1. acowsar1
    acowsar1 Junior Member
    US
    Have a 2012 that rattles sounds like some squirels are having a fight under the hood when I turn it on and at stop lights.
    LG-H931 ?
  2. Mendel Leisk
    40,533
    Have you popped the hood and listened during startup? One time after a dealership visit they closed the hood without the hood support latch properly clipped, sounded bad, on ours. As an example.
    Raytheeagle likes this.
  3. acowsar1
    US
    Yeah no it's not the hood its some kinda engine noise only does it when the motor comes on I'll try and get a recording tommorow.
    LG-H931 ?
  4. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    In addition to @Mendel Leisk ’s suggestion (which I had happen too), I’d pop the hood and see if anything else is loose;).
    Some questions:
    • How many miles on your Prius?
    • How long have you owned your Prius?
    • Has this just become a recent phenomenon?
    • Any recent work or damage to the car?
    • Where in the great US of A are you located?
    Good luck and keep us posted (y).
  5. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Clogged egr circuit
  6. acowsar1
    US
    180k and ive owned it since 2014 has slow oil leak and i live in austin tx area. Its been happening for about 3 months had to take it in and get the spark plugs replaced mechanic said they were saturated in oil.
    LG-H931 ?
    #6 acowsar1, Dec 25, 2018
  7. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    How much oil does it consume and in what mileage does it consume a quart?
    Has it ever ran low on oil where the level couldn’t be seen in the dipstick?
    Does your Prius consume oil?
    Did the mechanic recommend the spark plug replacement?
  8. acowsar1
    US
    id say maybe a quart every 1000 miles give or take. it has gotten really low a couple times. The spark plug replacement was reccomended by my mechanic it was needed they were sarurated In oil.
    LG-H931 ?
  9. Mendel Leisk
    40,533
    You might qualify for piston and ring replacement under the excessive oil consumption Technical Service Bulletin. I believe the threshold is around one quart in 1200 miles.
    I'll post the TSB's tomorrow morning. They essentially give you 2015 model year pistons and rings. And I would think do some cylinder and head clean up. A gasket kit rebuild is part of it too, including new head gasket I think.
    Addendum:
    Here's those TSB's. Dealeships should be aware of them, but it doesn't hurt to read through them, see what the oil consumption criteria are, and what's involved in the repair. It's pretty much a complete engine tear down, at least what's required to get the pistons out.
    Note: with the oil consumption test, they top up the oil, put seals on everything, then tell you to come back in "1100 to 1300" miles, for the consumption check. I would definitely make the return visit as close to 1300 as possible, and do some spirited high-speed driving on the way there. Maybe a hill climb or two...
    #9 Mendel Leisk, Dec 26, 2018
    Robert Holt likes this.
