Rear Doors
Discussion in 'Gen 3 Prius Main Forum' started by alanderego, Aug 17, 2009.
  1. alanderego
    alanderego Member
    87
    26
    Honolulu, Hawaii
    Does anyone else have this tape on their rear doors?
    It is on the bottom edge towards the rear on booth doors.
    What is it for?
  2. Tideland Prius
    16,402
    All new Toyotas will have them near the rear door area (this is the first time I've seen it on the door though.. usually it's in the rear fender). It's basically chip protection from rocks/pebbles.
  3. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Supposedly for protecting against rock chips.
  4. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    It takes up such a small area it makes me question whether there's any value to it. Why would rocks/pebbles strike only that particularly small area?
  5. Tideland Prius
    16,402
    Probably the most susceptible area compared to the other areas?? I'm assuming it's to protect from rocks kicked up by the car itself and not from other vehicles passing by.
  6. cantgoback
    cantgoback Junior Member
    santa rosa, ca
    I was guessing it was for protecting the corner when opening the door (carelessly) next to a high curb or rock or something else that might scratch up the corner. I wonder how effective this really is. But I'm not about to try it out. Does anyone know if this is the same/similar material as the invisible car bra that many dealers have installed at the ports?
    Going a bit further, it would have been nice if they had covered the entire door to protect it from people in adjacent cars opening their doors and slamming into yours. Continuing the thought -- imagine a windshield that had an outer coating of some soft material that wasn't as susceptible to cracking as glass is from rocks etc. That would reduce 50% of my paranoia while driving.
  7. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Yes.
    Many cars have that plastic film placed on vulnerable areas.
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Why not go for 100% and wrap the entire car. :D
  9. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    That sounds much more like what it's for, especially given how low the car is to the ground/curb and the small area the film covers. A true rock chip film occupies a much larger area (at least the transparent aftermarket ones).
  10. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    Hmm, mystery over here:
    1. If for rock chips etc, would cover more area.
    2. If for door protection when opening , hitting curbs etc - why not the front doors?
    I've seen similar protection on my previous cars, but just behind the wheel openings - truly for stone kicks...
    It MUST serve a purpose, and for a good reason. Or Toyota would have not installed them. Even .10 per unit manufactured plus a bit of labor is not chump change when they're looking to save every cent.
    Surprised this thing wasn't marketed as a Port Installed Option and charging us $40.
  11. pfreeus
    pfreeus New Member
    62
    CA, USA
    I would think that if it was meant to protect the door when opening against curbs then I would think it would wrap around aw well.
