durham NC
    You sure that's not ice buildup on something that's reciprocating a drive axle in the wheels literally something like that seemingly that's what it sounds like seems kind of plasticky sounding too like a piece of heavy under chassis plastic is flopping flapping when something's jammed in it pushing it against whatever is rotating like a drive axle end or something can't really see from here but the snow and ice is not fun for these cars driving them hard in the snow is not really a good thing best to go easy in the snow not trying to forge new ground
    51,840
    Maybe a bent or loose exhaust heat shield
  4. Cole 2005 prius
    Valley center
    NewThank you guys for all the help! Update I took it to a mechanic and he found the sound odd. He drove it around and it turned out I bent the catalitic converter cover when driving over heavy snow and when the exhaust would rattle at low speeds it would hit against it. He put a piece of wood under it and bent it back to normal. Car doesn't make the noise anymore and everything's great. Thank you!!
